All Bran Recipe
Re: All Bran Recipe
Postby gladitooktheredpill » Tue Apr 17, 2012 12:57 pm
gladitooktheredpill wrote:Here's one for you. I followed your directions with my first batch (20 liters) and ended up with about a 40 pounder of 40% vodka. Now I've made a second batch multiplying your recipe by 4, and the hydrometer is reading 1.56 which converts, according to the hydrometer, to about 7% alcohol potential. Am I missing something?
Yes, perhaps a brain cell or two. Or perhaps I'm such a rookie and so eager that I just jumped the gun, not knowing any better. I think what I did was distill my concoction before it was fully fermented. The second batch I make in exactly the same manner, with the exception of using 4 packets of Lalvin 1118, and it's still working after almost 4 full days. I harvested the other batch after about two. :mrgreen:
AND, actually the hydrometer reading would have been 1.056, not 1.56. Still that does give me an oddly low potential alcohol.
Reminder to self: do what you've been advised and spit out the testers. :oops:
gladitooktheredpill
Re: All Bran Recipe
Postby RidgebackDad » Tue Apr 17, 2012 3:34 pm
My two 5 gallon batches (used the formula on page 5 and scaled it up) are still going after 5 days and as of today, they both have a SG of 1.040 (they both started at 1.085) Think I may need to invest in an aquarium heater (or two) if I was going to use this recipe again. Not that the recipe is bad, but I'm no where near the 72 hours that other folks have had.
Brewhaus 3" Essential Extractor PSII High Capacity with 15.5 gallon keg on propane and cooling with a 45 gallon garbage can cooler
RidgebackDad
Re: All Bran Recipe
Postby coppermonkey » Sun Apr 22, 2012 12:37 am
All Bran is awesome!! i only ran it once, and when i did my cuts & blending i added a bit too much tails. over a month later i still have a pint left and the flavor is great. You can really taste the cereal. this stuff would be great for breakfast :lol: Think i need to make another batch to take camping this summer.
coppermonkey
Re: All Bran Recipe
Postby coppermonkey » Fri May 11, 2012 11:44 pm
Started a new batch of All Bran tonight.
11 gallon total wash.
20 lbs sugar
2 boxes generic bran cereal
1/4 cup DAP
2 jars fleischmann's active dry yeast
placed the crushed bran & sugar into my fermenter. added 5 gallons boiling water, and mixed real good for about 5 mins. added cold water up to the 11 gallon mark, mixed in the DAP., gave it a good stir. Pitched the yeast
The airlock started going crazy within 10 mins and has been going strong :thumbup:
I have done this recipe 1 other time,and really liked the wheat taste in a single run off a pot still :D
coppermonkey
Re: All Bran Recipe
Postby Prairiepiss » Sat May 12, 2012 12:23 am
1/4 cup of DAP? Please tell me tats a typo? That's way to much for a 11 gal ferment. And you really shouldn't need it with this recipe anyway. The cereal provides the nutrients. The only thing you mite add is Epson salts. And just a pinch of it.
It'scoldaroundhere. Whenyouloseyourjacket.
My Stuffs.
Prairiepiss
Master Distiller
Re: All Bran Recipe
Postby rad14701 » Sat May 12, 2012 5:16 am
Prairiepiss wrote:1/4 cup of DAP? Please tell me tats a typo? That's way to much for a 11 gal ferment. And you really shouldn't need it with this recipe anyway. The cereal provides the nutrients. The only thing you mite add is Epson salts. And just a pinch of it.
+1
And it also sounds like a healthy dose of yeast unless those were very small jars...
Master Distiller
Re: All Bran Recipe
Postby Prairiepiss » Sat May 12, 2012 6:40 am
If he is using the 4 oz jars of yeast like I was? I figured it up when I started my 12 gallon batches. And by your original per gallon recipe that's about right. If you upscale. Boiling half a jar and pitching the rest. But I dropped it down to one jar. Boiling 1/4 of the jar and pitching 3/4 of it.
So I would say if your going by the recipe its pretty close. But real world for the bigger batches. It's overkill.
My Stuffs.
Prairiepiss
Master Distiller
Re: All Bran Recipe
Postby coppermonkey » Sat May 12, 2012 1:02 pm
didn't measure the dap. just poured some in from a 1 lb bag and a clump fell in. will this mess it up?
yeast was 2 4oz jars. the only other time i tried this recipe it never finished dry, and i was told i under pitched the yeast.
man this thing is frying like crazy. way harder then any other ferment i have done.
coppermonkey
Re: All Bran Recipe
Postby coppermonkey » Sat May 12, 2012 2:32 pm
what will happen if i added to much? will it turn out like a turbo?
coppermonkey
Re: All Bran Recipe
Postby crazyk78 » Sat May 12, 2012 3:05 pm
Can someone advise what the Epsom does compared to the DAP as well? can you use both
crazyk78
Re: All Bran Recipe
Postby Dnderhead » Sat May 12, 2012 3:15 pm
magnesium sulfate,,a micro mineral yeast can use,very small amounts are needed.
Dnderhead
Master Distiller
Re: All Bran Recipe
Postby Prairiepiss » Sat May 12, 2012 3:53 pm
crazyk78 wrote:Can someone advise what the Epsom does compared to the DAP as well? can you use both
+1 Dnderhead
But this recipe doesn't call for DAP. Nor does it need it. The all bran is the nutrients. A small not of Epson salt really is all that is needed other then the cereal.
My Stuffs.
Prairiepiss
Master Distiller
PreviousNext
Return to Tried and True Recipes
Who is online
Users browsing this forum: No registered users and 3 guests
