Brix Reading
Brix Reading
If my refractometer reads 10 Brix does that mean my mash (unfermented) has 10% sugar? That's not a very high SG reading for a fruit mix. should I add sugar and bring it higher to say 15 brix?
Re: Brix Reading
I don't know the answer, but here is a SG to Brix conversion table that might help you out. 10 Brix is about SG 1.040 according to the table. http://www.fermsoft.com/gravbrix.php" onclick="window.open(this.href);return false;" rel="nofollow
Braz
Re: Brix Reading
10 brix is about 1.04 SG =5.3% alcohol
Re: Brix Reading
Mahalo!Braz wrote:I don't know the answer, but here is a SG to Brix conversion table that might help you out. 10 Brix is about SG 1.040 according to the table. http://www.fermsoft.com/gravbrix.php" onclick="window.open(this.href);return false;" rel="nofollow
Re: Brix Reading
Mahalo. Is there a chart somewhere or formula that converts the SG to % alcohol?Dnderhead wrote:10 brix is about 1.04 SG =5.3% alcohol
Re: Brix Reading
here's a calc.http://dd26943.com/davesdreaded/tools/convert.htm" onclick="window.open(this.href);return false;" rel="nofollow , or SG X 129=ABV (this is close,you will fiend slight variations)
if ferment stops befor 1.00 sg,,subtract FG (final gravaty) from OG (original gravaty)
then figer ABV from this NO..
Re: Brix Reading
Fixed:
Braz
Re: Brix Reading
OOPS, I meant to say convert SG to Percent Sugar. Sorry and thanks again for your help.BrooklynTech wrote:Mahalo. Is there a chart somewhere or formula that converts the SG to % alcohol?Dnderhead wrote:10 brix is about 1.04 SG =5.3% alcohol
Re: Brix Reading
Have you checked out the many calculators on the parent site...??? You should find just about every calculator needed throughout the still design, fermentation, distillation, and dilution process...BrooklynTech wrote:OOPS, I meant to say convert SG to Percent Sugar. Sorry and thanks again for your help.
Percent sugar is not a real measurement, per se, as it doesn't really reflect anything for our purpose... We just need to know how much sugar it takes to attain a specific gravity which can then be fermented to a potential %ABV which will then be distilled... That measurement is in dry weight to total wash volume... It's explained completely on the parent site which should have been part of your mandatory research... You'll never stop learning in this hobby so even re-reading multiple times never hurts...
Re: Brix Reading
Ya know I think I'm on brain overload. Now I think I was worried about % sugar in my unfermented juice when I was really thinking about the ABV of the fermented mash and worrying if I had enough to distil.rad14701 wrote:Have you checked out the many calculators on the parent site...??? You should find just about every calculator needed throughout the still design, fermentation, distillation, and dilution process...BrooklynTech wrote:OOPS, I meant to say convert SG to Percent Sugar. Sorry and thanks again for your help.
Think I'll have a cold beer and restart the brain in the morning. Many thanks for all the help and ideas.
Re: Brix Reading
{Revived this old post because it pops up as one of the firsts when you search for "Brix", and to replace old broken links.}
Here's a handy Brix/Gravity/ABV calculator: https://www.brewersfriend.com/brix-converter/
Re: Brix Reading
Thanks for sharing, I save those calc and they are very useful. Problem is when we link to other sites we have no control over the link. In the past we have had links fail. I will check if we have a conversion on the parent site otherwise in our glossary we also have a formula under the definition for brix.fizzix wrote:{Revived this old post because it pops up as one of the firsts when you search for "Brix", and to replace old broken links.}
Brix Scale a scale for calibrating hydrometers used for measuring the concentration and density of sugar solutions at a given temperature. A close but not exact formula for converting from Brix to SG is SG=1+(0.004 X Brix)
- rgreen2002
Re: Brix Reading
Bushman, maybe with the parent site being overhauled (well...it was when I left so I only assume it is still happening) maybe we could put it on the parent site if you can't find it? Brewer's friend really has some great calcs too....
Another good place would be on the Wiki page... or SMY's wiki page, or the glossary.
I'll stop now....
I'll stop now....
HD Glossary - Open this
