Honey Bear Bourbon
ShineonCrazyDiamond
Re: Honey Bear Bourbon
Post by ShineonCrazyDiamond » Fri Nov 30, 2018 11:19 am
OtisT wrote:SCD, have you ( or anyone else for that matter) tried this recipe with toasted oats? My next batch of HBB will be using toasted oats, and I’m excited to know if I can taste a difference.
Otis
Yes! Bayou shiner had some of my HBB and CROW bourbon at last years meet up. He went back and made hbb but toasted the oats. He sent it to us for this year's meet up. It was wonderful, and exactly what you would expect from combining the 2 recipes. Try it!
Shine on you crazy diamond."
Irishgnome
Post by Irishgnome » Wed Dec 05, 2018 1:56 pm
SCD,
I’m at work and decide to snack on an apple and see the sticker on the apple says Honey Bear. My mouth starts to water and now I can’t wait till 5:00 to get out of here and pour myself a glass of my honey bear that’s just about to turn six months. :ebiggrin:
Then I start thinking about adding some apple flavor or aging in a cider cask. Anyone tried this? Or aged on Applewood? Sounds like it could be really tasty.
Cheers,
Irish
Candy is dandy but liquor is quicker. - Ogden Nash
"if at first you don't succeed, try try try again"
Oldvine Zin
Post by Oldvine Zin » Tue Dec 11, 2018 7:36 pm
Just put into bottle a 2 year old 1 gal barrel of HBB. Sad that the angels took half of it but what I did get to keep is fantastic!! I have a couple 5 gal barrels aging and looking forwards to tasting that batch.
thanks shine on for that recipe
OVZ
dcpac
Post by dcpac » Mon Dec 17, 2018 9:51 pm
With help from StillerBoy, Mars and others I am on my 6th large batch. Here is what I have ended up with that work best for me.
I boil 35 gallons of water with 1000mg potassium metabisulphite to remove chlorine/chloramine
- After adding the 35 gallons of boiling water to my wrapped 55 gallon drum I stir in 45lbs cornmeal with a mixer attached to a drill.
- After bout 30 minuets I check PH to make sure it is in the 5.6 – 6.5 range and below 190F, then add 16ml HTL.
- I leave alone expect for stirring every couple hours until the temp comes does to 156F.
- At 156F I add 4lb honey malt, 8lb white wheat malt, 8lb red wheat malt, 8lb pale malt which drops the temp to 153.
- I after about 30 minutes I check the PH to make sure it is about 4.8 and adjust with citric acid as needed, add 12ml SEBamyl-GL and stir every hour or so for 2 or 3 hours. I then remove the wrap from the drum and start a fan blowing on the drum.
- Once it has cooled to 80F I adjust PH to 5.0 and pitch 1 cup bakers yeast rehydrated in 2000ml of distilled water
- 24 hours after pitching I check PH and adjust to the 4.5 range (also have some pieces of marble in the drum which seem to help PH a little
Hope this helps someone that is trying a larger scale.
OtisT
Post by OtisT » Tue Dec 18, 2018 10:47 am
Irishgnome wrote:SCD,
Cheers,
Irish
Hi Irish. I have done some finishing of my HBB on Toasted Apple Wood, along with Plum and Cherry. I’m no expert at it, but I do like the results. I posted about the experience here: viewtopic.php?f=4&t=72255
In a nut shell: I let my HBB sit 11 months in the barrel. It was delicious, in my opinion. I toasted up some fruit wood sticks on two sides, almost half way through so it was like an Oreo (dark on the outside with a thin untoasted strip in the middle). I used a small amount of toasted fruitwood with the bourbon and vacuum soaked it twice over a 24 hour period then pulled the wood. I like the results of the Apple and Cherry. The Plum added some astringency to the drink and I am hoping time will mellow this.
Otis
Irishgnome
Post by Irishgnome » Tue Dec 18, 2018 11:04 am
Thanks Otis!
Just in time too, I just did a spirit run on some HBB last night. :thumbup:
I was hoping someone would respond soon, sitting on some cherry and apple wood right now.
I may need to pick up a vacuum system in the future. I just spent quite a bit on specialty grains a new 15 gallon barrel and I’m about to order some overpriced Mizunara Oak sticks.
Need to read through your thread again and decide how I’m going to split this run up for aging. Ever use fig tree, or quince tree wood?
Thanks Again!
Cheers,
Irish
OtisT
Post by OtisT » Tue Dec 18, 2018 11:19 am
Irishgnome wrote:. Ever use fig tree, or quince tree wood?
