All Bran Recipe
acfixer69
Re: All Bran Recipe
Post by acfixer69 » Sat Jan 13, 2018 7:03 pm
still_stirrin wrote:If it ain’t broke....don’t fix it.
that's what goose said somewhere eh
AC
rgreen2002
Re: All Bran Recipe
Post by rgreen2002 » Sat Jan 13, 2018 7:12 pm
The bran also acts as a buffer to help prevent the pH crash frequently seen in sugar washes. It's a great recipe and makes a good neutral!
HD Glossary - Open this
Master Distiller
Re: All Bran Recipe
Post by still_stirrin » Sat Jan 13, 2018 7:34 pm
courtofjest wrote:I'm relatively new here, but I was making the all bran recipe and noticed that there are not any enzymes to break down the carbs in the wash. Would it help to add some malted barley to aid in breaking it down into sugars or is all-bran processed enough so that it does not matter?
Correct. This is a sugar wash recipe. The bran provides nutrients as stated, as well as buffering to the acid production as the ferment progresses. This too has been explained previously in this thread and as pointed out by RedwoodHillbilly, ACfixer, and rgreen.
The all bran recipe is an excellent base for a neutral, not particularly suited for a whiskey. But, it DOES make an excellent base for a gin...when you get to that recipe in the T&T.
UJSSM is better for that target (whiskey/bourbon), even though it too is a sugar wash (not a grain mash). Since these sugar washes utilize the sugar as the fermentable material, you don’t need enzymes to convert starches to sugars. Any grains added are for flavoring the sugar wash alone, not for potential alcohol.
Another is Odin’s corn flakes sugar wash recipe too. Corny flavor, but the alcohol comes from the sugar, not the cereal.
I hope you understand this difference (in the recipes). It is fundamental to your knowledge base in the hobby. Trying to make the all bran into something that it isn’t will lead to frustration and cause you to question your processes.
rgreen2002
Re: All Bran Recipe
Post by rgreen2002 » Sun Jan 14, 2018 5:25 am
still_stirrin wrote: I hope you understand this difference (in the recipes). It is fundamental to your knowledge base in the hobby. Trying to make the all bran into something that it isn’t will lead to frustration and cause you to question your processes.
+100.... this is a KEY copncept. Repeated failure because of something impossible will drive you out of the hobby. This would be akin to trying to change lead into gold...over and over and over again with the unexpected result of it not working... :mrgreen:
Spriit Tisler
Re: All Bran Recipe
Post by Spriit Tisler » Wed Jan 17, 2018 12:47 pm
Fancy, I had all bran going on for 7 full days now and it's still going on. It has always been done&cleared before. I quess it's the temperature. Does it hurt to let it sit for another week, because I've got a job related trip in few days and I'll be back at next wednesday?
Master Distiller
Re: All Bran Recipe
Post by still_stirrin » Wed Jan 17, 2018 6:50 pm
Spriit Tisler wrote:Fancy, I had all bran going on for 7 full days now and it's still going on. It has always been done&cleared before. I quess it's the temperature. Does it hurt to let it sit for another week, because I've got a job related trip in few days and I'll be back at next wednesday?
Won’t hurt it at all. Just keep it under airlock. Have a safe trip.
artooks
Re: All Bran Recipe
Post by artooks » Fri Jan 19, 2018 2:22 pm
What is your OG ?
courtofjest
Re: All Bran Recipe
Post by courtofjest » Fri Jan 19, 2018 3:20 pm
I did actually up the bran ratio quite a bit, added pearl barley, a bit of corn meal, and then converted a fair bit of sugar with malted barley. I added sugar to bring the gravity up and fermented to 1.0 before distilling in a pot still. The flavor actually came through very nicely and I'm quite pleased with it.
Looks like I absolutely made it into something it is not (without realizing its true purpose as a sugar wash) and it worked well for me luckily.
I'll give the original recipe a try next, I've heard it turns out great by many people.
