Ferment in the dark?
Alcoholic beverages which are not classified as spirits.
Postby D Major » Sat Jun 16, 2012 10:37 am
Just had a thought? I am working on an apple cider batch. 5 gal. The recipe says to ferment it in a dark place? Should I be doing that for ALL the wines etc. that I am working?
Thanks for your time.
D
Kentucky born and raised, Oregon distilled
D Major
D Major
Re: Ferment in the dark?
Postby myles » Sat Jun 16, 2012 10:40 am
NO. I have a few dark brown demijons but I only use them for things that specifically say to ferment in the dark. Most of the fruit fermentations do not mind a bit of light. Not sure about all the others.
myles
Postby frozenthunderbolt » Sat Jun 16, 2012 4:48 pm
Red (grape at least) wines loose their colour, and white wine may brown more rapidly. for the most part it is cosmetic, though i have a niggling feeling that their is a chemical change that can occur in some boozes as well - if i come across the reference again i'll let you know
frozenthunderbolt
Postby BrooklynTech » Sat Jun 16, 2012 4:58 pm
It's dark in my fermenting freezer under temp control.
BrooklynTech
Postby Dnderhead » Sat Jun 16, 2012 4:58 pm
yeast being a fungus does not like light.they prefer dark warm and damp.
UV can cause off flavors and can kill fungus /yeast.
watch the fluorescent lights also.
Dnderhead
Master Distiller
Postby Kas » Sun Jun 17, 2012 2:48 am
We all know that for our brew, direct sunlight is really, really bad. I'd say that indirect sunlight that is still relatively bright (for example next to a window, but not in a place where it will get direct sun), is also not that good.
But apart from that, is there much difference between normal room levels of light and complete darkness? For example just sitting in the corner of a room, maybe under a desk, not directly beneath the window but also not in complete darkness. I'd say it would be receiving a modest amount of light on the visible spectrum, but almost zero levels of UV, and it would make little difference to put it in complete darkness. :econfused: Correct me if I'm wrong.
K.
Kas
Postby Oxbo Rene » Sun Jun 17, 2012 3:56 am
I keep mine out on the back porch and don't seem to have a problem (related to sunlight) ......
It is not the matter, nor, the space between the matter,
but rather, it is that finite point at which the two meet,
that, and only that, is what is significant...........
(Of course, I could be wrong) ..........
Oxbo Rene
Postby D Major » Tue Jun 19, 2012 7:40 am
Thank you all for the input!
D Major
D Major
Postby Durace11 » Tue Jun 19, 2012 7:53 am
I keep a few hoodies or old sweatshirts and just put those over the buckets/bottles. Anything dark or thick will do the job just fine. Also a black plastic trash bag with a hole just big enough for the air lock is wonderful. Use a zip tie/painters tape/bungie to keep it locked around the bottle neck.
Current Evolution:
~ kekedog13
~Mr. P
Durace11
Postby GuyIncognito » Tue Jun 19, 2012 12:16 pm
+1 on Durace's comment. I have a cellar so everything is out of the light, but a few houses ago I just kept all my carboys in old shirts. Beer gets light-struck & skunky really quick (unless your carboys are brown glass), and anything subject to long aging like wine will also be damaged by UV exposure. I don't think it's as much of a problem for active ferments.
GuyIncognito
Postby firerat » Fri Jun 22, 2012 11:24 am
With ciders and wines, light isn't really an issue.
With beer (drinking beer not distilling beer) it is because of the hops.
Light interacts with isomerized alpha acids, which are produced when hops are boiled.
firerat
Return to Beer, and Wine
Who is online
Users browsing this forum: linkdex [bot] and 2 guests
