Affixing ferrules to columns
Postby lampshade » Tue Apr 10, 2012 10:43 pm
To avoid a lopsided column....how do you insure that the ferrule is affixed perfectly perpendicular to the column?
lampshade
Re: Affixing ferrules to columns
Postby LWTCS » Wed Apr 11, 2012 3:16 am
Good square cut for starters.
Postby NcHooch » Wed Apr 11, 2012 5:20 am
X2 ....that's pretty much it , along with a good helping of take-your-time. ;)
NChooch
3" perf-plate flute, for Carolina Boubon. Practice safe distillin and keep your hobby under your hat.
NcHooch
Postby astronomical » Wed Apr 11, 2012 6:37 am
I soldered mine in with the column on a 45 degree angle and I tapped it in lightly with a small hammer while the solder was still in a liquid state. I also cut my pipe using a mitre saw so it was very square cuts. Be careful tapping a fitting with liquid solder, it will spatter and you don't want molten tin on your arms. You'll do just fine.
astronomical
Postby Arkanshine » Fri Jun 29, 2012 9:02 am
Use a square and a tape measure, or two squares if'n you got them. A purty good hand oughtta be able to eyeball it square. It will fit purty tight and solder won't make it draw like a weld does.
Copper is the new chrome, I like the way it "shines"
Arkanshine
Postby Prairiepiss » Fri Jun 29, 2012 9:05 am
Being square if for squares. I like mine to have a cool lean to it. 8)
It'scoldaroundhere. Whenyouloseyourjacket.
My Stuffs.
Prairiepiss
Master Distiller
Postby Durace11 » Fri Jun 29, 2012 9:13 am
Even Mr. P's still has a swagger! Too 8) Mr. P too damn 8)
Current Evolution:
~ kekedog13
~Mr. P
Durace11
Postby Arkanshine » Sat Jun 30, 2012 7:06 pm
Prairiepiss wrote:Being square if for squares. I like mine to have a cool lean to it. 8)
I reckon that might save a Lil money on a 45 for a gooseneck, I hadn't thought of that :roll:
Arkanshine
Postby Bushman » Sat Jun 30, 2012 7:13 pm
Suprised nobody suggested a level!
"Beer is not a good cocktail-party drink, especially in a home where you don't know where the bathroom is" Billy Carter
The only person you need to be better than is the person you were yesterday!
Master Distiller
Location: Pacific Northwest if not on the water boating
Postby Prairiepiss » Sat Jun 30, 2012 7:17 pm
I have up on trying to make my builds perfect. It seems that its not in the books for mine to be perfect. Something always happens to screw it up. Like this last one. Just got it done installed the last sight glass. And it fell off the bench. Ugh. So I think from now on. When I get my builds done. I will just go ahead and whack it with a hammer. Just to get it out of the way. :crazy:
My Stuffs.
Prairiepiss
Master Distiller
Postby astronomical » Sun Jul 01, 2012 12:02 am
Prairiepiss wrote:I have up on trying to make my builds perfect. It seems that its not in the books for mine to be perfect. Something always happens to screw it up. Like this last one. Just got it done installed the last sight glass. And it fell off the bench. Ugh. So I think from now on. When I get my builds done. I will just go ahead and whack it with a hammer. Just to get it out of the way. :crazy:
:clap:
astronomical
Postby johnhopper1957 » Sun Jul 01, 2012 4:00 am
If you check to see if your concrete floor is level you will see it isn't, then if you check your keg when it is sitting on the ground the chances are your keg won't sit flat and may move side to side and rock a little, then when you check the ferrule that is attached to the keg you will probably see it isn't square either :)
Once you get it all square move it over to the other side of the shed and start again :)
johnhopper1957
Next
Return to Novice Distillers
Who is online
Users browsing this forum: Bing [Bot], Jimbo, THE SKRUFFY DOG and 11 guests
