Brandon O's Graff Cider
Posted: Thu Nov 11, 2010 11:53 pm
For all non-scientific beerology purposes, this is a cider. (I know, I know....but its got hops in it!)
Jay Huff and his apple bee got me started on some experiments and this is what I have come up with.
I noticed Ed's Apfelwein tasted super hoochy until it was about a year old. When it's about a year old tho it does taste like a good cider, but doesn't have the body a good cider does.
So, how can I make something that will taste good faster and also have body?
1. Get rid of the wine yeast and use a clean fermenting beer yeast
2. Get rid of that cheap sugar and use some light DME
3. Balance the tart flavor of young cider by using specialty grains.
4. Later on, I found hops also helped balance the overall flavor. BUT ONLY A TINY BIT, DO NOT USE MORE THAN CALLED FOR
If you like a clean, malty, not too tart easy drinking cider style beverage then this is your drink.
Materials needed for a 5 Gallon Batch
Clean fermenting yeast I have used Nottinham and Safale-05, both are good
.5 lbs of Crystal 60L If you use cheap store brand juice, I reccomend 120L. Cheap juice tends to turn out a tad tart and this will balance it.
1 oz of torrified wheat ( head retention, I've never used more than 2oz)
4 Gallons of apple juice.
1 gallon of water
2 lbs of DME ( I use 1 lb. amber and 1 lb. light DME)
0.5 oz of you favorite hops ( right around 6% AA, I have used 18.5% AA summit hops before and it took a month after kegging for strong bitterness to blend nicely)
WARNING! IF YOU ARE GOING TO CHANGE THE AMOUNT OF HOPS USED, MAKE IT LESS NOT MORE, it's really just too bitter with any more.
Directions for brewing
Steep the 60L and torrified wheat in .75 gallons of water @ 155 degrees for 30 mins.
Sparge with .25 gallons 170 degree water and throw away grains.
Add DME and bring to a boil.
Add hops when boiling starts and boil for 30 mins.
Cool down the wort (if you choose not to cool the wort and just let the AJ do the cooling then your cider won't be as clear). I don't care about clarity so I just let the AJ do the cooling, but if you stick your pot in the freezer and let this get down to 70 degrees or so your cider will clear fairly easy. Pour the wort and apple juice into your carboy and pitch yeast.
Ferment 2 weeks at 64-68 degrees then keg or bottle.
I keg, and this stuff is VERY drinkable as soon as it is carbonated.
SUPERB taste and drinkability after 2-3 weeks of aging.
People bottling, it will have SUPERB taste and drinkability after the standard 3 week bottling period for carbonating.
Last edited by Brandon O; 06-10-2009 at 07:42 PM. Reason: Cooling the wort before adding to the AJ really helps clarity.
Just figured I'd throw this one in here, it seems to have quite a following elsewhere. I'm going to make a batch this weekend. I have a jug of Ed's Apfelwein going right now and I'm not entirely satisfied with it. It's drinkable, but I'm going to try this one.
1 gallon of water
