All Bran Recipe
Re: All Bran Recipe
Postby RedwoodHillBilly » Sun Apr 16, 2017 9:01 pm
Calcium is a little low, but if you use oyster shells as has been recommended, you should be OK. When I did the all-bran recipe, I used oyster shells, DAP, a little MgSO4 (epsom salts), and some boiled yeast. You are probably OK with special-K, but if you have problems, you might want to add a small amount of DAP and some boiled yeast. If you add epsom salts, use just a very small amount, you want to keep the sulfur compounds to a minimum, but you do have copper in the vapor path.
John Barleycorn must die.
"and little Sir John in the nut brown bowl proved the strongest man at last.
The huntsman he can't hunt the fox, nor so loudly to blow his horn
and the tinker he can't mend kettle nor pots without a little barleycorn."
RedwoodHillBilly
Re: All Bran Recipe
Postby RedwoodHillBilly » Sun Apr 16, 2017 9:13 pm
I should add that once you have a recipe that works for you, optimum or not, stick with it and use it to learn how to run your tool (still). This way you haven't changed more than 1 thing at a time. Once you understand how running your still in different modes make a difference in your product, then you can branch out to new recipes. Do one thing, do it well, and keep the other variables the same, this will help you keep whatever sanity you still have left intact :-)
There are 4 major things that you need to master, don't confuse them. 1) ferments, 2) running your still, 3) cuts, 4 ) aging
They are all interconnected, but master them in order. Do each one well, then move on to the next. This is the path to success IMHO.
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Sun Apr 16, 2017 10:41 pm
Redwoodhillbilly thank you very much for this detailed explanation, ı used boiled yeast and epsom
Salt as said in the final recipe so from what you are saying I need to add calcium to make up for the
Limited amount in Kellogs Special K, how should I determine how much to use externally ?
artooks
Re: All Bran Recipe
Postby RedwoodHillBilly » Sun Apr 16, 2017 11:18 pm
If it were me, I would toss in a handful of oyster shells. This will help help to avoid a ph crash as well as adding a little bit of calcium. If you don't have oyster shell available to you, you could use clean and washed egg shells.
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 12:21 am
Hi,
I just realized that I made a mistake with the amount of Epsom salt that I used ı should have
put 1.5 teaspoon but instead 3 teaspoon would it cause much problem ?
artooks
Re: All Bran Recipe
Postby RedwoodHillBilly » Mon Apr 17, 2017 12:32 am
No, don't worry about it. Try to be consistent in your recipe. See my post above about #1, i.e. always do the same thing in your ferment, then work on #2.
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 3:37 am
Thank you RedwoodHillBilly I will do that, I think I am going to buy calcium tablets crush it and put it in the ferment would that be ok just trying to work out how much to put ?, would that be ok to put it now, 48 hrs passed already, so I hope I won't be interrupting the fermentation.
artooks
Re: All Bran Recipe
Postby still_stirrin » Mon Apr 17, 2017 4:20 am
:thumbup:
It looks great. It'll make a fine neutral. How is the fermentation working? Sizzling?
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Re: All Bran Recipe
Postby RedwoodHillBilly » Mon Apr 17, 2017 4:21 am
Unless your ferment has a problem, I would just let it run. Next time do your normal recipe, don't over think it, but be consistent.
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 5:07 am
Still Stirrin, Redwoodhillbilly
Thanks a lot, it is bubbling like crazy it is now 48 hrs since the fermentation started
Should I still do stripping and Spirit or only spirit at one go ?
artooks
Re: All Bran Recipe
Postby still_stirrin » Mon Apr 17, 2017 5:24 am
artooks wrote:...it is bubbling like crazy it is now 48 hrs since the fermentation started
:clap:
artooks wrote:Should I still do stripping and Spirit or only spirit at one go ?
Since you're desiring a neutral, I suggest (strongly) to strip and then do the spirit run. So, make enough wash to fill your stripper 3 times. Then, the low wines will give you a good run with a large measure of product, enough to make good cuts for a clean neutral.
Master Distiller
Re: All Bran Recipe
Postby RedwoodHillBilly » Mon Apr 17, 2017 5:35 am
If you want a clean neutral, I would recommend a strip then a spirit run. You may want to do a couple of ferments and strips to give you enough low wines to do a reasonable size spirit run.