Spriit Tisler
Re: All Bran Recipe
Post by Spriit Tisler » Tue Jan 23, 2018 3:34 pm
My longer-than-usual batch was well finished and I stripped it. I though added some leftovers from liquor and punch and I got total of 8 liters of strippings that have somewhat around 60% abv. I did not bother to run lower than 35% or 97C though. Gonna spirit it tomorrow if I've got the time and meanwhile I put in 5g/l of sodium carbonate in there to compress the heads and tails, hoping to get max hearts out of it.
EDIT Spirit ran it today, and it all got down to 2.5 liters of pure hearts at 95ABV which appears to have very neutral odor, with hints of ethanol and very distant aroma off all-bran. From 8 liters of 60% I distilled total of about 4 liters, which of hearts was collected about 55%, discarding two extra 150ml glasses just in case. During all the distillation it sat tight at 78.6C which is corrected to 78.2 from barometer count, and only at the end slowly rised to 78.7, and then jumped to 79.6 for a moment and then began the swing from 79 to 82 at when tails kicked in and I stopped.
I need to refine some of my equipment and work habits for smoother operation. Need to weld a new valve outlet to bottom of my boiler to eliminate the need to move that piece of junk for emptying and cleaning. I also broke my most expensive 4-liter boiling flask which set me back for 200 bucks. :evil:
Next week it shall be the corn whiskey.
BTW, I added about third of a kilo of rolled oats (the porridge stuff) to the all-bran wash, because I feel it adds smoothness to the end product.
dee_stiller
Re: All Bran Recipe
Post by dee_stiller » Thu Feb 22, 2018 12:12 am
Another thread completed and noted. A must try recipe. In absentia, thanks very much Rad.
All this readings giving me a headache. Upside? At least the grog wont.
Brunojack
Re: All Bran Recipe
Post by Brunojack » Tue May 01, 2018 8:30 pm
I got through all 64 pages!
Have a batch going now. Sounds like this is THE one to do. My initial sg was 1.104. Seemed high comparing to everyone else. Potential abv of just under 14%.
I did use different yeast. Still Spirits vodka distillers yeast. Says it can tolerate 14% alcohol. Started slow. After 24 hours airlock was bubbling once every 3-5 seconds. At 36 hours it was steady bubbling.
Currently at 96 hours after pitching. Airlock is slowing down to 1 burp/5 sec. Noticing some sediment forming on bottom. Going to let it finish, then clear and will report back.
Brunojack
Re: All Bran Recipe
Post by Brunojack » Tue May 22, 2018 7:14 am
Wow. Waited until the wash looked like apple juice. I ran this through my Pstill. My 1st "real" run. Definitely could tell the first bit wasnt something you wanted to imbibe.
Ended up chucking the first 150 ml just to be conservative. Collected a bit under 2 quarts in 12 jars. I was running real slow. Kept the 3 jars on each end for feints. I should have kept track of the abv better. The end of run was at 45%. I know I probably could have been more efficient.
I diluted the middle jars to 80 proof after letting them air out overnight. Added my tequila essence. That was absolutely the smoothest booze I have ever had in my life!! At first I was wondering if there was any alcohol in it!!!
Thank you Rad and fizzix and everyone else who helped me to get to this point!
Swedish Pride
Re: All Bran Recipe
Post by Swedish Pride » Tue May 22, 2018 8:39 am
Brunojack wrote:Wow. Waited until the wash looked like apple juice. I ran this through my Pstill. My 1st "real" run. Definitely could tell the first bit wasnt something you wanted to imbibe.
You ran a 14 wash once through a pot and like it?
Try running it twice next time to see if you can tell the difference
Don't be a dick
Brunojack
Re: All Bran Recipe
Post by Brunojack » Tue May 22, 2018 5:21 pm
"You ran a 14 wash once through a pot and like it?
Try running it twice next time to see if you can tell the difference"
As in collecting everything except the first 100 ml and running it again without diluting?
