What is it about apples that removes the burn in shine?
Novice here... But I've noticed something.
In making different recipes after making base shine, my peach shine, black and blueberry shine, and raspberry shine is like drinking liquid fire. My apple cinnamon shine, especially after sitting a week goes down very smooth.
In my bit of research, I've read that the more tart the apple in sitting, the more it mellows, and found one recipe actually recommending using crab apples to get rid of the hotness and mellow it out.
At first I just thought it was sugar that mellowed it, but all the other fruits have sugar too, and adding glycerine didn't seem to have much effect. What is it in apples that tames so much? Pectin? Something else?
The reason I ask is because I want to venture into other flavors and have the mellowness my apple brings, I just don't know how. There's obviously something I'm missing.
Thanks!
Thanks!
Re: What is it about apples that removes the burn in shine?
How do you do your base shine ?
+1 Pikey...sounds like possibly too much sugar or inaccurate cuts to me
- der wo
Probably yes. But anyway it would be very interesting to know if and how the acid content of the apples affects the smoothness. Do you have links to your researches?
Yes - I do flavoured shines and there are some - sloe for example which comes out incredibly smooth whatever base spirit I use and others which vary when I think about it.
So I think a little research and discussion here may be a learning experience
Interesting. I see you can get dried sloe berries.
My method is pretty unscientific. I use the cold shine uncle Jessie's method.. and I'll note right now I'm sipping on straight apple pie shine that's absolutely delicious from it.
5lbs sugar
2 cereal bowls full of corn (scientific I know)
1 small can tomato paste
1 packet 15% abv whiskey yeast
Here's the unscientific link I caught regarding smoothing down whiskey. I guess technically this last batch was aged with allegator charred oak blocks and had a fish tank bubbler ran through it on a copper tube for a few days, so there's that. Technically a whiskey based shine is what I make.
https://gizmodo.com/5914858/how-to-make ... -smoother/" onclick="window.open(this.href);return false;" rel="nofollow
What I don't understand is that my peach shine I made a month ago is still a fireball. My apple I made two weeks ago is going down staight as we speak. There's something in the matrix that milds the apple and according to that article, it might be something within the tartness of the apple that does it.
Citric acid? Not sure what other acids would be in apples, but we might be onto something....
5lbs sugar
Malic acid is the main acid in apples. The name is derived from the Latin word for apple, malum, although it is found in lots of other fruit, including sloes and peaches.malignity wrote: Citric acid? Not sure what other acids would be in apples, but we might be onto something....
- der wo
Thanks for the link. Looking at the pictures I am surprised how many apples he takes. It looks like it will taste more like apples than like Whiskey.
Probably I will try it out (with my worst Whiskey first).
Per pint, I do 2-3 slices only. After about 2 weeks, all the color is drained from it and taste is MUCH more smooth.
If it's the malic acid, I'm wondering why my peach didn't mellow out. Maybe not enough of it?
I'm not exactly sure all an apple contains, but I can definitely attest that this works -- just not sure why.
This article has me really thinking...
https://www.livescience.com/44686-apple ... facts.html" onclick="window.open(this.href);return false;" rel="nofollow
Vitamin C? Polyphenols? (Don't blueberries have antioxidants too? Maybe different kinds?)
When making apple brandy I take a smaller heads cut to capture more apple flavor in the finished product. I feel this is a necessary evil when doing apple. That being said, the end product is much hotter than my typical whiskeys which are pretty smooth after cuts. I was hoping extra time in my once used Balcones would straighten this out but this process has me hoping there might be a short cut and no fears of contaminating the flavor as its apple based already. I will give this a go with a small sample. I would be skeptical of adding apple slices to my bourbon though just because of the flavor. Thanks for the insight malignity!!
Maybe potato slices in vodka???
I did a little digging. It's most definitely not polyphenols doing this. Berries are higher than apples and my berry blends didn't mellow.
- DAD300
Dif alcohols and dif acids form dif esters. It is more than possible that the acid(s) in apples use the some heads and tails constituents dif than other fruits. Thus removing what you taste as burn.
Also some ingredient in the apples may be coating your mouth and preventing the burn. Keep researching.
There is an article in Fall Artisan Distiller about this.
DSP-AR-20005
DSP-AR-20005
- HDNB
vanilla beans knock the edges off too. still tastes like whiskey, specially if you don't over do it and use some oak too.
now i drink for evil.
