Oat,Wheat,Rye Whiskey/whisky
Re: Oat,Wheat,Rye Whiskey/whisky
Postby Anode Effect » Mon Mar 20, 2017 9:38 am
Is the wheat white or red?
Anode Effect
Postby Jimbo » Mon Mar 20, 2017 10:09 am
Nice recipe Bentstick, my experience is these multi grains are always delicious. Wheat Oats and Rye giving you Sweet, smooth and spicy/aroma, in that order ;)
Cheers
Jimbo
Master Distiller
Postby bentstick » Mon Mar 20, 2017 1:39 pm
Anode Effect wrote:Is the wheat white or red?
Unmalted wheat is Red winter wheat crops,the malted wheat is white wheat Rahar brand!
It is what you make it
bentstick
Postby bentstick » Mon Mar 20, 2017 1:42 pm
Jimbo wrote:Nice recipe Bentstick, my experience is these multi grains are always delicious. Wheat Oats and Rye giving you Sweet, smooth and spicy/aroma, in that order ;)
Cheers
:thumbup: jimbo it is a very smooth drop,almost to smooth!
bentstick
Postby Jimbo » Mon Mar 20, 2017 2:00 pm
haha, thats how I felt about an all oats one I did. You might have been overly conservative on the cuts? Do you still have your cuts jars? You could experiment with a touch of late heads to get some more fruit/spice and spank in there.
Jimbo
Master Distiller
Postby Anode Effect » Tue Mar 21, 2017 1:05 am
Thanks! I'm putting this on the to do list.
Anode Effect
Postby Tater » Fri Mar 24, 2017 1:11 pm
Ive done close to this recipe and am now waiting on it to air out to temper. I used 15 lbs malt and 10 unmalted in wheat and same in rye. Used rolled oats and Nottingham ale yeast.So close but not exact.Just strained the mash didn't press it getting a usable wash of 27 gallons. let settle real well and kept 25 gallons from that. Stripped almost 4 gallons outta 13 gallons .Put 3 gallons mash/wash in thumper and the stripped with what was left and ran that.Started out at 150 proof and at qt jar 11 had dropped to 75 proof where I quit. Ran out another 3 qts to mix with 2 gallons spent wash to put in thumper for oats sugar head wash.Will air out for bit then taste and blend and proof .
PLEASE READ THIS FORUMS RULES AND THESES Links: http://homedistiller.org and New Distiller Reading Lounge I use a pot still
Tater
Postby Tater » Fri Mar 24, 2017 1:16 pm
Proofed to 95 abv or so .Tossed a little more on heads then I figured on but also went further into tails .However all who tasted have gave it a good nod . Will pass it around at next meet to see what my peers think .
Tater
Postby Hank Reardon » Sat Apr 15, 2017 9:48 pm
just pitched round 4. 1.058 OG. If it hasn't been said enough, this is a product people should make. It is that good.
Hank Reardon
Postby acfixer69 » Sun Apr 16, 2017 2:12 pm
Tater wrote:Proofed to 95 abv or so .Tossed a little more on heads then I figured on but also went further into tails .However all who tasted have gave it a good nod . Will pass it around at next meet to see what my peers think .
I m looking forward to a snort there tater. Looking for a side by side. I'm figgerin both are great with the still making the difference. 8)
AC
acfixer69
Postby bentstick » Mon Apr 17, 2017 1:01 pm
I will have some also that was put on oak a while to try out! Lil under 2 weeks to go
bentstick
Postby Swedish Pride » Wed Apr 26, 2017 4:01 am
wouldn't mind a comparison on the 3 of them myself, but I have to make due with putting my own mash on. Will have to put it in the backlog of mashes to do :)
Don't be a dick
Swedish Pride
Postby Jimy Dee » Sat Apr 29, 2017 12:12 pm
Tater wrote:Ive done close to this recipe and am now waiting on it to air out to temper. I used 15 lbs malt and 10 unmalted in wheat and same in rye. Used rolled oats and Nottingham ale yeast.So close but not exact.Just strained the mash didn't press it getting a usable wash of 27 gallons. let settle real well and kept 25 gallons from that. Stripped almost 4 gallons outta 13 gallons .Put 3 gallons mash/wash in thumper and the stripped with what was left and ran that.Started out at 150 proof and at qt jar 11 had dropped to 75 proof where I quit. Ran out another 3 qts to mix with 2 gallons spent wash to put in thumper for oats sugar head wash.Will air out for bit then taste and blend and proof .
As a novice I am wondering if this system by Tater is just pure gold dust. If my analysis of this is correct, is it a case of Tater having 25 gallons wort
He then took 13 gallons of wort and stripped it (resulted in 4 gallons strip)
Then he took 3 gallons of wort and add this to the 4 gallons strip and put this into his thumper.
He then put the remaining wort into pot and ran that with the thumper.
If the latter is correct could one further distill this system down to
Strip 50% wort, and add this strip to 10 to 15% of more wort and put all into thumper
Put remaining wort in pot and run it with the thumper. Hey presto - finished product ?
To those experienced this might seem to be obvious, but to a novice like me it seems to be a great way of going from wort to strip to a full spirit run with just one batch of wort.
Please correct me if my analysis is incorrect, and if there are better ways of handling one batch of wort please let us novices know.
Thanks again. Jim
Jimy Dee
Postby Hank Reardon » Sat Apr 29, 2017 2:52 pm
Opened my fermenter today and this is what I saw. I wonder how it will change the taste...
Hank Reardon
Postby Pikey » Sat Apr 29, 2017 3:54 pm
What id that ? :shock:
Pikey
Postby thecroweater » Sat Apr 29, 2017 9:27 pm
its a lactic infection, it will change it from a sweet mash to sour mash which some guys really like and others not so much. You will probably want to run that as soon as fermenting is done.
thecroweater
Postby Hank Reardon » Sat Apr 29, 2017 9:36 pm
Running tomorrow crow. No worries.
Hank Reardon
Postby bentstick » Mon May 01, 2017 9:52 pm
Hank Reardon wrote:Opened my fermenter today and this is what I saw. I wonder how it will change the taste...
It happens Hank! And makes it that much better IMO!
bentstick
Postby bentstick » Mon May 01, 2017 9:53 pm
Pikey wrote:What id that ? :shock:
If not lacto what do you see?
bentstick
Previous
Return to Tried and True Recipes
Who is online
