Gerber
Master Distiller
Re: Gerber
Post by rad14701 » Sat Dec 03, 2016 2:54 pm
newbie1982 wrote:Hey rad if I'm going to do a 50 gallon batch do you think I need to scale everything up evenly?
Most everything except the yeast can be scaled up in linear fashion... I would also start reducing nutrients like Epsom Salt or fertilizer as the volume scales up... The Gerber, which is the primary nutrient and flavor component should be scaled normally...
newbie1982
Re: Gerber
Post by newbie1982 » Sat Dec 03, 2016 5:25 pm
Awesome thanks
stony183
Re: Gerber
Post by stony183 » Thu Dec 15, 2016 3:39 pm
Stonemull wrote:I know, I cant help myself. I hope I am not testing your patience much, I intend to be a contributor as well as a nuisance one day.
its my first wash, first still. I like to understand things and if this lot goes out to water the grass in the back paddock I can live with that and guarantee I will have learned a lot in the process.
personally, by sheer luck perhaps, it seems to be going swimmingly.
I have done this recipe about 100 times now and I've never had a ferment stall. I usually ferment in 36-48 hrs... I don't even check my SG or FG these days because if you do the exact same recipe everytime AFTER you have found the right one there is no need. I run mine in reflux mode and always get 92% on every single run!!!
Reason: removed unwanted advertisment
islander
Re: Gerber
Post by islander » Wed Oct 04, 2017 1:33 pm
Finally got my first drinkable run in! This recipe is extremely easy to follow and scale up, only hangup I had was the only greber cereal available was multi grain. I ran 10 gallons and finished with 2.75 gallons going from 150 proof down to 40 proof on my pot still. It took about 1 week to ferment in my basement at 70 degrees and used Red Star Distillers Yeast, starting SG was 1.078, PH was 4.7 after I adjusted it with citric acid. When you get to the middle of the run it's got a nice spicy note to it. Thanks for the recipe!
Nunyo
Re: Gerber
Post by Nunyo » Thu Mar 29, 2018 9:44 am
Rad, Thanks for your contributions here at HD and a big thanks for sharing your recipe. I've been lurking here for a couple years and just recently registered as I am finally about ready to do my first runs. I am thinking this will be my first wash to try which will be run through a 4" column still with 6 bubble plates and possibly an additional 12" extension packed with copper mesh with an aim at a high proof single pass neutral.
It was mentioned that the Gerber Barley flavored cereal was discontinued. I was looking on Amazon for Gerber cereal and came across this Gerber Single Grain Barley Cereal. Is this what you were using back when you stated this thread?
https://www.amazon.com/Gerber-Baby-Cere ... aby+cereal" onclick="window.open(this.href);return false;" rel="nofollow
On that note, I've been reading this thread (as well as many others) to exhaustion. My plan is to mix up about 50 gallons on my first run. I know you said to scale the water, sugar & Gerber up linearly but to reduce the yeast, salt and nutrients. I've also noticed that your experimentation have resulted in some changes to your recipe that isn't really noted in the initial post. Most notably the occasional use of 30-10-10. I also noted that some have used lemon juice which you don't note in your original recipe and I am assuming the lemon is used in lieu of citric acid to reduce pH. My tap pH is around 8.0 - 8.5 depending on the day. Since I plan on making a large batch in a 55 gallon barrel and will run up 15 gallons of the wash at a time in my boiler, I am curious what you would suggest as a recipe for this volume given the years of experimentation you have done using this recipe. I will note that I really don't care if it takes 3-4 days vs 1 week for ferment but at the same time, 3-4 days would't be bad as I am sure I will be anxious. I will likely use the first several gallons as my sacrificial cleaning run. Any suggestions would be much appreciated!
Nunyo
Re: Gerber
Post by Nunyo » Fri Mar 30, 2018 4:04 pm
slief wrote:Rad, Thanks for your contributions here at HD and a big thanks for sharing your recipe. I've been lurking here for a couple years and just recently registered as I am finally about ready to do my first runs. I am thinking this will be my first wash to try which will be run through a 4" column still with 6 bubble plates and possibly an additional 12" extension packed with copper mesh with an aim at a high proof single pass neutral.
OK... I just finished reading every post of this thread. My head is now spinning. :crazy: Information overload. I see that the citric acid is used to invert the sugar when added to the sugar during simmering. Now I just need to do the math to scale the recipe up and figure out how much yeast to use in a 50 gallon. I’ll likely go to Costco to get the bakers yeast. Any tips on a 50 gallon recipe would me much appreciated. Also, any feedback on the above mentioned Gerber Barley flavor from Amazon? Is that the same stuff that was being used early on?
Based on my calculations this is what I am looking at for 50 gallons.
87 pounds of sugar
50 cups or Gerber ( I think that’s about 12 of the 8oz packages?)
