First, thank you for taking the time to read my questions. Frist question, what the hell am I doing wrong?!!!! I have made several attempts at bending up a condensor coil. I have read plenty about how to do it, I am quite a good fabricater and rarely can not get the job done. I have 6 feet of quarter inch "soft" copper tubing left and don't want to waste it. I tryed to make the process idiot proof by first annealing the copper and then sand packing it. The well packed sand "should" be enough of a mandrel, I think. I can't make an ID bend of less then 2" without kinking or flattening the tube. In the pictures shown here on the board I have seen perfect double helix coils that could easily slip into a 2" pipe. I am trying to twist a single coil to fit into a 1 1/2' pipe. What gives?
My second question is much simpler. Is cork gasket material exceptable for use in a still?
