FDA says plastic bottles safe for chemicals
Forum for the discussion of any material/synthetics.Only posts with info /or links to research info allowed . Any posts recommend the use of any material without copy's or links to show proven research will be deleted
pHneutral
Re: FDA says plastic bottles safe for chemicals
Post by pHneutral »
I think it's not so much "plastic" as the types they are using.. the cheap types.
Things like PTFE are hugely resilient, but they are also hugely expensive and cost the same or more than the metal or glass counterparts.
So as one poster above said "Its all about the money".
I'll stick with glass and metal, and only use PE for fermentation of things intended for distillation.
If I was doing beer or wine (or mead), I'd definitely use glass or wood for the process.
FireH20
Post by FireH20 »
Will someone please give hard facts/research/medical/biological/physiological/etc. evidence about how 40% alcohol stored in plastic containers over X amount of time causes harm to the human body when ingested - and how that happens exactly?
(Hint: "I will never use plastic ever", "I don't believe in it", "You're an a-hole if you disagree with me", don't qualify as evidence.)
This is not a trick or rhetorical question. I don't have the answer either. I''m just trying to separate the heat from the light.
Give a man a fish, and all he'll want tomorrow is another free fish.
Hack
Post by Hack »
I think the powers that be are coming from the standpoint that most research/information about plastics that shows plastics are ok is focused on how the plastic is affected by alcohol, but little is known about how the plastic affects the alcohol. So with the absence of information about how the alcohol is affected it is decided to take a cautious stance here on the forum.
However, that's just my understanding of it, and thank god, I am no way in charge of such things. Now back to my UJSM, which is particularly tasty this evening.
theholymackerel
Post by theholymackerel »
FireH20 wrote:Will someone please give hard facts/research/medical/biological/physiological/etc. evidence about how 40% alcohol stored in plastic containers over X amount of time causes harm to the human body when ingested - and how that happens exactly?
The Chemist has stated here that EVERY water specimin he tested in his lab that came from a plastic bottle tested positive for plasticisers.
If water is a good enough solvent to extract plasticisers what is the ethanol capable of? Surely a solvent mix of water and ethanol is gonna be far more aggressive than water alone.
Tell ya what... why don't you go and dig around on the net and through science journals and try and find us some evidence that an ethanol/water mix stored in plastic is perfectly safe for consumption. You don't seem to trust the "better safe than sorry" stance, so you do the leg work please.
Harry
Post by Harry »
Holy,
I have no doubt that the chemist is giving true info, and you are getting quite exasperated with all this talk of plastic bottles. But May I make a simple observation?
Everyone is missing the point with the plastic spirit bottles issue.
The spirit NEVER TOUCHES the plastic. It is COATED with a BONDED LAYER of ...wait for it...CARBON.
The base material is PET plastic, sure. Gotta have something as a former. Could easily be wood, or glass, or metal, or whatever substance will hold a shape and be cost effective.
Sazerac has been using this technology since 1997 for its Ancient Age whiskey, as has Early Times. I haven't heard of one single case of problems, health or otherwise. Considering the hooha surrounding this issue, Don't you think the FDA would have yanked it if there were any issues? Has Sazerac gone broke over lawsuits? Not likely.
So, now that we are better informed as to what we are dealing with, is anyone prepared to say they would NOT let their booze touch CARBON???
If anyone is truly interested in being better informed, google BARRIER TECHNOLOGY. and pet bottles for alcohols here...
http://tinyurl.com/9d4qg4
Let's hope this is an end to the misunderstanding.
Slainte!
regards Harry
zymos
Post by zymos »
T
Followed that link and did some reading, and although SOME coatings are applied to the inside of the bottles, MOST seem to be applied to the OUTSIDE of the bottle, or sandwiched in a layer inside the plastic itself. Because the purpose of the coatings, to most of the manufacturers, is not to protect the beverage from exposure to PLASTIC, but to protect it from exposure to OXYGEN.
Harry
Post by Harry »
Yep. Many different coating and multi-layered options are available these days. You can 'dial up' just the requirements you need ant the manufacturers will provide the solution. In the case of spirits, at this juncture the preferred option is blow-molded PET with an interior bonded coat of Carbon.
By the way, all the closures used in existing GLASS bottle spirits, like synthetic corks and plastic caps, even the aluminum caps, are nowhere near as good as the Barrier bottles. But that's an area they are working on.
Slainte!
regards Harry
junkyard dawg
Post by junkyard dawg »
I don't need anything more than my own experience to decide that I don't care for using plastics. Lots of folks have had plastic hydrometer jars... They all know what I mean... I've put spirits in plastic bottles and gotten funky plastic flavors in it. The chemists comments on the subject and a healthy skepticism of the FDA's real masters lead me to choose a no plastic ethic. I don't need some internet article of proof that alcohol and plastic are not great together.... I've seen it with my own eyes and tasted it too.
Good to see you post Harry. I do feel better informed.
this is the internet
Harry
Post by Harry »
Aye JD. That was the aim.
Slainte!
regards Harry
blanikdog
Post by blanikdog »
Yup, me to too Harry. The more information we get, the more informed individual decisions we can take. Thanks
blanik
Cumudgeon and loving it.
theholymackerel
Harry wrote:If anyone is truly interested in being better informed, google BARRIER TECHNOLOGY. and pet bottles for alcohols here...
Interestin'.
If ya have any more links with good plastic/alcohol info please post 'em.
junkyard dawg
yeah, cool technology at work there. Its surprising to me that some of those barrier technologies could be cost effective.
Harry
Post by Harry »
junkyard dawg wrote:yeah, cool technology at work there. Its surprising to me that some of those barrier technologies could be cost effective.
There's three basic Barrier Technologies. Each has specific uses in the packaging industry. Some are for oxygen-scavenging to prolong the shelf life of foods. Some are strictly a physical barrier between the food and the container itself.
The three types are:
Coating
Monolayer
Multilayer
In Coating...Bottles are blow-molded and then coated with a layer of material suitable for the designed end-purpose. In our case for alcoholic beverages it (the bottle) is coated on the inside with a layer of carbon. This is different to the other popular methods for obvious reasons.
Cost to manufacturers is at present between $6 and $8 per THOUSAND bottles. Less than a cent each to coat.
Read this...
http://www.ce-pip.com/docs/31-33_F345_PET_barrier.pdf
Slainte!
regards Harry
HookLine
Post by HookLine »
Good stuff, Harry. While serious caution with plastics is the smart default position to take, that doesn't mean we shouldn't keep an open mind to technical progress.
Be safe.
Be discreet.
And have fun.
atticpc
Post by atticpc »
This is interesting.
I am one of the bold people who used to use plastic for storing normal bottle strength. Moved off that to glass. When I was storing in plastic most of what I was using was empty bottled water bottles. I never noticed any taste being added to the drink - but I think that it would be safe to state that there was probably no carbon coating on those bottles. Now re-using a plastic spirit bottle would be a very different thing as those bottles are designed to be used with alcohol.
