strawberry in thumper
OK I made a mash of water, sugar, strawberries, and cocoa. the first time I ran it, you could taste the chocolate really good but no strawberry. so for this run I am thinking of putting strawberry extract in the thump. Question is, should I start with the extract in the thump or put my backings in the thump until I collect a bit and then dump the extract into it? thanks!
- Truckinbutch
Re: strawberry in thumper
Double or triple run your likker to the point that you no longer need to worry about cuts . Dilute that to under 40% abv and charge your boiler with it . Put your flavoring mix (or a cooked and strained version) in the thumper and run one more time and collect everything .
- Rain Distillate
If your looking for strawberry flavor why not take some of your strawberry mash, add some strawberry extract to it and then put it in the thump keg? Might help?
^^^ was thinking of doing just that too
If you're going to use extract, why put it through the thumper when you can add it straight into the likker?
- Rain Distillate
NZChris wrote:If you're going to use extract, why put it through the thumper when you can add it straight into the likker?
I think he's looking for a more authentic strawberry shine taste w/o having to say he added an extract to final product. Correct me if I'm wrong.
Also the abv would still be high as opposed to adding extract later and diluting it.
If you want authentic, put real strawberries in the thumper or gin basket and run the likker through it. I slice them. Raspberries I put in whole.rain distillate wrote:NZChris wrote:If you're going to use extract, why put it through the thumper when you can add it straight into the likker?
If you're going to infuse starwberries for a flavour, beverycarefull how many - the flavour goes a Long way !
So I went a head and tried the wash in the thump with a small bottle of extract. Now it taste like a chemical. So lesson learned. I guess I will run it hard with water in the thump to try to clean it up and just make the panty dropper. So I learned my lesson to use real fruit in the thump and NOT extract!
