Birdwatchers sugar wash recipe
Re: Birdwatchers sugar wash recipe
What would be the recipe for the birdwatchers sugar mash scales to 5 gallons. Sorry if this has been answered here but it would take a while looking through q5r pages of this thread. Thanks
- Danespirit
Divide everything with 4,2
Personally, I cut back on the tomato paste and use some spent yeast as nutrient, a B-vitamin pill is also added (one for every ten liters).
It's up to you if you will follow the original recipe, or take up my practice...the original is a tried and true..
5 US gallon (liquid) are 3,78 L x 5= 18,9 L
80L divided by 18,9 L = 4,23
Edited for type error.
Have you been here?bigredgrizzly wrote:What would be the recipe for the birdwatchers sugar mash scales to 5 gallons. Sorry if this has been answered here but it would take a while looking through q5r pages of this thread. Thanks
http://shuggo.com/birdwatchers/
Birdwatchers ingredients calculator: https://birdwatchers.info/
Thanks Undies. I will check it outUndies wrote:Have you been here?bigredgrizzly wrote:What would be the recipe for the birdwatchers sugar mash scales to 5 gallons. Sorry if this has been answered here but it would take a while looking through q5r pages of this thread. Thanks
Well I put 2 25 liter batches on 7 days ago. One was all white sugar and the other was around 1.5 kg of molasses and the rest white sugar. The SG of both was 1.075. I checked today and the molasses one has no bubbles on top and SG is 1.01. The white sugar one has bubbles in top and the SG is 1.01. The temp has been around 20-22 degrees. Should I wait it out for 14 days and see what it reads? Is that about normal SG after 7 days?
- der wo
20-22 is cold for bakers yeast. It should go to 0.990 or less. But at this temp I think it will need 3-4 weeks for that.
Ok. I made it through 22 pages...
Q: What inherent problems may I have if I do a 200 liter wash?
Q: My barrel is a "55gallon" food barrel (208.2 liter), I'm just assuming here but my guess is that it actually will hold slightly more than labeled, so does that leave enough head space?
I would plan for at least a 10% ulage. If not, you likely will have a sticky mess.UnSub wrote:Ok. I made it through 22 pages...
Now, back to reading...you've got another 30 to go!
30?'s? Nah. I just figured I'd ask someone who has done a 200ltr wash. Weather here has been up and down, not sure where I should start it but; wth- I'll just set it on some foam in the garage and see what happens..
done lots. biggest risk is alcoholism. leave 12" of headspace in the barrel or buy a mop.UnSub wrote:I just figured I'd ask someone who has done a 200ltr wash.
now i drink for evil.
Large ferments can create quite a bit of heat, so have a target temperature range and try to keep within it. I adjust the amount of insulation almost daily for the first few days and often have a fan plugged into the same controller I use for heating.
Any reason this won't be a good starting recipe? (It's a copy/modify/paste)
My recipe for an 160 liter wash. Ingredients as follows:
6 cups/48oz tomato paste
Juice 6 lemons
Approx. 36 kg (80lbs) sugar
80g RedStar DADY
water (municipal)
Procedure:
Carefully mix paste, juice, say 14 kg (30 lbs) sugar with 60 liters (15 gallons) water at 30C (90f). I plan to heat the water in 2 batches of the 15.5g boiler and transfer it to the 55g barrel and add the sugar, stirring it in the barrel with a maximum sugar content of abt 80lbs
I'm aiming for 1.06
Carefully add water and sugar to bring mixture to 160 liter (42gallonish), WITH A SG 1.06. Temperature of finished mixture should be 30C-35C (85f-95f)to start.
I should now have 160 liters(42gallons) of mixed ingredients.
Carefully sprinkle 80 grams of DADY over surface, Place cover loosely.
My food grade barrel has an inkbird control with a 300w aquarium heater and a squirrel cage fan for wash temp control and a small recirculating pump. I have it set for 80f, heat on at 78f,, cooling on at 82f.
I don't plan to check the gravity aside from OG/FG unless there appears to be an issue.
I don't plan to stir at all.
Ideally, I will reach an FG of .995 in a week or so.
Sound about right?
-Is that a sufficient amount of yeast?
-would I benefit from peters 20/20/20 or Epsom salt?
-it doesn't look like there is generally a ph issue so I'm not too concerned about that.
I appreciate any input offered:)
Regards
Juice 6 lemons
80g RedStar DADY
water (municipal)
Procedure:
I'm aiming for 1.06
Sound about right?
Regards
Check the pH before adding acid/lemon juice to any sugar head. Sometimes they don't need any.
