Pintoshine's Fast Fermenting Molasses Wash
punkin
Master Distiller
Re: Pintoshine's Fast Fermenting Molasses Wash
Post by punkin » Sat Aug 09, 2008 11:02 am
I've understood that you're using this recipe for your neutrals, Pint. Do you just strip it once then run it through a column? Is there anything else that has to be done to remove flavours?
I can get mollasses free, and it sounds like it'll be a good source of sugar in a case like this, so long as the flavour doesn't come through :wink:
pintoshine
Post by pintoshine » Sat Aug 09, 2008 2:48 pm
Yes because you will be much happier with the results if you do. Since I use two pot stills with doublers I get about a xxx with two runs as far as comparable taste is concerned. Believe me you will not lose any of the good stuff but will remove lots of the bad. This is providing you make good conservative cuts. You can find several stickies about cuts in the other forums.
punkin
Master Distiller
Post by punkin » Sat Aug 09, 2008 10:20 pm
Thanks, i'll go and see if i can learn some stuff about cuts :wink:
alice
Post by alice » Sat Aug 09, 2008 10:52 pm
punkin wrote:Thanks, i'll go and see if i can learn some stuff about cuts :wink:
LOL!! Methinks Pint was answering Wilbl777's query re double distilling rather than you, Punkin.
punkin
Master Distiller
Post by punkin » Sun Aug 10, 2008 12:40 am
:oops: Oh...
WasHeIgnoringMeThenPunkin
pintoshine
Post by pintoshine » Sun Aug 10, 2008 4:58 am
Punkin is definitely having a bit of fun with us. Strewth? :wink:
punkin
Master Distiller
Post by punkin » Sun Aug 10, 2008 11:13 am
Punkin is in deadly eanest about the mollasses question. My mate told me at their last stocktake they were 3 tonnes over with the amount of mollasses they should have had stored.
They hate being over as much as under, so if i can get drums for nothing, it'd make a very good plan to use your recipe Pint, then reduce it by stripping in my potstill and then run it through my new Vapour Management column. Just wanting to know if it came out as neutral tasting and what else i'd have to do (assume the baking soda rest for the low wines).
NotThatI'veGotANeedForMuchNeutralPunkin
alice
Post by alice » Sun Aug 10, 2008 3:08 pm
Bloody hell! What's a tonne of molasses worth?
HookLine
Post by HookLine » Sun Aug 10, 2008 4:00 pm
IIRC, some commercial vodka distilleries use molasses as part of their feedstock.
Be safe.
Be discreet.
And have fun.
StabbyJoe
Post by StabbyJoe » Sun Aug 10, 2008 5:01 pm
Take it either way man!
I'm sure you can make a nice neutral, but if all else fails... think about the quantity of rum THAT MUCH molasses can make!
You'd have enough for you and your friends to drink rum until... well a bloody long time at least.
*drool*
Never fully understood the use of the word strewth :lol:
pintoshine
Post by pintoshine » Sun Aug 10, 2008 7:00 pm
If I strip it first and then use my column well balanced and slow, I can make an exceptional neutral. It yields about 60% with the heads and tail taking the rest. I never use baking soda though. No need with the tight cuts. Hell even if it made a extra light rum, that mixes great with so many things.
punkin
Master Distiller
Post by punkin » Mon Aug 11, 2008 11:36 am
Thanks Pint. Dunno exactly what i'll be using neutral for yet (aside from learning how to make it) but probably for macerations and for flavoured vodkas.
Just looking for cheap sources of sugar, and i think this one will work.
ublong
Post by ublong » Tue Aug 12, 2008 1:05 am
Hey Punkin if you cant use all that molassus I will bring the ute and trailer over and relieve you of a couple of drums LOL
Bullshit Baffels Brains
Buggers Science
And Rules The World.............
All Australian Boys Need a Shed
GreenEarth
Post by GreenEarth » Mon Sep 15, 2008 10:57 am
Your fast fermenting molasses wash, worked Great! Thanks! :D
For A Better Earth, Or A Better Buzz!
Mr Clean
Post by Mr Clean » Thu Oct 23, 2008 4:06 am
You will notice I mentioned rain water in this discussion a number of times. I have found that clean rain water has some sort of magical property about it that causes things to ferment frantically. It is slightly carbonated and mildly acidic once it sets in the barrel a day or two. It is very nice if you have a clean source because it requires no dechlorination and has no ground contaminants.
Perhaps the reason the rainwater is so helpful is because it usually contains acid, i.e. acid rain, which used to be loaded with sulphur dioxide unless they've managed to stop that phenomenon.
