Page 14 of 17
Re: Glass Marbles for Reflux Column Structured Packing
Posted: Mon Mar 06, 2017 1:24 pm
by BayouShine
This thread has caught my interest over the last few days. I've been running copper scrubbies in my 2" CCVM for a while now. I figured marbles were a cheap option to experiment with, so why the hell not? I bought the 2lb sacks of marbles from Hobby Lobby for $3. They are a little over 1/2" dia. so I guess 14mm. It took about 2.75 bags to fill my 40" column. I left a roll of scrubbies on the top and bottom to hold the marbles in.
Here's what I was getting with copper scrubbers.
- 93.JPG (14 KiB) Viewed 5301 times
This is what marbles gave at the same takeoff rate.
The big difference for me is that I had to increase the power from 2000w with scrubbers to 2700w with marbles to maintain the flooding inside my sight glass.
I think I'll stick with the marbles for a few runs and see if I can find any difference in taste.
Posted: Mon Mar 06, 2017 1:40 pm
by Klein
BayouShine wrote:This thread has caught my interest over the last few days. I've been running copper scrubbies in my 2" CCVM for a while now. I figured marbles were a cheap option to experiment with so why the hell not? I bought the 2lb sacks of marbles from Hobby Lobby for $3. They are a little over 1/2" dia. so I guess 14mm. It took about 2.75 bags to fill my 40" column. I left a roll of scrubbies on the top and bottom to hold the marbles in.
Just out of curiosity what was your takeoff rate?
I'm in the proses of building a 2" ccvm with the same packed column length.
Posted: Mon Mar 06, 2017 1:51 pm
by BayouShine
Roughly a quart/liter every 30 minutes or so. If I go any faster, I lose azeo.
Edit: I just timed it. 26min for 1L at 95%.
Posted: Mon Mar 06, 2017 4:55 pm
by joeymac
Excellent reporting bayou.
I'm surprised you got a scrubber to hold in all that weight!
Your results are nearly identical to my findings on my old 2x36" column which pulled off about 2.5LPM of 95%+ with an estimated 2500-3000w input.
Posted: Mon Mar 06, 2017 5:30 pm
by BayouShine
I say scrubbie, but it's the rolled up copper mesh. I guess it's about 4-5" long and stuffed into the ends fairly snug. It holds the marbles pretty well. There's also no rattling while the still is running.
Posted: Wed Mar 08, 2017 5:36 pm
by T-Pee
Just ordered 4.5# from Amazon for $14. I've gotta try this!
tp
Posted: Wed Mar 08, 2017 5:55 pm
by BayouShine
I'm kicking myself for not trying this sooner. Last run, I collected 4 gallons of 95% from 12 gal of 40% low wines and feints. The still locked on to 95% through 3 gallons before I had to adjust the power. I never saw anything close to that with the copper packing.
Posted: Wed Mar 08, 2017 6:48 pm
by Fills Jars Slowly
joeymac wrote:I''m surprised you got a scrubber to hold in all that weight!
I use two stainless scrubbers, shown in a picture further back in this thread, as packing retainer. I was surprised by not needing more support for the marble packing. The scrubbers probably could have held packing for a much taller 2" column than I have. Larger diameters might be different. I hold marbles in my 4" column with a copper wire mesh screen.
Posted: Sat Mar 11, 2017 4:11 pm
by Bobbywolf
I made a copper retainer to hold back the marbles. Lots of holes drilled, and then I soldered solid copper wires across the holes so the marbles wouldn't plug the holes. Finally I attached a tube for a handle for installing it.
My column has a SS triclamp ferrule on the inside of the pipe, so this retainer slips in, then rests on the ledge. Guaranteed no marbles will fall into the boiler.
Posted: Sat Mar 11, 2017 4:29 pm
by joeymac
well that's the prettiest packing retainer I ever seen
finishing up my new stainless 3" column this weekend. I'm going to TRY to tig in some thin welded stainless 2x2 mesh (12mm gaps) into the bottom of the tube sanitary flange. It might go good but it might not. The mesh wire is only .047" thick and the flange is probably 3/16" thick... heck, my thinnest tig filler rod is even thicker than the mesh at 1/16".
https://www.mcmaster.com/#stainless-steel-mesh/=16pq2o4" onclick="window.open(this.href);return false;" rel="nofollow
Posted: Sat Mar 11, 2017 8:35 pm
by cob
it was made for a different purpose, but this holds marbles.
http://homedistiller.org/forum/viewtopi ... g#p6811105
Posted: Sat Mar 18, 2017 5:48 am
by Spriit Tisler
I should try glass marbles before doing anything else.
Posted: Mon Mar 20, 2017 1:14 pm
by Spriit Tisler
Umm.. I checked through 8 different stores and online but they only had these toy glass beads with hefty price.
