Water for diluting/proofing
My question is about the water used for dilution or proofing. I've searched this topic several times and it seems that most prefer distilled water. Am I right? How about water filtered through a Brita or similar filter or even bottled spring water? Any thought on this?
Re: Water for diluting/proofing
Anything short of distilled will cloud your product. But depending on how good your condenser works you can still your own.
my shizzle......13gal 3" vm.http://homedistiller.org/forum/download ... p?id=19748
E. CLAMPUS, VITUS....HANG THE BASTARD
I have used all of the above and they all work...the latest trend in scotch drinking is that if you are going to dilute the whiskey at all, the "experts" say it should be diluted with the same water as the whiskey is made from which is almost as expensive as the whiskey... I have also tried rain water... The best is collected on the winter solstice through and until Jan 21st....in a deep bowl carved from western broad leave maple
- Truckinbutch
I have also tried rain water... The best is collected on the winter solstice through and until Jan 21st....in a deep bowl carved from western broad leave maple . Hmmm ? You wouldn't have a second business guiding folks on snipe hunts would you ?
I use tap water but I add alcohol to water, instead of water to alcohol, and have never had issues with clouding...
thats crazy that you can use tap water rad i tried that once and it turned to pure shit instantly.any time i use anything but distilled it clouds albeit to varying degrees with different water but distilled is always clear for me.
I have never had any problem adding bottled water to my alcohol but have heard many times that it needs to be done the other way around to prevent clouding. I am sure it has a lot to do with temps and I have been lucky so far.
I just use the bottled water because of the taste. Distilled water has no minerals that can enhance the flavor.
Just my $0.02 worth.
I never even thought about this. I add tap water to the alcohol and never had any issues with cloudiness. Something is precipitating out. I bet its a function of water hardness but that's just a guess.
I also use tap water for proofing without clouding. I live in a very soft water area which may make a difference as it doesn't have a great deal of minerals in it, like calcium and magnesium ions.
A man who doesn't read good books has no advantage over a man who cannot read.
I use spring water from my own well. Never had a clouding issue and the water tastes good.
Same with me, I live in a fairly moderate hard water area, no problem with clouding.rgarry wrote:I never even thought about this. I add tap water to the alcohol and never had any issues with cloudiness. Something is precipitating out. I bet its a function of water hardness but that's just a guess.
If its tails you are diluting, It dont matter what kinda water you use, It will cloud up. I tried it all. Right now, if i have some good tasting tails, I use them to dilute my hi proof licker down to drinking proof. This works for me. The oils in tails will mix with licker but not water without the dreaded blue tint.
my 2 cents.
my 2 cents.
OLD MAN IN THE SHED
I have one of those fridges with ice and filtered refrigerated water on tap, I use that to dilute with. Works a treat for me.
I’m still reading and researching before I get started. I read this thread and wondered about pH of my well water and if it’s an issue for proofing down. My water is exceptionally soft but I live in an area with acidic soils so the pH is low - like 6 or below. I’ll experiment with it but just curious if anybody has any experience with acidic well water.
An additional $0.02 (for free)....R.O. (reverse osmosis) water works great. I have a R.O. filter in my home and it is excellent...I love to drink water with ice and the R.O. is “delicious”.
But the tap is great for tempering. And, it make your morning coffee taste so much better too...well worth the investment.
I’m knocking on wood (white oak, of course) while I post this: I’ve never had any issue with clouding when tempering down with tap water, bottled spring water, or distilled water. I think a lot of the “clouding” is associated with going too deep into the tails — which is fine if it tastes good. Lately I’ve been adding Distilled water to alcohol while it is spinning in the jar. So far, so good.
We do have a water softener on out house. No idea how it works it was just there when we moved in. Buy uses salt to remove chlorine and calcium I believe. We then have the normal carbon filter on the drinking tap.
Sooner or later the people who run the planet all end up choosing one drink....
Hmmmm....OK. You’ve got an “outhouse” with running water. Now, that’s a modern convenience!
Haha! Our house! Although toilet water would explain the colour.still_stirrin wrote: ↑Sat Aug 08, 2020 2:49 pmHmmmm....OK. You’ve got an “outhouse” with running water. Now, that’s a modern convenience!
Hi everyone!
I'm just starting to craft gin. I diluted it with bottled water without any issue.
Is the use of distilled water only to avoid cloudiness? I think a good quality mineral water can be better for the final product.
I use distilled water and also add alcohol to water not water to alcohol
Stainless pot with copper shotgun I'm a simple kind of guy
I don't use distilled water or mineral water, I use RO water. All will louche if there is enough oils concentrated in the gin essence to make that happen at your desired dilution.
If you want to write 'mineral water' on the label, use it. You might have to dilute the gin flavors a bit more than you would have to if you used some kind of de-mineralised water and don't want cloudy gin.
I use RO drinking water as well. Very little flavour or minerals in the water and it tastes fantastic. Works really well and I never have cloudy issues.
