Lately my mash has been staying around 7 to 8 %. I end up getting a stuck ferment when I've tried to push it over that so I have started being satisfied with what I get and the taste it gives me.
Seems though my runs are really going on the long side. From start to finish once it starts dripping can easily be 8 or 9 hours.
My pot holds 17 and I generally run 10 to 12 in it. Not counting the foreshots and heads I normally get close to 3/4 of a gallon of good tasting spirit that is strong.
Then I can stretch it out and get another quart or so of tails before I get tired of a drop a second.
Could increasing my coil size speed things up.
Pot is 15" in dia. x 24" tall.
Then I come out of the head with 6" that tapers to 4" and this is 24" tall. This angles off at a downward slope starting at 3" and reduces down to 1 1/2" or 2" in about 24".
This section is removable from the pot for filling and cleaning.
Then I reduce down to a 1" coupling with about a foot of 1" straight down to a reducer to about 6' of 5/8" coil. This is sitting in a 5 gal. bucket that has water going into it at the bottom and draining out at the top.
I would post a photo of the entire thing, but my camera died on thanksgiven!
It takes about an 1 1/2 hour with a propane turkey cooker to get up to 175F +/- where I usually start getting a slow drip, then the drips increase to a couple every second or so till it gets over 200F and starts slowing down again.
Still these runs seem long.
Luckily, when I have work, I work at home.