Has anyone used ceramic raschig rings sold as filtering media for pools and other stuff? Or raschig rings whatsoever?
Posted: Mon Mar 20, 2017 7:19 pm
by joeymac
Hobby lobby... Get about 3-4 bags for a couple bucks each.
Posted: Mon Mar 20, 2017 7:51 pm
by still_stirrin
joeymac wrote:Hobby lobby... Get about 3-4 bags for a couple bucks each.
That's the place (I did post a link somewhere earlier in the thread). 12mm (or 14mm, I can't remember which) at $2.99 for 2 lb. bag. Getcha' a couple...so you can replace cracked marbles when they do. I haven't had very many crack, but I have had a few.
You'll see your purity go up as you increase the reflux ratio (use more input power/heat). Just make sure your reflux condenser can handle what you push, so it doesn't let vapor escape out of the top.
My 2" ID column is a meter (39") long and it takes about 3 lb. of marbles, but is capable of azeo with 2kW input power. I get a liter about every 20-25 minutes off the VM. The LM is a little slower than that, but not much...a liter every 25-30 minutes.
Posted: Thu Mar 23, 2017 6:28 am
by spiff
I think I want to try this too. Would just leaving the bottom plate in to hold the marbles interfere with the marble advantage at all? I"m planning on filling my 6 plate flute with marbles using only the bottom plate and all 6 T's filled with marbles and then keep the foot of copper packing above that.
Posted: Mon Mar 27, 2017 5:19 pm
by casper the Irish
1. If smaller marbles were available, would the increase in surface area:
- improve purity
- increase flow
2. If glass was more conductive of heat (say, made of clay or stone) would it be more efficient, need less heat?
I was thinking how to test this, looking at pea gravel (irregular rough small 7mm stones) or beach pebble (smooth 12mm)
Posted: Mon Mar 27, 2017 6:04 pm
by Bobbywolf
I have 7/16" (11mm) marbles as opposed to the 1/2" (13mm) most have and I have found it is very easy to flood the column. I would guess 7mm would pack down much more and create worse problems.
I nearly doubled my takeoff speed while holding 95%+, and no off tastes, than when I was using copper packing.
I certainly recommend marbles but wouldn't go smaller than mine due to flooding and possible blockage issues.
Posted: Mon Mar 27, 2017 7:54 pm
by Badmotivator
Bobbywolf wrote:I have 7/16" (11mm) marbles as opposed to the 1/2" (13mm) most have and I have found it is very easy to flood the column. I would guess 7mm would pack down much more and create worse problems.
That's good info and advice, but what column diameter and power were you running when you saw flooding? I'm thinking about small marbles for my 4" column at 4kW.
Posted: Tue Mar 28, 2017 4:26 am
by joeymac
on my 2" with 5/8" marbles, I was getting great takeoff rates and purity around 2.5-3kW (column uninsulated). I've finally got enough low wines together and getting ready to run my expanded 3" column sometime in the next few days also using 5/8" marbles. I plan to use between 4-5kW and insulate the top of my boiler along with insulating the bottom 36" of column. I have a small sight glass on top the tower now so I can really push it hard and then back off when shes either losing purity or ready to upchuck.
I'm not sure it matters, but i've measured 5/8" marble packing at a 42% open volume/flow area inside a 3" column. I have no reason to think it varies too much in a 2" or 4" column... maybe +/-5% or so.
Posted: Tue Mar 28, 2017 9:06 am
by casper the Irish
I read that dia of packing stones should be a seventh of the column dia. Odin also sas the packing should conduct heat. Glass is a god insulator, stone is more conductive.
I run a 3" CCVM which I am told should be 80% flooded but my turkey boiler is maxed at 2.8kw
I have never been able to achieve flooding or puking! But flooding is good, it provides max reflux when kept to just below the puke
Posted: Tue Mar 28, 2017 7:25 pm
by captainshooch
Just my 2 cents worth, anytime you run any still in a flooded state you are defeating the purpose, specially on a plated, or plated and packed combination. If that is what you want, then park the plated still and fire up a pot still.
A flooded still becomes a single plate at the flood point.
Posted: Wed Mar 29, 2017 12:14 am
by Bobbywolf
For those wondering my boka is 3" by 48" tall. I run it at 2400w on spirit runs. I have no sight glasses, but when I run at 3200w I'm flooding to the point where she starts to spew.
With no packing, I can run it at full 4800w and I am able to knock it all down with the condenser, so that isn't the issue.
A sight glass just above my packing would be great so I can tune it to run just at the ragged edge for maximum efficiency, but I'm not paying that price for the last little bit of efficiency. 2400w works great, with a great product output. This is even lower power than with my copper packing, and I still get a faster takeoff than with copper.
