Thumper question
Thumper question
Postby clones2 » Sun Apr 10, 2011 6:52 am
In process of building my first pot still and I have a question about the thumper.
First - for something around a 5 gallon pot - how big should the thumper be?
Second - This is what I dont 100% understand about the thumper. If it starts 50% of water... the initial incoming vapor condenses to create more liquid... Is there a chance that the thumper would ever fill up and overflow with liquid before the vapor starts flowing out of it into the condenser???
Yes I am a bit of a newb at this. :-)
Thanks.
clones2
Re: Thumper question
Postby Bull Rider » Sun Apr 10, 2011 7:56 am
Welcome Clones2:
I see this is your first post, what I'd suggest is that you get your pot still up and running. Learn it well, run it without a thumper until you're producing a product that's pleasing to you. Pot stills are pretty basic, but that's not to say that there isn't a considerable learning curve.
When you've achieved that level of skill, then move up to a thumper. You may like it, or you may prefer just the pot still. I've run a pot still dozens and dozens of times, and I've considered building a thumper. I have all of the components, but I'm content (for now) to run my current setup.
Bull.
Bull Rider
Postby LWTCS » Sun Apr 10, 2011 9:18 am
thumpers are often 1/2 to 1/3 the size of the primary boiler.
Yes there is a chance that that flooding can be an issue.
Typical thumper run only needs liquid enough to cover the inlet.
Upward turn lyne arm with a jacketed condenser can give you the self fill capability. Means more ABV.
Elevated thumper with return drain to the primary can illiminate the flooding issues.
Reflux condenser atop that,,, and you got yourself a tuneable thumper...
Postby clones2 » Sun Apr 10, 2011 9:57 am
Thanks for the advice.
clones2
Postby staggerlee » Sun Apr 10, 2011 3:07 pm
Personally, I run a 16 gal. boiler with an 8 gal. thumper. I fill the thumper to just above the inlet and on average end up with the thumper being half full after 10-12 hour runs.
staggerlee
Postby LWTCS » Sun Apr 10, 2011 3:19 pm
staggerlee wrote:I run a 16 gal. boiler with an 8 gal. thumper. I fill the thumper to just above the inlet and on average end up with the thumper being half full after 10-12 hour runs.
Kinda heat you run?
I'd shoot my self with a 10 or 12 hour run
Postby Barney Fife » Sun Apr 10, 2011 3:24 pm
Yeah, but he's talking about a 16 gallon still, LW. That said, I'd go nuts, too! Can't keep myself focused on anything for that long... ;)
Barney Fife
Postby staggerlee » Sun Apr 10, 2011 3:44 pm
Typically, about a 13-14 gal charge with propane. Slow enough just to get a pencil lead stream. It can definitely feel like an eternity at times.
staggerlee
Postby LWTCS » Sun Apr 10, 2011 4:15 pm
Pencil lead sounds good.
Didn't mean to come across like an A-hole.
I do apologize.
I'm not typically charging with much more than 7-8 gallons..recon thats the difference.
Postby staggerlee » Sun Apr 10, 2011 6:11 pm
Hey man no worries, I didn't think you came across like an a-hole at all :lol:
staggerlee
Return to Novice Distillers
Who is online
Users browsing this forum: Pikey and 5 guests