In reading this PDF, I'm thinking malic acid is what's doing it. What exactly it's doing I couldn't tell you though. My scientific brain only works so well before morning coffee.
https://www.google.com/url?sa=t&source= ... FHsFJCWnt6" onclick="window.open(this.href);return false;" rel="nofollow
Yep, this has to be it.
Wikipedia link explains malic acid is what gives tartness to fruit.
Given that first link suggesting crab apples, there's no question those are more tart, thus likely having a much higher malic acid level.
If I'm understanding this all correctly, malic acid can ferment sugars. If that's the case, this is likely removing any leftover low ester sugar alcohols and fermenting them out and thus making a higher grade...?
Here's the Wikipedia link. The PDF also mentions this.
https://en.m.wikipedia.org/wiki/Malic_acid" onclick="window.open(this.href);return false;" rel="nofollow
I'm not understanding why my berries didn't accomplish this though when my apples did unless it just has a much higher concentration.
- Hilltop
Are your blends all using the same base liquer? In other words can it be as simple as one batch was mixed hotter at higher proof? It sounds to me like your Apple cinnamon was made using good cuts. Maybe your other batches were made with too much heads.
"Virtute et armis" By valor and arms
Let's keep our country free as God has given us.
"Give me Liberty or Give me Death."
- masonsjax
Doesn't an acid and an alcohol combine to form an ester? Probably that's what's going on.
- TDick
FWIW -
My son bought a bottle of Jim Beam Honey
& I was trying to make it drinkable - no so sweet.
I mixed it with a bottle of Evan Williams ($9) and even nuked it but just too sharp to drink with water.
After reading this I poured it in a jar with a sliced Granny Smith and left it for a day.
Saturday, decided to try it with Coke while watching the Alabama football game - Roll Tide.
I refrigerated it and it's a little cloudy, but Incredibly smooth and there was no apple taste at all. And I don't know how to describe it but it has an very interesting "chew" to it.
Not sure I'd want to do for everything, but it sure helped clean up that mess.
- DAD300
Next time you have a really messed up bottle of commercial Booze, leave the cap off for a day or two (air it) and or add a dried cherry! The acids in the cherry do great things for heads.
DSP-AR-20005
DSP-AR-20005
This is my input based on experience distilling and heading up R&D in a craft distillery:
In my experience attempting to make an authentically prepared peach infused corn whiskey I learned something very interesting regarding fruit infusions. This discovery also put to rest a lot of folklore that we run into on this forum.
This information is in regards only to adding whole or portions of FRESH fruit or veggies to distillate - Dried or preserved will yield different results
When fruit is fresh it can contain anywhere from 10%-95% H20 and this H20 is to blame for the phenomena being discussed. When the fresh fruit is submerged and allowed to macerate in the distillate an osmosis reaction occurs in which areas of low alcohol concentration ( let's say a slice of peach) absorb distillate and in turn release h20 (along with sugars and esters). If one were to drink from the jar they would be pleasantly welcomed by sweet, smooth peachy goodness. Unfortunately the spirit they are drinking is (depending on weight of fruit to booze) most likely only 10%-30% ABV. Where did all that ABV go? Eat a peach and you'll see, that peach will taste nothing like fruit and fully of shine! - this has held true with any infusion where the substance to be infused has a water content.
This is a reaction I mistook for smooth booze for years of home distillation and helped explain the folklore to never eat the fruit in the jar.
SOLUTION? There are a few options I use everyday with great results but the best option to use at a home scale would be to create a fruit juice or better yet a concentrated fruit juice and use that to cut your spirit and then allow to mingle for several days or weeks. That time does wonders for the smoothness of your booze. I can attest this is how I perfected the best apple pie you've ever had while holding out a heady 80 proof.
- Chip N Dale
I have had great success with dehydrated apples.
'never eat the fruit in the jar. )'.
Throw the fruit in the next wash before distilling to recover some of the alcohol? Probably not enough to make it really worth while, but, you have got to throw it somewhere....
- Swedish Pride
yeah apple works, unless a week in a jar smoothened it out when a year on oak did not
Don't be a dick
Yes! Dehydrated fruit is awesome- I made an "apple pie bitters" using apple skins. the skin is actually what holds a majority of an apple's flavor. That's not to say you can't get delicious results with fresh - just account for the addition of h20 and a loss of alcohol.
- Jimy Dee
What a very interesting thread.