Posted: Wed Mar 29, 2017 1:00 am
by thecroweater
if you are flooding to the point of puking and that is a deliberate aim it is fair to say you don't quite understand reflux distillation. I don't mean to upset anyone but this idea that it is in some way beneficial to have a column flooded or pukeing is very far from true, this madness needs to stop. By flooding a packed reflux column you have reduced your packing height and theoretical plates by this amount, this is simple physics and plain logic. A section of immersed packing can not reflux vapour and that section flooding is at best doing the job of one plate or thump box and that also is simple physics and plain logic. Now if you are flooded to the point of almost puking then virtually all your column is doing the job of one plate as opposed to the equivalent job of a hundred or more plates and very little to no refluxing above it. The AVB might not be really bad although nothing like a column in full reflux but there is going to be a shit ton of carry over and that is also Simple physics and plain logic. Enough with the story's of how much better the still runs flooded and puking, some of us are having a hard enough time just trying to swallow that marbles are equal to packing with hundreds of times the surface area, sheez
Posted: Wed Mar 29, 2017 1:15 am
by Saltbush Bill
captainshooch wrote:Just my 2 cents worth, anytime you run any still in a flooded state you are defeating the purpose, specially on a plated, or plated and packed combination. If that is what you want, then park the plated still and fire up a pot still.
Couldnt agree more Captain
Anyone who thinks a flooded still is working to its maximum potential has a lot to learn.
You only need to flood the plates on a plated column and watch the ABV drop away to learn that.
Posted: Wed Mar 29, 2017 1:52 am
by Bobbywolf
thecroweater wrote:if you are flooding to the point of puking and that is a deliberate aim it is fair to say you don't quite understand reflux distillation. I don't mean to upset anyone but this idea that it is in some way beneficial to have a column flooded or pukeing is very far from true, this madness needs to stop. By flooding a packed reflux column you have reduced your packing height and theoretical plates by this amount, this is simple physics and plain logic. A section of immersed packing can not reflux vapour and that section flooding is at best doing the job of one plate or thump box and that also is simple physics and plain logic. Now if you are flooded to the point of almost puking then virtually all your column is doing the job of one plate as opposed to the equivalent job of a hundred or more plates and very little to no refluxing above it. The AVB might not be really bad although nothing like a column in full reflux but there is going to be a shit ton of carry over and that is also Simple physics and plain logic. Enough with the story's of how much better the still runs flooded and puking, some of us are having a hard enough time just trying to swallow that marbles are equal to packing with hundreds of times the surface area, sheez
I'm not sure if that was aimed at me, but I absolutely agree. The whole idea is for the liquid to drop back down and make it down into the packing to be revaporized. I was simply stating that if I crank the power higher, I get flooding which is most definitely not the aim of a reflux still. I maintain that the marbles appear to work much better than copper mesh, but I will not advocate purposely flooding your column.
Posted: Wed Mar 29, 2017 2:36 am
by Saltbush Bill
My comment was not aimed at you , but at this.
casper the Irish wrote:I run a 3" CCVM which I am told should be 80% flooded but my turkey boiler is maxed at 2.8kw
Posted: Wed Mar 29, 2017 4:29 pm
by FuelMaker
thecroweater wrote: some of us are having a hard enough time just trying to swallow that marbles are equal to packing with hundreds of times the surface area, sheez
I'm just spitballing here but I have to wonder if it's not so much the surface area as it is the volume of the entrained liquid - that the shape and smoothness of the marbles allows it to hold a thicker film of fluid than a thin copper scrubby strand. This would also help explain why SPP works so well, because it holds more liquid because of the shape of the triangular prizmatic coil peaks that hold a decent sized droplet in it.
Posted: Wed Mar 29, 2017 4:58 pm
by thecroweater
I don't know but I can say when I used structured copper packing I got 95.63% of pure neutral spirit every time with the slight exception of rum wash that had a very slight flavour. I get virtually the same result from scoria, you can't get better than that and I'm not convinced that marbles are equal to it. That is I have drank spirit from marble packed columns and didn't think it was quite neutral. Could be the way it was run but to my thinking a sphere is the least possible surface area for a given column and the smallest consistent void, so I think that has more to do with it. As I said many pages back etched/ scuffed marbles might have a better affect but might be difficult not to flood.
Posted: Fri Mar 31, 2017 2:47 pm
by Tomb
That is weird....
For my 48" - 2" and used about 7.25 lbs (It was good I ordered 8lb, as I only have about a cup full left over.)
These are the 14mm (but measure between about 13.5 and 15.5mm)
From this I figure you should have needed almost 6 lbs?
(1.78lb per foot)
For fun, I took a 39" piece of 1.5" and it took 3.25lbs to fill.
Might you actually have a 1.5" column?
T
