Jimbo's easy 1/2barrel Wheated Bourbon and Gumballhead
Jimbo
Master Distiller
Re: Jimbo's easy 1/2barrel Wheated Bourbon and Gumballhead
Post by Jimbo » Sat Oct 20, 2018 1:54 pm
First damn snow of the season, that means its whiskey fixin season! Brewed up a batch today, here's how it went down, with all the details, hope it helps somebody. Cheers friends. -Jimbo
- 11;30AM - Fired up the pots of water. About 29-30 gallons in 2 half barrel keggles. RO water + 2 tsp Gypsum + 2 tsp Epson salts + 1 tsp calcium carbonate.
- 12;45PM - Water on 50 lbs cornmeal, near boiling. Add 60 ml SebMalt HT enzyme. stirring with drill mounted bucket stirrer (see pic). 185F (barrel wrapped in quilt)
- 3;00PM - Stirring every 20 min or so. Gravity at 15.8 brix, 1.0655. 154F. Mixed in 60 ml Sebsuper enzyme.
- 3:30PM - 149F, 16.2 Brix, 1.067 Added 17 Lbs Wheat malt (25% of grain bill), put through the roller mill twice. Mash temp 146 after malt add. (target is 145-148)
- 4:30PM - 141F, 18.8 brix, 1.0785, Cooled to pitch temp with bigass wort chiller. Pitched 1/2 qt US-05 taken off a recent batch of beer.
This is my standard protocol now. I shoot for 10%. If this batch hits 1.005 I'll be at 9.6%, if it hits 1.000 Ill be at 10.2% ABV. My mash temp was good so expecting 1.000 or close. Ill post up again in a week after ferment is done and Im runnin the flute.
Cheers.
Jimbo
Master Distiller
Post by Jimbo » Thu Nov 01, 2018 6:17 pm
Step 2, squeezing it out. 12 days fermenting, longer than I like, but was damn busy, or damn tired, or both. usually go a week.
67 lbs of grain turned into 32 lbs of squeezed out grain. Use my hands for most of it, and the mop ringer (new, and sterilized good with starsan) for the last bits. Took about 1 hour.
Got 26 gallons out at 1.003, 9.76% ABV. (29 gal in) Was a very sweet mash, nothing sour at all about this lot. It will settle till Sunday when I will have time to run it.
3 gallons left on the grain means 24 of that 32 lbs is liquid. So 67 lbs of dry grain turned into 8 dry lbs of spent grain. Id say the enzymes and yeasties did good.
It feels damn good to be makin whiskey again. No gumball with this, I have 2 more runs to do like this to fill a 10g new oak barrel. That'l be enough work.
Cheers,
Jimbo
TDick
Post by TDick » Thu Nov 01, 2018 10:16 pm
Jimbo wrote:\
Brewed up a batch today, here's how it went down:
50 lbs cornmeal
17 Lbs Wheat malt (25% of grain bill)[/b], put through the roller mill twice.
Curious, what made you decide to leave off the barley malt?
Is this the first time you've done it?
Jimbo
Master Distiller
Post by Jimbo » Fri Nov 02, 2018 5:52 am
Bourbon needs to be mostly corn. At least 51%. This is a wheated bourbon, so the part thats not corn should be primarily wheat. If its all wheat malt, all the better. Barley malt is optional (but will affect the flavor profile).
Jimbo
Master Distiller
Post by Jimbo » Sun Nov 04, 2018 3:25 pm
OK did the run today. I forgot how much I love this flute!
24 gal 9.75% wash poured off the top of those 4 buckets below. 1.75gal thick yeast settled, combined across the buckets.
9 qts keep at 80% average. Thats 11.6 quarts watered down to 62% for the barrel. Running feints through the next runs should put me right at 10 gallons to fill the barrel with 3 runs like this.
The sweet spot where this 3 plate flute really wants to run is 82% through the hearts at 176-178 head temperature, all day long. Took some work to keep it as close to 80% as possible adjusting heat and defleg water.
