You can not make whiskey from tomato paste but you can make neutral from grain. Confused?
It is a myth that you must use a pot still to make whiskey or good whiskey. With the risk of stepping on some “traditional toes” I will explain why I can make better whiskey with a fractioning column than a pot still.
Starting with your wash, what ever you ferment has particular characteristics. Some washes contain higher amounts of nasties. Great example, turbo yeast ferments. Some washes have greater amounts fusels, ie Rum, Whiskeys etc. Some washes contain more lower boiling point alcohols. (Heads) All washes contain most alcohols in varying percentages. Fusel oils vary by ferment content. Most but not all flavor congeners are located in the fusels.
WHAT is in your wash is what you get! Period. You wont get whiskey from a tomato paste wash or turbo yeast in a pot still. There is plenty good reason you get crap when pushing your wash SG.(from us and from your still) Higher gravity ferments and the nutrients necessary for them create more crap than a lower gravity wash. IE;Turbo etc.
All these different parts we call Fractions. Fore shots, Heads, Hearts and tails all contain a variety of different alcohols, fusels and the different flavor congeners that hide among them. Again, different ferments will have different fractions in varying amounts.
Okay, now that you are on board there and understand that your wash has different components lets talk about distilling.
When distilling, Fractions do not magically disappear. OR magically appear! Lets look at a grain ferment. Run carefully through a pot still, fores are discarded, heads are taken, hearts are taken and only very deep tails avoided. Commonly all tails are taken. After dilution, It is run again with the same procedure. Results? Damn fine whiskey!
Why cant you make neutral with a pot still? Well you can, with a really clean wash and if you are willing to run it ten times. Without reflux you are getting one distillation cycle maybe two from a pot still. It takes close to twenty distillations cycles to make perfect tasteless alcohol.
Pot stills are better suited for whiskey or rum because they are not real good at separating fractions. They lack the ability to allow for equilibrium to occur or even partially maintained during take off.
With a reflux column equilibrium
Typical blending of neutral or vodka distillate would include some late heads and avoid even the earliest tails. Even a great whiskey ferment distilled to a high % and collected in this manor will have middle jars that are devoid of flavor that can be blended as a neutral.
Blending reflux whiskey is a little different. Typically heads are carefully avoided, hearts are blended with early tails then diluted to oaking strength before deep tails are added. Deep tails are added carefully by taste until the edge is found. The slight bitter edge that will smooth over time on oak.
The master distiller doesn't just run a still, he blends his product for oaking.
Yes. Some of my pals (maybe many) will argue I am full of **** but, I will put my blending up against their pot still any day. Of course assuming we are using the same wash.
I believe it is about understanding the distillation process and that better equipment makes better product in the right hands.
MR
stirring the pot
