sand
sand
how about the use of sand as 'double boiler',
I've some +: cheap, will not evaporate as water will, it can hold weight (<->water)
- : will I get stable temperatures with the use of sand? (equilibrium) I would like to use wood as fuel.
and will it conduct enough the heat?
-I have too much blood in my alcohol system-
I've also seen designs for home-made heating mantles made out of diacotemous (sp.?) earth, aka betonite. For that matter, any mud-brick suitable clay would probably do. Make up a slurry, form it around the boiler, and let dry.
An alternative to vegetable oil would be ethylene glycol, aka anti-freeze, although there may not be much difference from a safety perspective.
- Tater
Water has the advantage that it holds the max temp to 100degC so you cant burn anything. By the time your boiler gets to 100C there's no ethanol left anyway.
When using firewood, keeping the heat input low enough is a problem. Flooding the column and having vapour and hot 95% liquid pissing out the top of the still get a bit exciting.
An overheated water jacket can be cooled rapidly by adding cold water. I wouldn't like to try that with brick rock or sand.
Nice theory, wrong, but nice.
I think I'll try it some day
an other advantage: less loose of energy (evaporating water takes a lot of energy)
I don't think you will burn something with the use of sand. is you use a nice buffer (thick enough), then the inside of the sand will have the same themperature of the (boiling) wash, so, no possibility to burn somethingWater has the advantage that it holds the max temp to 100degC so you cant burn anything. By the time your boiler gets to 100C there's no ethanol left anyway.
Has this been covered? Waterbaths.
One of my first "paycheck" jobs was as a cook for a big chain steakhouse.
They had breads and salads and soups on a buffet bar, in adition to the entree's and sides that people ordered. I started out in the prep kitchen, and the double boilers that they used were 7-8 gallon pots, with a stainless steel insert liner. The soup sits in the liner(this is great for cream soups, as it is unlikley that the cream will break dowm as fast), and the water sits in the big pot. OK, what is so different ? The liner had an mouth that was as big as the outer pot, and the weight kept the soup liner flush against the rim of the outer pot. The water that did boil, transfers its energy to the side of the soup liner, and then recondenses. These rigs would ocasionally burp a little steam, but only if they were running on too high a flame, and the soup was also boiling or really just too hot in the case of very thick stuff.
So what I'm saying is that if your doubble boiler is designed nicely, the boil dry problem is minimal. With that said, My rig does not have a well engineered waterbath, and the escaping steam has wasted countless hours of my time.
It is important that the water vapor does have a way out, so that nothing explodes.
Re: sand
stoker wrote:how about the use of sand as 'double boiler',
The problem I see with sand is that it will just slow down the heat input but not control the temperature - water controls the upper limit for temperature without slowing heat input that much.
The problem with firewood is the variability of heat input and overheating. Either water or sand will give thermal mass to slow down the variation, but overshooting is the problem. It is easier to measure the temp of water than sand and easier to cool it down in an emergency.
What sort of still are we talking about?
SIAS - It shouldn't be too hard to test.
Guys,
lots of discussion on this topic. And luckily most of it makes good sense
But my vote goes to oil in the double boiler. Vegetable oil (like for deep frying) boils at 180 degrees. As far as i know there is no way a mash gets that hot. So, before the oil even gets to smoke the mash should be completely boiled dry.
I think it is no coincedence that farmers in Germany, Austria and the rest of eastern Europe (and maybe other parts of the world) use double walled stills on oil for their (semi-) professional eaux-de-vie / schnapps / spirits.
KJH
KJH
A hot oil heat bath for a still makes me nervous. Ever get a drop of water in hot fry oil ? I have multiple scars fromm hot oil. Don't make the situation too dangerous. Hot oil boiling on an open flame with a combo of water and ethanol boiling on top of it would be a bit risky.
I don't want to hear about any of you guys on the news: "Moonshiner invents one stroke desil motor". I would use somthing non-flamable if I could.
Possum, don't get me wrong: it isn't an open oil bath in wich my still sits. For goodness sake.. I wouldn't even dare to step near the thing.
The boiler i use was already a double walled vessel when i got it, used for insulating food or something. I drilled a hole in the outer shell to fill and empty with water / oil / sand / other heat transferring material, and have a cork in the hole to seal it. The seal is not too tight, so if any pressure is building up it can blow off.
At first i used water, but i found that was boiling off quite fast and had to be refilled often. Second; it corrodes the outer wall wich is not stainless steel, but zinc plated iron.
KJH
KJH
I tried sand before. one of my first rigs was a stainless fire extinguisher that had a round bottom. I put it in a vessel of sand and tried heating it. I couldn't get it hot enough & it stunk badly.
Peanut oil can withstand high temps for long periods without burning. many other oils stink when burnt, and burn easily.
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
I dont know how big your still is,but if its something like a milk can,you could get a big cast iron skillet to lay between the still and the flames.Ive done that before and the cast iron is great at holding heat.Or if its to big for a 14 inch skillet,get a sheet of steel.Ive never tried a vegetable oil double boiler,and it does sound like a good idea....but it scares the heck out of me.Picture this: A nice big,hot pot of glistening oil heating up a still down in some overgrown laurel thicket.Everything is going well...that sweet familiar smell is rising up from the still,and the moonshiner tending to it is sitting all cozy right up next to it doing what he likes to do best.......and then it starts to rain......
Oil combusts if you get distracted and let it overheat. Water just evaporates and the boiler gets discolored or warped. You don't neeed more than 100C heat, so why not use water.
Re sand what you want is something which is a good conductor of heat that also tranfers the heat to the whole area of the boiler bottom so there are not hot spots like when you put a boiler on a electric stove burner. The ideal would be a 2" thick copper or alu boiler intergral with the bottom with and element embedded in it. Next best is a thick copper or alu layer integral with the boiler with an element under it.
A separate 2 inch copper or alu plate between the burner and the boiler won't work nearly as well since it will not conform perfectly, and there will be air spaces between the two surfaces and smaller areas of contact where most of the heat tranfer will take place.
Sand is not a good conductor of heat (to say nothing of airspace between grains), and will conform pretty well but not great to the boiler bottom. Odds are it will seem to work well until you notice how much longer your runs are taking - because the price you are paying is for more even heat is wasting most of it.
Supposedly Helium is a good conducter. Of course it is notorious for escaping through the smallest of holes.
If you are talking about your copper water heater stoker, then I guess a metal plate wouldnt help.
But if you had a flat bottomed still, then the metal plate could be good.
In a hot wood fire sand could concievably fuse together into a big lump of glasslike.... making a horrific mess on the "outer" pot.... if you had quartz/silica sand.
If OTOH it is "play sand", which could also be ground up coral
or seashells.....UN-fun way to inadvertantly make quicklime...
(is there a fun way to inadvertantly make quicklime?)
If you really want to try a dry media? Might I suggest shopping for some "Black Beauty"? (both a brand name and a coloquial name) Black beauty is Silicon Carbide made specifically for abrasive blasting.
It also is a better conductor of heat than any of the other types of "sand"
and if you manage to melt any I don't want to be anywhere near you when you do....
silicon carbide is most commonly used for making abrasive stones
Silicon Carbide has also been fused into rods for use as heating elements
Particularly in hydrogen atmosphere furnaces used in the aluminum industry... I doubt there is anything you could do to hurt it...
But it might be a viable alternative for a dry, non-reactive media for a double boiler.
AllanD
AllanD