Another hint, while you are waiting on you spirit run and have low wines, you may want to raise the ph of the low wines, which will make a cleaner neutral. Do some research on the forum about this (that is where I found it and it works nicely).
I used sodium carbonate. but Lye (NaOh) would work also. There is much research about why this works, it is up to you to to do to your research/search to find out why.
Posted with SS
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 5:39 am
Thank you very much Still Stirrin
I will do Strip and Spirit Run, I cannot do more than 1 batch at a time because of my fermentation chamber can only take 1 I purchased a small boiler, for this purpose, so my big boiler is 8 gallon and small boiler is 2.5 Gallon, I hope I can achieve what I am looking for, would it make a difference to start with a small bath so first I would do 8 Gallon strip run then will do a 2.5 Gallon spirit run.
artooks
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 5:57 am
RedwoodHillBilly,
Thanks I will do the necessary research about it, thanks for pointing that out.
artooks
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 6:18 am
My Biggest problem from day 1 is transferring the wash to the boiler, so with this All Bran wash what I will do is once the fermentation has been completed I will syphon it to a secondary and will keep it at 40.00 ℉ and then rack it to the boiler, is this workflow correct ?
artooks
Re: All Bran Recipe
Postby still_stirrin » Mon Apr 17, 2017 7:07 am
artooks wrote:....would it make a difference to start with a small bath (batch?) so first I would do 8 Gallon strip run then will do a 2.5 Gallon spirit run.
That'll work. It's just that you'll have to collect in small jars in the spirit run so you can make good cuts. A larger charge just gives more product for you to "cut and claim". Same process applies for the small batch as a larger one. It's just easier to do with the larger sized batch.
edited to add:
Or, another possibility would be to store the low wines until you have enough to charge the big boiler for the spirit run. It's the way I do it. I ferment 2 x 5 gallon carboys (sometimes 3) at a time. Then, I strip the wash and put it in the refridgerator for storage. I start the next round of ferments in the carboys. And I repeat this the 3rd time. Once I've collected all the low wines, I charge the still for the spirit run. Sure, this takes more calendar days than the way you're proposing to put some fresh spirits into your drinking bottles. But, it gives me more product to cut with, making "conservative cuts" easier to accomplish. Like RHB suggested, I do add a couple of teaspoons of sodium carbonate to the low wines while I wait for the 3rd strip run. It does help clean the spirit while stored awaiting the spirit run.
Master Distiller
Re: All Bran Recipe
Postby still_stirrin » Mon Apr 17, 2017 7:17 am
artooks wrote:My Biggest problem from day 1 is transferring the wash to the boiler, so with this All Bran wash what I will do is once the fermentation has been completed I will syphon it to a secondary and will keep it at 40.00 ℉ and then rack it to the boiler, is this workflow correct ?
You know, artooks, this type of "process question" is not specific to this Tried &True recipe. So, it would be better asked (and answered) in a different forum. The T&T forum really is reserved for recipe and process concerns/questions/comments relative to this recipe. General process questions are better placed elsewhere. <-- just a hint or suggestion (I'm not the website owner or moderator).
Master Distiller
Re: All Bran Recipe
Postby RedwoodHillBilly » Mon Apr 17, 2017 7:38 am
Good point, I know that I've been a little lax in pointing this kind of thing out. I'm trying not to be a (former member name redacted), and I know that I've done a lot of "spoon feeding", but I remember when I was a "newbie". Hopefully Artooks, will get the hint and do his own research :hint :hint: and just ask questions when they can't be found after searching or trying something that didn't work out.
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 8:01 am
You are absolutaly right Still Stirrin, I will be more careful. Thank you Redwoodhillbilly ı will do my best.
artooks
Re: All Bran Recipe
Postby still_stirrin » Mon Apr 17, 2017 10:33 am
Hang in there artooks. You'll get it soon...
Master Distiller
Re: All Bran Recipe
Postby artooks » Mon Apr 17, 2017 12:04 pm
Hi,
I also find this Nesfit, it is a plain one and is consumed in breakfast, can this be a better option compared to the Kellogs Special K
artooks
Re: All Bran Recipe
Postby RedwoodHillBilly » Mon Apr 17, 2017 12:14 pm
That should work just fine. Yeast want's B vitamins and a bit of calcium, magnesium, and nitrogen. Try it and let us know how it works out. Remember, one good test is worth a thousand expert opinions. If it doesn't work, that is a good data point. Experiment, and if you have a problem, correct it and then try again. This is part of learning.