Also got 5 quarts of feints at 50+% (heads+tails) and 1 pint fores for the fire pit. I tune the defleg way back for the tails run, the plates stay flooded, but the head temp shoots up to 190's and the distillate drops to 50's %
Oldvine Zin
Post by Oldvine Zin » Sun Nov 04, 2018 5:53 pm
Jimbo wrote:OK did the run today. I forgot how much I love this flute!
Is that the one that Corene built?
Jimbo
Master Distiller
Post by Jimbo » Mon Nov 05, 2018 5:34 am
Yes, fabricator extraordinaire.
nuncaquite
Post by nuncaquite » Mon Nov 05, 2018 1:30 pm
I got to give it to you guys that go AG to this extent, you are artist, I respect that.
I usually do a 5 gallon Booner's, mop bucket, split it between two--5 gallon buckets and add a bag of sugar to the each.
Add a bag of sugar to the sparge, and mop bucket again when it ferments.
The sparge does do a disappearing act once fermented. Kinda shocking how little ends up in the bottom of the bucket once the
yeast works on it.
school
Post by school » Mon Nov 12, 2018 7:05 pm
Jimbo, would you have used those enzymes if you were using barley for this recipe?
Jimbo
Master Distiller
Post by Jimbo » Tue Nov 13, 2018 7:30 pm
school wrote:Jimbo, would you have used those enzymes if you were using barley for this recipe?
School, Malted Wheat has a higher diastatic power (enzyme juju) than malted Barley. This recipe would work fine without any enzymes, Ive made it that way plenty. I use the enzymes for convenience. The low temp ones are really optional but the high temp ones sure make life a truckload easier by working on the corn right away while its cooking on the boiling water. Without them its gets pretty thick while youre waiting for it to get to temp for the malt :tired:
Was down squeezin barley wash out of the grain tonight. Crazy ass dog likes barley wine, licking up everythign I splashed on the floor. Damn alcy dachshund.
Jimbo
Master Distiller
Post by Jimbo » Sat Nov 17, 2018 1:50 pm
Well shit, 3 batches didnt fill the barrel. (see first batch details just below from a couple weeks ago) Total grain bill 150 lbs corn meal and 50 lbs wheat malt. Put 8.9 gallons in the barrel at 62%. Gotta go get another damn bag of corn meal and more wheat malt. Thats ok will give me some extra aging on glass for top up after the angels tie one on. Barrel is a 10g new Barrel Mill barrel Char 3.
Did 3 still runs today, 2 bourbon wash runs and an all feints run using the feints from all 3 bourbon runs (first run details below). 24 gallon ea on the 3 runs. Then drained out half the backset on the last run and added 3 1/2 gallons of feints and ran again.
This barrel will be ready to tap XMAS of 2020.
Cheers
StuNY
Post by StuNY » Wed Mar 20, 2019 9:24 am
Well, I went ahead and made the gumballhead at last after feeling bad throwing all those grains into the compost. I stripped everything last weekend in my pot still, then debated how to finish it off. Reading through all the posts again it seemed it wouldn't quite be as good as the original bourbon for sipping neat and that is how I drink my whisky. Then realized that I was out of vodka from my sugar wash runs so maybe run it to be more of a vodka in my reflux still instead of the pot still. Need something to drink while I am waiting out all the Whisky and Bourbon batches on oak! I was able to keep it close to 95 abv throughout the run, so was feeling a little worried that I had stripped out all the flavor.
Well, have to say it is the best damn vodka I ever tasted! The hint of corn gave it a smooth sweetness that made me go back and check the ABV three times- thought I had watered it down too much in bottling. Nope- still at 43% abv- hard to believe! The Rye (used instead of wheat for the bourbon) gave just a hint of flavor- not exactly spicy just a bit of a complex taste together with the malted barley. Huge hit with the wife too- she was tiring of the "we have to wait at least 6 months to drink all this" line with my other batches!
When I was squeezing out the grains in the mesh bag after fermenting I remember thinking- "well, this is the last time I am doing this one" haha... felt like too much work vs. my usual straight sugar washes. It is going to be my only vodka now going forward. Works out great that I have constant batches of various bourbon/whiskys going so always a second chance to use those grains, not to mention double use of a packet of US-05 yeast.
