Ferment stinks like rotten eggs
Postby kenfyoozed » Wed Apr 22, 2009 6:06 pm
I started a new wash last night.
3lbs of brown sugar
7lbs of white sugar
1 can of tomato paste
added water to reach Sg of 1.077
Also added a "yeast bomb". Consisting of:
1/4 yeast
1/4tsp epsom salt
5 tsp 21-0-0
2 multivitamins.
This thing started ferminting fast. Airlock was bubbling fast in 30mins and has not stopped for 24 hours. I Pitched 1/2 cup of yeast when the temp was 84*f. I did two new things, 1) I used the bread machine bakers yeast that comes in small jars. 2) I used tap water.
After 20 hours the Sg is 1.034. The air coming from the air lock smells like rotten eggs. I searched the forums and found some information, and the thought of contamination scares me. The liquid smells fine and taste fine, but the off gassing smells horrible. What have I done wrong? Am i safe to distill?
kenfyoozed
Re: Ferment stinks like rotten eggs
Postby Dnderhead » Wed Apr 22, 2009 6:18 pm
Symptom: It smells like rotten eggs.
Cause 1: Yeast Strain Rotten egg odors (hydrogen sulfide) can have two common causes: the yeast strain and bacteria. Many yeast strains produce noticeable amounts of hydrogen sulfide during fermentation. The smell and any sulfur taste will dissipate during lagering.
Cure: Let it condition for a few weeks after primary fermentation.
Cause 2: Bacteria Bacterial infections can also produce sulfury odor.
Cure: Let the fermentation complete and then taste it before distilling to see if it is infected. Toss it if it is.
I whould say the yeast........
Dnderhead
Master Distiller
Postby kenfyoozed » Wed Apr 22, 2009 6:23 pm
I am a Nurse by trade, and I have never "tasted" infection. :mrgreen: So when tasting what should I look for? Are there anyother signs? I assumed it was the yeast or water. Thanks for the help.
kenfyoozed
Postby Dnderhead » Wed Apr 22, 2009 7:27 pm
If it is good it will taste like "funky"dry wine or hard cider if it is infected it will taste like OOOOOO its **@*&^%!!!!!
one note** if you ever have a mold on top it wont hurt (mite look like a zodiac sign :? ), just run it and clean everything up next time.
Dnderhead
Master Distiller
Postby kenfyoozed » Thu Apr 23, 2009 3:26 am
Thanks. I'll let it run for now and taste when completely finished. Hopefully it will be ok, and the smell is just comeing form the yeast.
kenfyoozed
Postby The Chemist » Thu Apr 23, 2009 6:40 am
Epsom salt = magnesium sulfate
21-0-0 = ammonium sulfate
Bugs + tons o' sulfate = rotton egg smell
As advised though, it's not a deal-buster. Any that doesn't 'blow off' will likely be 'dealt with' during distillation.
Purposeful motion, for one so insane...
The Chemist
Postby goinbroke2 » Thu Apr 23, 2009 7:19 am
"1) I used the bread machine bakers yeast that comes in small jars. 2) I used tap water"
Just FYI, I use bread machine yeast (what the wife brought home) and tap water. My water is town water with chlorine etc and a ph of 7.0 I use lemon juice or backset to lower it. No mine doesn't stink but thought I'd confirm that others use bread machine yeast and tap water too.
goinbroke2
Postby rad14701 » Thu Apr 23, 2009 1:37 pm
"Bread Machine Yeast" is merely "Rapid Rise Yeast" which contains Ascorbic Acid as an added ingredient which would contribute only marginally to a sulfur smell, but you never know what'll happen when combined with the rest of the sulfates...
Master Distiller
Postby kenfyoozed » Thu Apr 23, 2009 2:17 pm
I know all of my equipment was clean I used water and bleach and let evrything soak an hour before I started. All my ingrediants were new except 1 bag of brown sugar. It was in an airtight container, but I have had it for a few months. How else could I have gotten contaimination? I am new to this, but I knwo about keeping things clean and seperate from working in a hospital. I'll report back tonight once I get a chance to check it.
Is there any way to actually test if there are "bugs"?
kenfyoozed
Postby rad14701 » Thu Apr 23, 2009 2:30 pm
I think you're probably exaggerating the off smell because brown sugar and molasses do put out an odd smell... That's one reason why I haven't tried any more brown sugar washes here in the apartment... While the smell does subside relatively quickly it really smells things up until it does... They can say all they want about being unsulfured - the smell is still there during fermentation...
Master Distiller
Postby kenfyoozed » Thu Apr 23, 2009 4:50 pm
I checked the ferment when I got home. SG at .996. The smell is still there just not as strong. I didnt add molasses, but the smell amy be coing from the brown sugar. That is a good thought. This was the first time I had the ferment in the living area, normally it stays in our utility room/storage area. In the dining room it , it really stank up the whole house, but its going away now. So who knows? It tatse's ok, almost like some bubbly champain. I'll run this tommorrow after noon.
I forgot to add, that I appreciate the help!
kenfyoozed
Postby blind drunk » Thu Apr 23, 2009 6:47 pm
Don't know the science but when it used to happen to me when I made wine I would rack off and that would do it. BD.
I do all my own stunts
blind drunk
Master Distiller
Postby The Chemist » Fri Apr 24, 2009 6:06 am
kenfyoozed wrote:Is there any way to actually test if there are "bugs"?
:D
Yeast are bugs...or is that 'yeast am bugs'? 'Yeast is bugs'?
The Chemist
Postby punkin » Sat Apr 25, 2009 11:49 am
:D
here i am thinking yeast is a plant.... :roll:
punkin
Master Distiller
Postby 0re0 » Thu Nov 19, 2009 4:16 am
reading on the homepage I saw that pitching too much yeast can possibly give you sulfur odors
I've done it before, no big deal.
Sulfur smell doesn't necessarily mean you are contaminated
Aerate wash with a breathing nebulizer or small water pump and add copper as stated before
It worked for me in my time of need
BUUUUUUUUUUURP!
My 1st Rum Run
0re0
Return to Novice Forum Graveyard
Who is online
Users browsing this forum: No registered users and 0 guests
