40 ft 3/8 Worm
40 ft 3/8 Worm
Was wondering for my set up of a 3/8 inch tubing with wither 40-50 ft length in a 6 gallon igloo bucket work for a 15.5 keg with a pot still head. I know people usually go bigger on the worm but since I have so much length already was wondering if that what make up for it because it would be awesome if I could use this coil that I already have for my home-brew setup. Thank you so much guys, I want this to handle anything I can throw at it on the stripping run.
Re: 40 ft 3/8 Worm
a big issue in size isn't the volume which could be altered by length... a big issue in using smaller then 1/2 in is that if for any reason clogging or blockage occurred then you would have a major problem. i would say stick to 1/2 in tubing but thats just my opinion. im sure there are people using 3/8th with no problem but to each their own
Just-A-Sip
Re: 40 ft 3/8 Worm
+1 on the 1/2". 3/8" is just small for a keg boiler. And that's also a little long.
Re: 40 ft 3/8 Worm
It is really going to depend on how you run your still.
I use a 3/8 dia worm that's only 10 ft long and it's always worked just fine. However, even when stripping, I always run pretty slow, just enough heat to get a stream just above dripping. I also add cooling water in my flake stand so that within the temp gradient there is always cold water at the bottom.
With the 3/8 you're going to have to construct the coil very carefully, insuring that you always have downward flow. If not then the distillate will collect in the flat spots and that means trouble. 40-50 ft is a bit excessive, half that length will work, just insure the water in the flake stand never get too hot.
Big R
Big R
Re: 40 ft 3/8 Worm
Agree with 1/2" or bigger being preferable. If you're stuck with 40' of 3/8", cut it in half and run 2 parallel worms, but like big R said, be very careful about slope.
heartcut
W. H. Auden
W. H. Auden
Re: 40 ft 3/8 Worm
It sounds like a wort chiller for beer. Just bite the bullet and get the 1/2 inch.heartcut wrote:Agree with 1/2" or bigger being preferable. If you're stuck with 40' of 3/8", cut it in half and run 2 parallel worms, but like big R said, be very careful about slope.
Re: 40 ft 3/8 Worm
I am using a 3/8 worm too, but only 20ft. I am thinking it should be fine because I have an 8qt thumper for my 12qt boiler (my whole setup is pretty small to keep it apt. sized) that ought to take care of anything that gets burped up, right?
Just getting started, trying not to be another idiot building a poison mill.
Re: 40 ft 3/8 Worm
Now come on folks, 40 foot is a bit long for a keg boiler, but 20 foot is fine. Obvious really just chop it in half and use two concentric parallel worms. Double the cross sectional area and lots of surface area.