No. I have only used seasoned Apple, Cherry and Plum. I am interested is acquiring some nut woods soon to try out. Lots of Hazlenut trees around here. I’m not in Pecan country, but I hear that wood is great for spirits. Otis
Oldvine Zin
Post by Oldvine Zin » Tue Jan 01, 2019 1:19 pm
I'm starting the new year with mashing a big ol pot of HBB, just finished grinding all the grains and the house sure smells nice!
Happy new year
OVZ
Oldvine Zin
Post by Oldvine Zin » Fri Jan 04, 2019 8:30 am
This is my best HBB ferment to date :D
85 lbs of grain to 50ish gals of water brought me to 18 brix, pitched 4 packs of US 05 yeast and it's bubbling crazy.
I would like to thank SCD for this recipe and everyone else on this forum for all the great advice
Thank-you
OVZ
ShineonCrazyDiamond
Post by ShineonCrazyDiamond » Fri Jan 04, 2019 1:42 pm
You're most welcome. Happy new year friend.
Jpfeife
Post by Jpfeife » Tue Jan 08, 2019 10:08 am
started a batch with cornmeal and rolled oats 5 days ago. OG was 1.03. was bubbling away good for a few days. opened it up today to check it and the SG is 1.02 which i thought was weird but then took a temp reading and it was 105F. I had a brew belt around my ferment bucket. I used bakers yeast. If i take the brew belt off and let the temp of the mash go down will the yeast kick back in or did i kill them and need to repitch?
Longhairedcountryboy
Post by Longhairedcountryboy » Tue Jan 08, 2019 11:01 am
Jpfeife wrote:started a batch with cornmeal and rolled oats 5 days ago. OG was 1.03. was bubbling away good for a few days. opened it up today to check it and the SG is 1.02 which i thought was weird but then took a temp reading and it was 105F. I had a brew belt around my ferment bucket. I used bakers yeast. If i take the brew belt off and let the temp of the mash go down will the yeast kick back in or did i kill them and need to repitch?
I use Red Star brand bakers yeast. I've had ferments that ran in the low 100's the entire duration. They finished dry with no problems.
OtisT
Post by OtisT » Tue Jan 08, 2019 11:40 am
Hi Jpfeife. On a separate note, the next time you plan to make HBB you should pay attention to your conversion process and maybe ask for help before you start. If you followed the recipe, your OG should be near 1.07. If your OG reading was correct, you only got less than half of the sugar/alcohol out of your grains.
Otis
Oldvine Zin
Post by Oldvine Zin » Mon Feb 04, 2019 10:50 pm
Just tasted a bit of the HBB that I ran yesterday. Wow the middle hearts was unbelievable, almost didn't add that jar to the mix but knowing how good this will be after a couple of years in barrel it went into the mix. One more batch and then I'll have enough for another 5 gal barrel.
OVZ
jonnys_spirit
Post by jonnys_spirit » Wed Feb 06, 2019 2:43 am
Started up a batch of hbb with more oats than I used last time. I’m doing several batches and filling at least a small 10l barrel.
-jb
i make stuff i break stuff
water into whiskey into water
ShineonCrazyDiamond
Post by ShineonCrazyDiamond » Wed Feb 06, 2019 2:26 pm
Oldvine Zin wrote:Just tasted a bit of the HBB that I ran yesterday. Wow the middle hearts was unbelievable, almost didn't add that jar to the mix but knowing how good this will be after a couple of years in barrel it went into the mix. One more batch and then I'll have enough for another 5 gal barrel.
OVZ
:thumbup:
You know, it's been a long time since I had white honey bear. I knew I wanted to share the recipe after the first time I had that middle jar. I need to make some just for white.
Cheers.
Canuckwoods
Post by Canuckwoods » Fri Feb 08, 2019 1:40 pm
I'm on my umpteenth batch, today I used 1-minute oats as they were in the brewhouse from a batch of stout I did. The mash was light and mixed really well almost watery I checked my measurements and they were right on I thought I might have halved the cornmeal. Just an interesting observation.
OtisT
Post by OtisT » Fri Feb 08, 2019 3:39 pm
OVZ
:thumbup:
Cheers.
+1.
I have also gotten in the habit of saving the middle jar from my HBB and a few other recipies. It’s just too good to pass up, and I don’t think it impacts the barrel cut at all.
Full_moon
Post by Full_moon » Sat Feb 09, 2019 8:20 am
Going to try some rolled oats in my next hhb. Where do you source the oats. Super market in the breakfast food section? thanks :wave:
ShineonCrazyDiamond
Post by ShineonCrazyDiamond » Sat Feb 09, 2019 8:36 am
I either use those, or "rolled oats" from Tractor Supply (or grain supplier).
