S-Cackalacky wrote:Thanks WV, I just read through it once and it does seem that I may be able to follow it. I'm guessing the switch is just there to completely kill the power instead of trying to do it by turning the power down with the control knob - correct? About the 12-2 wiring - I have a 25 feet, 14-3 extension cable that I currently have connected directly to my heating element. I was planning to cannabalize it for the wiring I need for the controller. It's rated for 110V, 15A. My element running on 110V is 1375W drawing around 12A at full power. I've run the boiler with that cable a few times and didn't get any heat up of the cord. Do you think it will be OK to use it?
About the phone charger - I don't think I have one. Would a regular 12V DC adapter serve the same purpose. If so, could I wire the 110 directly to the plug prongs and wrap them real good with rubber insulating tape?
The bus bars - I'm assuming you connect the 110 power in to one terminal and anything you connect to the other terminals on the bar will draw from that power source - correct? If so, it would seem to be a better solution than the wire nuts.
Hey, I might just be able to do this!
Just sayin',
S-C
Well yep the switch is to be able to turn it off and whats 4 or 5 bucks for safety.As for 14-2 extension cord I would just recommend 12 -2 just a little extra margin of safety. The cable is 12-2 or 14-2 the green earth ground isn't counted. If you get the 110 fan it's not needed. Let's see the 12v adapter from ebay would probably be fine but if you have to by one I would get a regular stepdown converter from ebay. There just as cheap maybe cheaper and designed to do the job. Let me know and I will post you a link. Yes the bus bars are a far better solution than the wire nuts and you have extra locations for other options if you decide to add to it. See before you know it you'll have that controller. If you wants some links for parts just ask I probably have them saved somewhere.
Glad to help.
Just sayin',
S-C
Glad to help.
I guess I was editing my last post as you were posting this. My edit was about the 110V fan and you pretty much answered my question. I'll try the flea market for the 12 guage extension cord. Otherwise, I might need to use the 14 guage for now.
Enough for now. Let me absorb some of this and I'll get back to you. Your help is greatly appreciated. You have a considerable amount of patience.
Thanks,
S-C
