Boiling point of EtOH and azeotrope
Postby WV Shine » Mon Apr 23, 2012 10:13 pm
I had talked about this in a previous post.... turns out I don't have to do the math afterall :sarcasm: Found a chart that gives the boiling point of water, ethanol, and azeotrop at different elevations. Hope its useful for anyone up in the mountains ;)
Original source: http://gillesenergies.webs.com/boilingpointaltitude.htm
WV Shine
Re: Boiling point of EtOH and azeotrope
Postby astronomical » Tue Apr 24, 2012 9:00 am
thanks.. i never looked this up... i guess im at 77.1... that explains some things...
i feel rather stupid now.... i've never seen this mentioned on here.... (I knew elevation mattered, but, im in the flatlands of IL... guess its still almost 1000 feet)
seems to me that 78.1 is rather mythical for most people.
Now, what to do.... Calibrate my thermometer to the correct nembers for my elevation OR keep it calibrated with the difference adjusted.... guess it'll work either way
@ WV..... If you calibrate your thermometer to 212 for boiling water than your elevation will be irrelevant... If you're using an encapsulated mercury/alcohol/wax thermometer than this chart should be somewhat helpful
astronomical
Postby Odin » Tue Apr 24, 2012 9:11 am
I live a few feet below sea level, so thank you WV for the info!
:thumbup:
Odin.
Odin
Master Distiller
Postby WV Shine » Tue Apr 24, 2012 9:13 am
astronomical wrote: feel rather stupid now....
Ha yea I did too... I was flippin out the first run I made w/ my VM... On the cleaning run w/ vinegar my brand new fancy-pants thermometer was reading 93F or thereabouts... I was pissed! I think I realized what was wrong a few days later when I was making pasta and realized it took a bit longer due to the elevation :roll: The difference is pretty huge where I am... azeotrope is at 73.3C?!
WV Shine
Postby rad14701 » Tue Apr 24, 2012 2:59 pm
I'm at +1350 and never worry about exact temperature readings or corrections, just stabilization and changes...
Master Distiller
Postby rockchucker22 » Tue Apr 24, 2012 3:16 pm
Thanks very interesting, I'm at 5000 ft so this makes perfect since.
if your gonna ride, ride the wild horse
rockchucker22
Master Distiller
Postby heartcut » Tue Apr 24, 2012 3:37 pm
When I lived a 9000 feet, it took forever to boil potatoes. Around 10000, you can't cook them by boiling. Now I live at 50'.
heartcut
My Theory of Evolution is that Darwin was adopted.
Steven Wright
heartcut
Return to Research and Theory
Who is online
Users browsing this forum: Guns_Garlo and 4 guests