That would be a much higher abv wash running through the still. I am thinking a 2nd run would remove more flavor and result in higher abv during the entire process. This is the so called stripping run followed by a spirit run? As I understand it..stripping runs can be done at a very fast rate..correct?
I did my run real slow...probably collected for 4 hours or more.
Bear with me as I am a Noob with a capital N!
Blackbeard
Re: All Bran Recipe
Post by Blackbeard » Thu May 24, 2018 3:03 am
rad14701 wrote:Recipe
* 2 gallons water
* 7 cups white sugar
* 2 cups All-Bran Flakes cereal
* 4 tbsp Fleischmann's dry active yeast
* 1/4 tsp 20-20-20
Process
* Inverted sugar in 8 cups water for 30 minutes
* Boiled cereal in 4 cups water for 30 minutes
* Allowed invert sugar and cereal to cool to 95F
* Pitched yeast and aerated for 1 hour
* Added 1/4 tsp 20-20-20 and airlocked.
Can you please clarify what 20-20-20 is and your final ABV target please?
Swedish Pride
Re: All Bran Recipe
Post by Swedish Pride » Thu May 24, 2018 6:02 am
Brunojack wrote:"You ran a 14 wash once through a pot and like it?
If it were me I'd stripp as hard as you could until the collected booze is about 30% abv, then do a slow spirit run.
A few do a single distillation but would not be to many.
yep second run gives you srtonger booze but also cleaner tasting and better seperation the fractions.
you'll still get smearing and a lot of flavour through a pot still doign two runs
Don't be a dick
Master Distiller
Re: All Bran Recipe
Post by still_stirrin » Thu May 24, 2018 6:14 am
Blackbeard wrote:Can you please clarify what 20-20-20 is and your final ABV target please?
Fertilizer.
20% nitrogen (which is a nutrient to yeast, but can result in ammonia in the ferment if excessive amounts are used). 20% phosphorus (which is essential for yeast healthy budding/reproduction). And 20% potassium, which also is somewhat a yeast nutrient, although not quite as critical of a nutrient to the yeast as the other elements. However, it is now a chemical which is more regulated because of its “bomb-making” potential.
20-20-20 fertilizer is hard to find with that high of phosphorus and potassium content. Flower fertilizers may have it, but at a higher price....Miracle Gro, for example.
I use a 10-10-0 fertilizer (at the same rate as recommended in the recipe). And I pulverize the fertilizer in a mortar and pestle before adding to the stock pot where I simmer the ingredients before adding to the fermenter.
The vitamin B pills are important to this recipe as well. They provide a good nutrient for yeast metabolism. Spent yeast cells are also a great source of vitamin B. Even health food stores sell dried yeast (denatured, of course) as a food supplement.
p.s.-A good starting gravity target for the all bran recipe would be 1.070-1.075, which will get you to around 10%ABV (potential). Don’t try to push it higher as you’ll start to get fermentation off flavors in the wash and finished product.
Brunojack
Re: All Bran Recipe
Post by Brunojack » Fri May 25, 2018 6:57 am
"If it were me I'd stripp as hard as you could until the collected booze is about 30% abv, then do a slow spirit run.
you'll still get smearing and a lot of flavour through a pot still doign two runs"
Alright. I will give that method a try next time then. I honestly appreciate the advice bro! Thanks.
Have read about that in the new member section, the parent site and other places I'm sure. But it seems to hit home better in the context of this recipe. I know spoonfeeding is frowned upon and I understand why...I believe there was some posts in this recipe thread about reading a hydrometer! and other basic methods. Made it a little frustrating for me (a complete and total n00b). But I now have 1 successful run, looking forward to the next.
Brunojack
Re: All Bran Recipe
Post by Brunojack » Sun May 27, 2018 7:05 pm
I have a question concerning this recipe.
Do you guys think when you boil the cereal with the water you are extracting all or enough of the nutrients to have a successful ferment? In other words, is it necessary to include the cereal mush in the fermenter?
Seems like you could have a cleaner ferment without the mush.
