Baking Soda
Baking Soda
Postby Froggy » Wed Jan 09, 2008 4:06 pm
I have about 12L of 40% cloudy spirit which I'm going to cook off again. I've been reading on here about mixing bicarbonate soda in with the spirit for a week or so before running through the still.
A few of the more in depth threads on here had many posts for and against the idea.
So my question is how many on here use this method and do you notice any real improvements?
Here froggy froggy..
Shane
Our reading material:
The Compleat Distiller
Making Pure Corn Whiskey
Froggy
Postby BW Redneck » Wed Jan 09, 2008 4:24 pm
Bicarb works great. It dissociates into NaOH ions and they chew up a lot of various esters and aldehydes and clears up a bunch of funky flavors. Mix about 1 tablespoon per quart.
Only recommend it for neutral spirits. Can turn a malty whiskey into flavorless hootch.
"If you can't dazzle them with brilliance... baffle them with bullshit."
"Don't steal. The government hates competition."
"Believe none of what you hear, and only half of what you see"
20lt small pot still, working on keg
BW Redneck
Postby Froggy » Wed Jan 09, 2008 4:33 pm
Thanks mate.
One quart is roughly one litre isn't it?
Shane
Froggy
Postby BW Redneck » Wed Jan 09, 2008 4:56 pm
Right. I wanted to say litre, but I thought it'd seem odd that I used US and metric to refer one quantity to another. :roll:
BW Redneck
Postby Froggy » Wed Jan 09, 2008 5:57 pm
No worries mate.
Shane
Froggy
Postby Bsnapshot » Wed Jan 09, 2008 6:06 pm
Do you add the baking soda during the stripping run or the spirit run? Do you add it the same day or days before the run?
Does the baking soda do the same as adding salt like I seen in some other post
Bsnapshot
Postby HookLine » Wed Jan 09, 2008 6:28 pm
No, after the stripping (low wines) run, before the spirit run
Add it straight after the stripping run, and let it sit for a week or so, stir it up at least once a day.
Explanation here.
Be safe.
Be discreet.
And have fun.
HookLine
Master Distiller
Postby mikeac » Wed Jan 09, 2008 8:33 pm
BW Redneck wrote:Right. I wanted to say litre, but I thought it'd seem odd that I used US and metric to refer one quantity to another. :roll:
You'd be from Canada if you did... :lol: tablespoons and liters are directions I can understand
mikeac
Postby Bsnapshot » Thu Jan 10, 2008 8:35 am
I read the explanation on the parent sight but still a little confused.
So the baking soda and the salt do two different things and both should be added? the salt highers the boiling temp for the water and helps with separation and the baking soda helps with removing off flavors and nasties? Or am I wrong on this?
Bsnapshot
Postby HookLine » Thu Jan 10, 2008 10:01 am
Sounds about right. I am pretty sure that most do not use salt, but most do use bicarb (or sodium carbonate, at 1 tsp per litre).
This is for neutral spirits, of course, not flavoured spirits.
Be safe.
Be discreet.
And have fun.
HookLine
Master Distiller
Postby oakie » Thu Jan 10, 2008 11:41 am
Personally I never use salt. I do how ever use baking soda. I add baking soda and freshly charred toasted wood to my low wines (for neutral spirits) and let sit for a couple of weeks. (shaking it once a day) I then run my spirit run. The spirit is a lot smoother and I end up with a little more when I use this method then when I don't.
oakie
Postby stoker » Thu Jan 10, 2008 1:31 pm
BW Redneck wrote:... It dissociates into NaOH ions ..
that's not correct, but the results will be simular, though bicarb is not as strong as NaOH, it might not react with the esters, but will react with acids, but I doubt how much acid is present in low wines. therefore, I think the bicarb has most of its influence during the run, more then before. at higher temperatures.
does anyone want to make experments of a good quality? NaOH, bicarb, before, after run, ... would be interesting.
-I have too much blood in my alcohol system-
stoker
Next
Return to Novice Distillers
Who is online