4" 10 plate column
chefbootleg15
Post by chefbootleg15 » Sun Nov 30, 2008 3:46 pm
i have acesss to the scimings from a sugarcane cooking
can this be used in place of molases or in any other way to make rum?
punkin
Master Distiller
Post by punkin » Sun Nov 30, 2008 10:33 pm
chefbootleg15 wrote:i have acesss to the scimings from a sugarcane cooking
Is it sugar (is it secret is it safe){sorymadlordoftheringsmoment}, if so it is very usable and very vauable if it's free....
Just find a use for it...
MaybeSendItToMePunkin
Julwit
Post by Julwit » Thu May 21, 2009 3:01 pm
Since I'm totally new to this I need ask most likely very silly question:
Can I run this mash through reflux still or should I remove and copper pads from my column and run it as a pot still?
Julwit
Tater
Post by Tater » Thu May 21, 2009 5:34 pm
Would depend on what your looking to make wouldn't it?Vodka or rum
minime
Post by minime » Thu May 21, 2009 6:36 pm
Julwit wrote:Can I run this mash through reflux still or should I remove and copper pads from my column and run it as a pot still?
Julwit
Molasses carries flavor quite nicely on a column, scrubbers or not. If you run it @95% from this recipe it will be highly flavored and an excellent base for blended rum or to serve as white rum. Both Pinto's recipe and Pugi's work beautifully on a packed column for high quality rum.
Good luck on your venture.
Mr.Spooky
Post by Mr.Spooky » Thu May 28, 2009 5:15 pm
i just gotta say,,, i love this recipe. even though i sub brown sugar for the molasses, i follow everything else to the T... it works well for me.
thanks
Dyce51
Post by Dyce51 » Sat Jun 27, 2009 2:13 pm
hey Pintoshine I am going to try this recipe looks like you got great results from it. You said you got 2.3 gallons finished of 100 proof. Did you lower the proof? and what was the proof before you did and how much water did you add?
I just collected about 20 gallons of rain water.
ibfestus
Post by ibfestus » Fri Aug 14, 2009 8:52 am
You said you use 2 carboys. Would it work putting the whole 13 gallons in a BOP and letting it work off or is that too much volume? :?: :?:
Dnderhead
Post by Dnderhead » Fri Aug 14, 2009 10:55 am
it whould work "if " you have the head space as some wash foam and molasses is one.
a 20-25 gallon fermenter whould be a better choice
ibfestus
Post by ibfestus » Fri Aug 14, 2009 12:08 pm
I put it all in Rubbermaid Brute 30+ gal waste bin. I followed the recipe (I believe to the letter) except I used untreated well water instead of rain water. I have big hopes for the results. Boy that paint stirrer sure does the job. I had trouble keeping my cheap assed drill at a low enough speed to keep molasses off the ceiling. :oops: :lol:
ibfestus
Post by ibfestus » Mon Aug 17, 2009 1:57 pm
I understand that good hydrometer readings are hard to get from a molasses wash. I pitched the Red Star bakers yeast on Thursday afternoon. Within an hour it was already bubbling and for the next 36 hours or so it fermented like crazy. By Sunday the ferment had slowed a lot. Today it is still bubbling but very slowly. I used my new alcohol meter and the wash has a negative reading. I stuck my hydrometer in it and it reads 1.04. The wash doesn't taste bad and looks kinda like strong coffee with just a bit of creamer. I can neither smell nor taste alcohol or sweetness.
Any thoughts here?? :?:
Master Distiller
Post by rad14701 » Mon Aug 17, 2009 4:03 pm
ibfestus, let it go until it completely stops... No need to rush... Should be done within a day or two...
Master Distiller
Post by The Baker » Mon Aug 17, 2009 6:03 pm
StabbyJoe wrote:Take it either way man!
snip
I have heard it is from the Cockney expression, Gawd's truth. Probably originally something like, 'Really? God's truth?!'
Common in older Australian idiom, we got a lot of stuff from the Cockneys; probably a lot of them amongst our original convict settlers.
As to the use of it, it is just an ejaculation, like 'Really? that's amazing!', 'You don't say!', and so on; only very much in the vernacular/slang.
Pronounced as an ejaculation, NOT a question
HookLine
Post by HookLine » Mon Aug 17, 2009 6:57 pm
Strewth is also used as a frustrated exclamation. Kinda equivalent to...
Oh for fuck's sake, you've got to be kidding me!
Be safe.
Be discreet.
And have fun.
Master Distiller
Post by The Baker » Mon Aug 17, 2009 7:23 pm
HookLine wrote:Strewth is also used as a frustrated exclamation. Kinda equivalent to...
Like a lot of these sayings, the meaning varies pretty much with the way you say it!