Canuckwoods
Post by Canuckwoods » Sun Feb 10, 2019 2:12 pm
Can this recipe be used to do a scotch? they have peated malt at my homebrew supply can I use that and if so what quantities?
acfixer69
Post by acfixer69 » Sun Feb 10, 2019 3:12 pm
Corn and scotch in the same sentence don't even sound right.
Canuckwoods
Post by Canuckwoods » Sun Feb 10, 2019 3:32 pm
That's what I thought.
dieselduo
Post by dieselduo » Sun Feb 10, 2019 3:50 pm
I've added peated malt many times and really like it.I call it bourbotch
ShineonCrazyDiamond
Post by ShineonCrazyDiamond » Sun Feb 10, 2019 4:02 pm
acfixer69 wrote:Corn and scotch in the same sentence don't even sound right.
Lol
jonnys_spirit
Post by jonnys_spirit » Mon Feb 11, 2019 4:13 am
Mash #2 done and pitched on this run. I used 20# corn meal, two large tubs of rolled oats, 2# honey malt, 2# raw torrfied red wheat, and 13gallons boiling water + backset. Oats and malt thru the grinder. Wrapped it in reflectix and let it drop to 150 over about 12h. Added ground malts - 2# each red wheat white wheat and golden promise malted barley. Also used liquid enzymes and og was just over 1070.
I’m planning several mashes for this winter lager run of hbb. The cellar is cool and the lager yeast keeps chugging away at the wort. I’m looking for a couple gallons of clean white hbb and at least three - five gallons barrelled. I’ve got my work cut out on this and as i top up my barrels and jugs i’ll move into rye mode and use this general process with added rye grains and some heavy rye bread plus a specialty malt or two.
I also re-use a portion of the spent grain and backset each generation and macerate feints in another portion of spent grains. Squeeze em into the next spirit run.
Thanks SOCD for the recipe!
-jonny
jonnys_spirit
Post by jonnys_spirit » Tue Feb 19, 2019 7:33 am
On this run - Mash #1 stripped - 12 gallons beer = 4 gallons low wines. Mash #2 AF complete & settling in the brute for one more week. Mash #3 mashed pitched and off to the races. I might strip #2 one day this week.
I harvested and washed about 750ml trub/sediment from Mash#1 and storing in the fridge in a wine bottle. I’ll use this saflager yeasties as a starter for each mash in this run. 9-12 mashes planned.
I reincorporate some spent mash (33%) from the last squeezing back into each new mash at pitch time to drop temp and just for fun too.
I take a day or two to bring the yeasties back out of dormancy and colonizing on a mini-mash that i prepare just for them before pitching into the brute.
First carboy of low wines smells the honey bear !!
Cheers,
-jonny
rollmeown
Post by rollmeown » Mon Mar 18, 2019 6:42 pm
Hello,
I posted in this thread last year. And I chickened out due to the fear of all grain mash so this year I'm back to try it again. I figure 2 pounds of grain per gallon 42 gallon total wash size. This is my upscaled grain bill for 42 gallons. Please let me know about any corrections or comments.
Thank you.
57 pounds ground corn. 68% corn
8 pounds red wheat malt
7 pounds White wheat malt. 20% wheat
8 pounds pale malt
4 pounds honey malt. 12% barley?
6 handfulls of oyster shells? Too much or not enough.
Is the pale malt and honey malt a barley grain?
Gonna make with 30 gallons boiling water to mash and 12 gallons to water to cool to pitching temps. 85°
Last year went with liquid enzymes had good converions due to a finer grind of corn (almost cornmeal) and grits. Was a good experience. Wasn't a fan of corn whiskey tasted like eating field corn.
Thanks again.
Truckinbutch
Post by Truckinbutch » Fri Mar 22, 2019 8:58 pm
I sipped 2 long drinks last week that I brought home from the last S3 gathering .
SCD's rendering is a mark for any stiller to shoot for .
I'm saving a sealed 'hand grenade' from 2 years back to share with GAflatwoods in early May .
Twisted Brick
Post by Twisted Brick » Sat Mar 23, 2019 12:47 pm
rollmeown wrote:Hello,
Thank you.
8 pounds pale malt
Last year went with liquid enzymes had good conversions due to a finer grind of corn (almost cornmeal) and grits. Was a good experience. Wasn't a fan of corn whiskey tasted like eating field corn.
Thanks again.
Sorry rollmeown, just came across your question. In case you haven't pulled the trigger yet, you want to observe the optimum temps of each of your grains. Your batch is large and should make a great drop, as long as you follow procedure. Read through this explanation and it'll help with understanding the process.
Yes, the honey and pale malt are from barley. The honey malt loses its enzymes with higher kilning temps, and do not contribute to overall DP.
Don't forget to take an SG and FG of your ferment. Good luck.
