Any reason to temp control a done wash?
Is there any good reason to keep a wash temp controlled even after is finishes? Or is it possible for residual active yeast to still contribute off flavors even if its technically done?
Re: Any reason to temp control a done wash?
When a wash is done, it is best rack it off its sediment/lee, and keep it cool.. it is not necessary to keep it at the fermentation temperature level.. kept off the lee and in an inclosed container, it will keep for a few month before being process..
Mars
Mars
– Albert Einstein
– Albert Einstein
- Rain Distillate
To minimize residual yeast in your wash- cool it down for a few days in a cool garage, refrigerator if you have the space or something similar. This is because solids settle faster and easier under cooler conditions.spiff wrote:Is there any good reason to keep a wash temp controlled even after is finishes? Or is it possible for residual active yeast to still contribute off flavors even if its technically done?
Rack it good (don't be greedy, sucking too close to the bottom or the rack was a waste of time)
Then store it like you would any other wine or beer.
Airtight to keep out infections. Many folks don't rack though. Personal preference I guess.
IMO this is the safest way to hold a wash as long as possible. If you rack it and it's just clean beer inside a clean container and it's airtight the alcohol should preserve it for awhile!
Rain Distillate
Thanks for the replies. That makes sense.. remove the sediment from the equation then its a non-issue.
But what if I was lazy and I only wanted to rack it once, into the boiler? So it'll be sitting a week with spent(partially?) sediment..what would you do then? Control or not control? I'm thinking playing it safe and just keep it modulated....
Here something you may want to try.. get some small jar, baby food jar work good for this.. when the wash has finished fermenting and has started to clear, take a sample of the wash and put it in one of the jars.. wait 2 days and do the same thing again.. now taste the first jar vers the second jar, and you will see a different in taste overall.. this different also carries across to the finish product.. and you can take this up to any numbers of time you want to determine when you should rack it off its lee.. by keep notes, it will help to determine each wash when they are finish..spiff wrote:But what if I was lazy and I only wanted to rack it once, into the boiler? So it'll be sitting a week with spent(partially?) sediment..what would you do then? Control or not control? I'm thinking playing it safe and just keep it modulated....
Making a wash for liker is in many way the same as in wine making..
Mars
– Albert Einstein
– Albert Einstein
I think that is very true - Except - in wine making, we aim for an abv 11-15% as a rule, plus hygiene and cleanliness are highly addressed and the importance of excluding air and especially the vinegar fly are paramount.StillerBoy wrote:............
Mars
Having said that, winemakers sometimes leave their wine settling for several months and I have a whisky sugarhead which has been sitting for a good three months, with me just taking a run out if it every two - 3 weeks or so, without detriment. It is however kept cool <45 degree F.
The higher the alcohol in your done wash, the better it will keep, like say a bottle of sherry which has been opened. Whereas a low abv wash will not keep nearly as well (like an opened bottle of beer).
Thanks again..
That's a good thought taking samples. Problem is, the last (and only time so far) time I had a bad wash I couldn't tell until after I ran it and then I could smell that almost the whole run smelled and tested like tails except perhaps the high heads and fores. So i'm not sure that would work.
I was just curious what most folks do and it sounds like most folks prep for a dormant period by racking it somewhere. I only need to delay a week so for me I'm thinking its best to play safe and just leave it.
A week, in the whole picture, will probably not make much of a difference, especially if is not a repeated wash.. I like to able to duplicate my wash as close as possible within reason.. therefore one of my habit is to rack it once I determine its finish off its lee, then I store it for a few days to a couple of weeks.. never had a wash go bad in storage and I ferment for a level of 11%..spiff wrote:I was just curious what most folks do and it sounds like most folks prep for a dormant period by racking it somewhere. I only need to delay a week so for me I'm thinking its best to play safe and just leave it.
Mars
– Albert Einstein
– Albert Einstein
Right on.. Guess I'll keep rolling with the status quo since its been working. In hindsight now it seems stupid to risk 26 gallons of wash and 1.5 weeks investment to save pennies of heating power.
Thnaks again
Thnaks again
Why would you want to keep it warm? I would think, rack it or not, but store it cold.
Well, my thought was that if there were still any residual active yeast that any cold might make them add off flavors like a cold ferment might do. To head off any suggestion that I'm not waiting for it to finish, it is. But I don't think that all the yeast just suddenly stops like a light switch.. there could be SOME activity going on. Just trying to prevent off flavors no matter how minuscule. I don't do the extra week I read about some people doing to let their wash clear.. sort of the same thing.. So I'm wondering if they're continuing the temp control on that clearing period.
It depends what you're making.
For rum, flavor is still developing after it goes dead, so I keep the controller on for another six days to keep it at tropical temperatures, but I turn the controller off for a Birdwatchers if not running it immediately.
I don't rack and clear anything flavored and don't know of any good reason to do it unless you are industrial and run a continuous column 24/7. It gives a chance for O2 inclusion and infections, which are reasons not to.
Yes and nospiff wrote: Is there any good reason to keep a wash temp controlled even after is finishes?
Some folks think leaving a fermenter "warm" for a couple days after the SG hit's rock bottom
Gives the yeast a chance to clean up after itself.
Possibly. Depends on your yeast I think. Just my own idea, but I feel some of the "Acetone" flavour that comes with a "Turbo" may come from the yeast attacking the cellulose in dead yeast cells. I wonder whether some of the "Off flavours" associated with other aggressive yeasts may come from interaction with dead yeast cells as they autolyse ?shadylane wrote:Yes and nospiff wrote: Is there any good reason to keep a wash temp controlled even after is finishes?
- Rain Distillate
+1StillerBoy wrote:Here something you may want to try.. get some small jar, baby food jar work good for this.. when the wash has finished fermenting and has started to clear, take a sample of the wash and put it in one of the jars.. wait 2 days and do the same thing again.. now taste the first jar vers the second jar, and you will see a different in taste overall.. this different also carries across to the finish product.. and you can take this up to any numbers of time you want to determine when you should rack it off its lee.. by keep notes, it will help to determine each wash when they are finish..spiff wrote:But what if I was lazy and I only wanted to rack it once, into the boiler? So it'll be sitting a week with spent(partially?) sediment..what would you do then? Control or not control? I'm thinking playing it safe and just keep it modulated....
Mars