Brunojack
Re: All Bran Recipe
Post by Brunojack » Mon May 28, 2018 3:43 pm
Wow..this has taken off! I did add some DAP this time
Huge difference.
fizzix
Re: All Bran Recipe
Post by fizzix » Mon May 28, 2018 4:07 pm
That DAP is a godsend.
I looked for an answer to your boiling question, Brunojack, and couldn't find anything.
When I did Cornflake Whiskey I left the boiled cereal in the ferment. Might as well.
Just siphoned off to the cereal bed when it was done.
Brunojack
Re: All Bran Recipe
Post by Brunojack » Mon May 28, 2018 5:41 pm
I'm a believer in dap now. Airlock isn't so much bubbling..but a constant stream of gas emitted.
Yeah, I ended up dumping everything from the kettle in..too much liquid tied up with the cereal mush. Like you said fizzix..just siphon off of it when done.
Wolfairious
Re: All Bran Recipe
Post by Wolfairious » Mon Sep 24, 2018 3:16 pm
Are people getting better results with the 20-20-20 than the epson salt? Epson salt is so much easier to get why are not more people using it?
Modular Keg Pot Still & 3" CCVM
fizzix
Re: All Bran Recipe
Post by fizzix » Mon Sep 24, 2018 5:13 pm
Wolfairious wrote:Are people getting better results with the 20-20-20 than the epson salt? Epson salt is so much easier to get why are not more people using it?
I use Epsom in conjunction with DAP (which is a substitute for 20-20-20) as they each have a function.
Epsoms provides the magnesium for cell division and clumping, and 20-20-20 (or DAP) is a nutrient to keep the yeast "energized" and healthy.
So it's really not a matter of one over the other.
dirtybird33
Re: All Bran Recipe
Post by dirtybird33 » Tue Sep 25, 2018 8:43 am
So how much dap are you using?
Mod edit removed advertisement
Master Distiller
Re: All Bran Recipe
Post by still_stirrin » Tue Sep 25, 2018 11:43 am
dirtybird33 wrote:So how much dap are you using?
I use 1/8 teaspoon per gallon.
dirtybird33 wrote:Sent from my SM-N950U1 using Tapatalk
Please turn this advertisement off. We don’t need it here. Thanks.
dirtybird33
Re: All Bran Recipe
Post by dirtybird33 » Tue Sep 25, 2018 3:17 pm
Thanks. I might pick some up and try it. I have never used it. Do you add it when you start the wash or do you add it mid ferment. (I know some yeast nutrients are added mid ferment)
fizzix
Re: All Bran Recipe
Post by fizzix » Tue Sep 25, 2018 3:56 pm
dirtybird33 wrote:Thanks. I might pick some up and try it. I have never used it. Do you add it when you start the wash or do you add it mid ferment. (I know some yeast nutrients are added mid ferment)
In 5~6 gallons, right before I pitch the yeast I put in the DAP, pinch of Epsoms, a crushed vitamin B-complex, and a dash of gypsum.
Aerate until a froth remains, throw in a brew bag containing a fistful of crushed oyster shell (for pH buffering), and then the yeast and cover.
That's the whole chemistry set as-is, all built on advice from here at Home Distiller and I've never had a stall or failure of any kind.
equilibrium
Re: All Bran Recipe
Post by equilibrium » Sun Dec 02, 2018 7:58 am
Several pages back, Odin mentioned he filtered his water prior to diluting. I was under the impression that giving the water a quick boil, cool down and then using it for dilution would be enough. That being said, where I live (Norway), we have clean tap water. Drinkable directly from the faucet. But it still made me wounder. Should I filter it, or even distill it?
Other than that this recipe seems pretty straight forward. Will do a strip run, then do a neutral run through my VM still. Look forward to try it out!
Paymanz
Re: All Bran Recipe
Post by Paymanz » Tue Jan 01, 2019 12:15 am
high amount of yeast in this recipe ,2tbsp of yeast for 3.5 cup of sugar , so whats the purpose for aeration?