100 tbsp (6.2 cups) of bakers yeast
11 tsp of citric acid (1/8 tsp per pound of sugar)
My plan would be to simmer 87 pounds of sugar in 10 gallons of water along with the citric acid. Due to the amount of sugar, I will likely split this into two batches. Each of about 43.5 pounds of sugar in 5 gallons of water with 5.5 tsp of citric acid. Once it’s simmered for 30 minutes or once it turns to a hay yellow color, then add the Gerber and a bit of yeast and simmer for a bit longer before putting it into the fermenter and adding the remaining 40 or so gallons of cool water. Hopefully that will result in temps that are around 90* for pitching the yeast. I will aerate the crap out of the wash using a drill and mixer paddle both before and after adding the yeast. I’ll likely start the yeast in advance using a mix of warm water and sugar with a bit of Gerber in it.
If I want to expedite the fermentation, I’d add 5 tsp of Epsom Salt and 10 tsp of 20-20-20 or 30-10-10 to the sugar syrup once the sugar has inverter?
It’ll be another couple weeks before I start this wash as I am still completing my still. Any further tips or critiquing the above numbers would be greatly appreciated.
Alphadog007
Re: Gerber
Post by Alphadog007 » Fri Apr 06, 2018 1:53 pm
I have a question on Rad's original post. He writes:
" * Simmer equal amounts of water and sugar for 30 minutes or longer to invert sugar.
* Combine boiled components with cold water and cereal to bring up to total volume.
* Let cool to 95F.
* Pitch yeast.
* Aerate for one hour.
* Cap and insert air lock. "
Later in the thread he and others talk about boiling the cereal (some say as long as 30 minutes) rather than just combining along with cold water (above) to the inverted sugar water. Doesn't that denature the cereal? What is the best way, Rad's original post or boiling the cereal also (for 30 minutes)? Note: The post started with Gerber but changed to various other cereals.
Nunyo
Re: Gerber
Post by Nunyo » Sun Apr 15, 2018 8:32 pm
After reading this thread from end to end as well as countless others, I just started a 45 gallon batch which is cooling now in prep for me to pitch my yeast. This is my first wash ever. A bit of this will be used for my sacrificial run and the rest will be run in 12-15 gallon batches in my new flute.
I dissolved about 75 pounds of sugar in about 17 gallons scalding hot water with 17 tsp of citric acid. I simmered for 30 minutes until the solution turned a hay yellow/inverted and then added 12 boxes of Gerber Barley flavor and about 1 cup of yeast. This was split across 2 seperate batches as my pot only holds 15 gallons. That was added to the fermenter with 25 or so gallons of cold tap water. Total volume came out to about 47-50 gallons in my 55g fermenter.
Corrected SG of 1.080
pH of 5.5
It’s been a few hours since I finished and the temp is down to 105 with constant aeration(air stone) and an occasional drill mixing using the plaster mixer. It’ll be a few more hours until it hits a pitching temp of 95* at which point I’ll add 4.5 cups of Red Star activated dry bakers yeast, aerate some more and put the airlock on. Will update over the coming days.
Edit, it’s 6:30 am the next morning. I pitched yeast about 25 minutes ago. I’m aerating with a stone and hitting it with the drill mixer every 15 minutes. Will button it up in about 30 minutes or so. Yeast seems to be working already.
Nunyo
Re: Gerber
Post by Nunyo » Mon Apr 16, 2018 7:18 am
Wow.. I pitched the yeast at 6AM and at 7AM when I covered it up and put the airlock on, the bubbling was insane! Like a machine gun! :crazy: This stuff took off like a bat out of hell! I had to remove the water with Star San from the airlock and just put plain water in because it was bubbling so hard the stuff in the jar started foaming up within seconds. I only had a tiny drop of Star San mixed with a lot of water in my mason jar airlock but. I had to run to the office and since this is my first ferment, I opted to put my spare webcam in there aimed at the airlock just to make sure it doesn't go nuts and spew through the airlock while I am at work. My airlock consists of a 1 pint mason jar with a 1/4" RODI filter type tubing run into it using push lock connections. I am hoping the tubing diameter will be sufficient.
Nunyo
Re: Gerber
Post by Nunyo » Fri Apr 20, 2018 3:43 pm
slief wrote:Wow.. I pitched the yeast at 6AM and at 7AM when I covered it up and put the airlock on, the bubbling was insane! Like a machine gun! :crazy: This stuff took off like a bat out of hell! I had to remove the water with Star San from the airlock and just put plain water in because it was bubbling so hard the stuff in the jar started foaming up within seconds. I only had a tiny drop of Star San mixed with a lot of water in my mason jar airlock but. I had to run to the office and since this is my first ferment, I opted to put my spare webcam in there aimed at the airlock just to make sure it doesn't go nuts and spew through the airlock while I am at work. My airlock consists of a 1 pint mason jar with a 1/4" RODI filter type tubing run into it using push lock connections. I am hoping the tubing diameter will be sufficient.