If it doesn't go to completion quickly, you may have pH problems. I add a few large clam shells to act as a buffer and then keep an eye on the pH.
Aerate the water or the wash.
I just had to join up and say thank you to Birdwatcher, I just cant believe how pure tasting your recipe is especially coming from that nasty still spirits potion.
The recipe tastes like a cross between Vodka and Sambuca minus the overwhelming sweetness, I love it but ironically I hate Vodka and Sambuca
I was getting into using wood staves to make my scotch and liked it much more than the mixing kits (or chivas for that matter) but now I have tried it with only water added Ive kind of gone of the wood staves, especially in summer, this is a refreshing drop.
I cant believe how much money I have been wasting to drink what tastes like poison compared to the birdwatcher recipe after distilling.
My pocket thanks you, my taste buds thank you and I thank you
oh, has anyone by chance found a way to speed the recipe up?
my only criticism really......I know I know, you cant rush good art.
- Haus
- Location: When you get to the fork in the road, take it
You could take the off-set approach. Stagger out two or three ferments over a three or four day intervals. Then one will always be near ready or ready when you are and not mess with the recipe.jedics wrote:
you can lead a horse to water but it's hard as hell to drown it
Yeah, easy. Get a bigger fermenter.jedics wrote:oh, has anyone by chance found a way to speed the recipe up?
My wash is at a ph of 4.1. SG 1.065. Temp is at 68*f.
I'm guessing I need the ph to be higher (like 5.5ish) and temp to be up to 80f or so before I pitch yeast?. A little direction if anyone can please..:-/
(-edit: digital ph meter that I have used a few times in pools and seems to be calibrated)
I am not sure of exact gallons but it's about 40 and only added 60# of inverted sugars- I thought for sure I'd need closer to 70 to get to 1.06.... I'm sure I missed something...
sg seems accurate for about 40 gal. there is a calc by Rad on the parent site that will confirm for you.
i'd be a bit concerned with that Ph for starting at. may stall in a day or two. consider some kind of buffer or alk up a bit.
i ferment with bakers at 72, just take a couple more days.
I would definitely get that pH higher so your ferment doesn't stall early on...UnSub wrote:My wash is at a ph of 4.1. SG 1.065. Temp is at 68*f.
Posted the same time as HDNB...
Sodium bicarb? I do have shells (not crushed).
Heater is on- was going to wait until 75-80 to pitch yeast? Sound appropriate?
(Not sure how critical the wash temp is- plan to just put ADY on top)
HDNB- I used the birdwatchers calc and I recall it saying closer to #72 for 40gallons.. Doesn't matter to me as long as it finishes fair.
Shells don't need to be crushed... Either would work and both with be better than baking soda... Also, shells have more of a buffer effect than sodium carbonate...
Baking soda is sodium bicarbonate Rad?
Correct...UnSub wrote:Baking soda is sodium bicarbonate Rad?
Sorry, thought you meant sod. bicarb or shells were better.rad14701 wrote:Either would work and both with be better than baking soda...
What about temp... Let it come up would be best?
Personally, I like pitching at a warmer temperature and then letting the wash establish it's own temperature... I've pitched yeast as high as 95F - 115F without issues but closer to 90F - 95F is my preference...UnSub wrote:Sorry, thought you meant sod. bicarb or shells were better.rad14701 wrote:Either would work and both with be better than baking soda...
Can you pot distill this recipe for a final product? Say, a double or triple distilled?
13.5g/50L keg
26g 4" stripping still
5500watts of fury
5500watts of fury
Yes...Be your own judge... Single, double, triple... Or do stripping runs followed by one big spirit run... You have options...The Booze Pipe wrote:Can you pot distill this recipe for a final product? Say, a double or triple distilled?
- der wo
Yes. A great plus for triple distillation is, that the diluting between the distillations rises much the cleaning effect of the distillations.The Booze Pipe wrote:Can you pot distill this recipe for a final product? Say, a double or triple distilled?
Hi, I'm extremely new to all this and have been just using commercial yeast packages and want to try this birdwatchers wash, I'm wondering what the addition of lemon juice is actually for.
Apologies if I'm asking a really dumb question but I'm trying to understand the process
Thanks in advance for your help
This forum has been providing me with a wealth of information but there is so much to learn
Cheers
Greg - NZ
Cheers
Greg - NZ
Hey Greg. Welcome!
No dumb questions, just dumb answers.
I believe the lemon juice is to adjust to the correct ph. IE more acidic to keep the yeast all nice and happy.