RedwoodHillBilly
Re: All Bran Recipe
Postby artooks » Tue Apr 18, 2017 12:31 am
Hi,
I will try this and keep you posted,
artooks
Re: All Bran Recipe
Postby Grappa-Gringo » Thu Apr 20, 2017 2:37 pm
I've been looking all over for an answer but can't find it. Rad's All bran recipe... does it have a flavor? or is it just a sugarwash neutral type of thing??? He doesn't have a email or PM box next to his name otherwise I would have asked him. I'm thinking of running a batch, but want to know what to do with it afterwards...does it mix well with anything??
They say, "you are what you eat"... Then I'm fast, easy and cheap!
Grappa-Gringo
Re: All Bran Recipe
Postby RedwoodHillBilly » Thu Apr 20, 2017 2:38 pm
Sugarwash for making neutral.
RedwoodHillBilly
Re: All Bran Recipe
Postby kimbodious » Thu Apr 20, 2017 3:34 pm
It makes a good neutral spirit.
If you work your way through this thread you will read where people using generations (adding backseat from earlier runs) and oak-ageing to make a nice whiskey-style tasting sugar head spirit. I have made this and it is a popular sipper!
kimbodious
Re: All Bran Recipe
Postby cranky » Thu Apr 20, 2017 5:33 pm
Grappa-Gringo wrote:I've been looking all over for an answer but can't find it. Rad's All bran recipe... does it have a flavor? or is it just a sugarwash neutral type of thing??? He doesn't have a email or PM box next to his name otherwise I would have asked him. I'm thinking of running a batch, but want to know what to do with it afterwards...does it mix well with anything??
I use it for both, I make a nice flavored version using miscellaneous cereals which I generally refer to as Unicorn Sweat since I am not very strict on controls and often use whatever organic cereal is available, on sale, or cheap. I also use an entire box of cereal for every 5 gallons of wash sometimes adding some fresh cereal to the wash just before it finishes which adds a lot of flavor. I get plenty of flavor run once or twice through a pot or once through the flute depending on the blend. Then after I take what will be used for flavored I make a neutral out of the rest.
Sometimes I pretend to be normal but it gets boring so I go back to being me
A message to new members
We want you to be safe and succeed so start here
My Simple Controller
My Apple Brandy Recipe
cranky
Re: All Bran Recipe
Postby artooks » Fri Apr 21, 2017 2:20 am
Hi Everyone, as I said I did my first All Bran wash with Kellogs Special K, it is in its 6 day still bubbling starting OG: 1.074 Yesterday I did another batch with Weetabix Bran Flakes, so I will be doing some trials about taste, I am not sure of the Vitamins and Calcium levels, would it hurt to add 1 Multivitamin tablet, in the wash if so how much for 7-8 Gallon ?
Also with this type of wash how do you syphon it to the boiler, would like to here your experience as I am close to complete the fermentation.
artooks
Re: All Bran Recipe
Postby Pikey » Fri Apr 21, 2017 3:25 am
artooks wrote:Hi Everyone, as I said I did my first All Bran wash with Kellogs Special K, it is in its 6 day still bubbling starting OG: 1.074 Yesterday I did another batch with Weetabix Bran Flakes, so I will be doing some trials about taste, I am not sure of the Vitamins and Calcium levels, would it hurt to add 1 Multivitamin tablet, in the wash if so how much for 7-8 Gallon ?
Oh come on !
Do some reading or take some responsibility for your own decisions !
I'm not sure all this constant spooooon feeeeeding is doing you any good !
Pikey
Re: All Bran Recipe
Postby Still Life » Fri Apr 21, 2017 5:28 am
Artooks...
Here's how to fish rather than feeding you one:
Open HD Google Search at top of page.
Leave a space after the URL and type in "siphon"...
Do the same for "vitamin"
The answers are there.
Still Life
PreviousNext
Return to Tried and True Recipes
Who is online
Users browsing this forum: No registered users and 4 guests