Well, exactly 4 days later and it appears that my ferment is done. The bubbles have pretty much stopped as of this morning and it now reads a corrected .993 SG. I’ll let it settle until tomorrow morning before racking it off into another drum for at least another day. Then I’ll do my sacrificial run and decide whether I will run the remaining 43 or so gallons at full reflux in my flute or dumb my flute down and run as a pot still to strip the wash and then run the low wines in a spirit run. Decisions decisions...
That said, I am very impressed with the speed at which this fermented out. I will do a final SG reading before racking it as I expect the SG to drop a bit more between now and tomorrow. Thanks Rad for the great recipe! I hope you’re stil lurking on this forum despite your apparent lack of activity.
Changnoi
Re: Gerber
Post by Changnoi » Sun Feb 17, 2019 6:14 pm
I'm still working my way through the thread, but thought I'd pipe in about starting my first batch. I went with the following recipe because it fits a 25# bag of sugar and will fit into 2 stripping runs in my pot still:
15gal water
25# sugar
2T citric acid
2ea, 8oz gerber rice cereal
3T DADY
pinch epsom salt
I boiled 5gal of water, added the sugar and acid, stirred, let it come back to the boil for about a half hour, then slowly transferred it with cold water to my fermenter to bring it up to about 15gal volume. Gravity ended up 1.070. While I was doing that I put some cold water in a mason jar, added some of the hot sugar water until it felt about right, put the yeast in and hydrated it while I did the rest.
Added the epsom salt, baby food, and yeast at about 90 degrees F. Used my power drill paint mixer and aerated for about 10min.
It's already foaming up a few minutes later. I'll come back every 15min or so and give it a good stir since I pitched a bit light compared to some of the ratios I've seen here. Should all come out in the wash, right? ;-)
Choady
Re: Gerber
Post by Choady » Mon Mar 30, 2020 7:28 pm
This looks likea great recipe for a first run!
If God is for us, who then can be against us?
Romans 8:31
Deplorable
Re: Gerber
Post by Deplorable » Thu Jul 02, 2020 11:35 pm
I cant find the Gerber Barley anywhere. But Wal-Mart has an Oats, wheat and Barley cereal mix.
https://www.walmart.com/ip/3-pack-Earth ... /191853654
Would this be a viable cereal. I'm really trying to stay away from a turbo wash for my sac run, and looking for a simple fast fermenting alternative.
metalsmith
Re: Gerber
Post by metalsmith » Sat Jul 04, 2020 6:53 pm
You are good with this for a sacrificial run. And many runs past that. Just stay away from the turbos. Just stay away from the turbos.
It should be a good drink after the cleaning runs too.
Deplorable
Re: Gerber
Post by Deplorable » Sat Jul 04, 2020 9:21 pm
Thanks metalsmith. I'll pick up a few boxes of this. I'm going to put a Kale wash in tomorrow for the sac run, then I'll play with a couple of these while I learn WTH I'm doing. Once I learn how to drive this still, I'll put my home brew experience to work. For now I'm not going to waste grain to make something that's mediocre at best. The still I ordered is on back order, and expected to be available for shipping this month. I figure I can get a couple of washes ready to run, and store them in corny kegs under CO2 until the still gets here. I've got a few kegs I can store washes in and get a few lined up to run freeing up my fermenters for more wash. :wink:
Deplorable
Re: Gerber
Post by Deplorable » Sun Jul 05, 2020 4:53 pm
I just started a 5 gallon wash of the Gerber Multi Grain Cereal.
6.5# sugar simmered 40 minutes in 2.5 gallons of water
6.5 Ounces Gerber Multigrain cereal added with the remaining water. Used a wort chiller to drop the temp to 95F.
SG 1065 @ 95F (calibrated for temp)
2 pkts of Lavlin EC-1118 rehydrated in 2 cups of cooled wort ( every store in town is out of bakers yeast)
Pitched yeast at 98F
The fermenter is now capped and wrapped in Reflectix bubble wrap.
SGB
Re: Gerber
Post by SGB » Tue Jul 07, 2020 11:10 pm
Just did 18lt. With 3 k of sugar ( afterwards I realised I should've used 4 kilos ) and a box of Baby Burbur ( I guess it was wheat baby food , it had a picture of wheat on it ) citric acid and a multi vitamin and sugar tolerant bakers yeast
Fermentation went OK. But I couldn't distill it for about two weeks because I got to busy with a building project.
Tastes like the baby food with a multi vitamin however
I ended up getting the exact same ratio as I do the UJSSM.