Thanks Jimbo!
Eddie Haskel
Post by Eddie Haskel » Wed Jul 31, 2019 9:02 am
I tried your ½ barrel bourbon/gumballhead the other day and thought it came out well. A couple of questions for next time. My mash only came out at about 6% . It started at 1.053 SG and I used 3 packs of US-05 along with yeast nutrient and about a 30 second shot of oxygen. It only got down to one % alcohol after letting it ferment for 10 days. I’m thinking that some SEBstar HTL and SEBamyl GL might help out. Do you use or recommend them? After squeezing out the grains things got very cloudy and even my low wines were a bit cloudy after the stripping runs. The spirit run came out well. I just finished squeezing the grains for the gumballhead. This time I remembered that I have a wine press!! (A down fall of getting old is forgetting shit) I must have got two to two and a half gallons using that press. So much easier than using your hands. Tried the nuking method and it tastes great. Can’t wait for a little age to get to it. Going to find a rum to do then another run of yours. I’m pretty new to this and just did my first batch of UJSSM back in May. I’m lucky enough to have meet the distilling goddess a while back and she has helped me out tons, including making my column and still.
Have a great day!
Eddie Haskel
Jimbo
Master Distiller
Post by Jimbo » Mon Aug 05, 2019 10:27 am
Hey guys, sounds good, congrats on your runs. I've been getting low on bourbon stocks until this new barrel is ready next year, so I started diluting my bourbon maybe 60/40 with the gumball (2013 batch) and its really nice. Nothing at all seems unbourbonlike about it. The other livers that help me filter my bourbon havent noticed anything astray and I havent volunteered my deceitful shenanigans. The gumballhead was on oak, and has some nice flavor now with age. Even by itself its a nice sipper. The 10 gal barrel is 8 months old now and really coming into its own. I started looting a fifth here and there. Its really nice. Them Barrel Mill barrels out of MN are really nice, really nice caramel and vanilla characters.
NeckStiller
Post by NeckStiller » Thu Aug 22, 2019 12:32 pm
Jimbo!! How are yah!
Where do you get the enzymes? I been looking and can't find a local source...thanks
frunobulax
Post by frunobulax » Thu Aug 22, 2019 2:35 pm
I think THESE Are what you are looking for. No, they are not usually available locally.
acfixer69
Post by acfixer69 » Thu Aug 22, 2019 2:40 pm
NeckStiller
Post by NeckStiller » Thu Aug 22, 2019 4:09 pm
Huge help! Thank you guys!
Nutz
Post by Nutz » Wed Jun 17, 2020 5:30 pm
Made this the other day! Thanks Jimbo. My second time making it. More delicious at 100 proof vs the 80 proof I did the first time! Highly recommend
kmmuellr
Post by kmmuellr » Thu Oct 29, 2020 12:27 pm
I'll be doing my first cleaning run and sacrificial run at some point very soon, so I'm reading the T&T recipes and this will be the first non-sugar wash for sure after I figure out the operation of the still I've built!
I've been a brewer since 1996, so its been wonderful reading this whole thread and getting Jimbo's and other's input on the fermentation and using AG for distilling. Quick question on fermentation; since its not a sanitary fermentation, do you keep the fermenters in the same location as your beer fermentation, or do you keep it separate (like I do my sour beers)?
Thanks!
K
Edited to add: Does anyone use BIAB for this or any other AG mash/wash? I'm thinking of putting my bag in an electric keggle, mash in with the corn and cover. Add malt, etc.... Once fermentation is complete, pull the bag (pulley above keggle), squeeze, settle, and transfer to the still for a run, or into glass for further clarification if needed.
Put grain bag back into keggle, mix backset and sugar in separate bucket, add to keggle, rinse and repeat.
Any reason this would not work? I've never mashed w/ this much corn, so unknown how it would react in the bag. A malt mash would be no problem with this method.
