Flavoring
Flavoring
I just did a 5 gal apple run. 20 lbs of apples peeled, cored and juiced. 2 Gallons 100% apple juice. 10 lbs sugar. Total was 5 gallons. Alcohol content roughly 12% based off Specific gravity test before and after fermentation. 1 QT concentrated apple juice in thumper. Ended up with 3/4 gallons 100 proof keepable/drinkable. No apple flavor at all. Had the apple smell though. Without using extracts how do you get the natural flavors of the fruit to carry over into product?
Re: Flavoring
Sugar makes neutral, so you effectively made apple brandy but diluted it with a large dose of neutral.
- Truckinbutch
Re: Flavoring
Little light on the thumper charge . Also , more apple flavor may develop with age .
- cranky
Re: Flavoring
As Chris pointed out, adding sugar takes away flavor in addition removing the peel before juicing takes away flavor and as TB pointed out apple may take some time to develop the apple flavor. Apple can be hard, the flavor is usually in the heads and can take a while to show itself. When it does, hopefully what you will wind up with the ghost of the fruit you started with. Give it time and see what develops.
Re: Flavoring
Good advice given, when I am making apple brandy I shoot for 8% in my fermentation. I am guessing you added yeast, which one did you use?
Re: Flavoring
So would you recommend leaving the peels on?
Re: Flavoring
I use Red Star Dady Distillers active dry yeast from LD Carlson
- cranky
Re: Flavoring
Yes.MrBrew69 wrote:So would you recommend leaving the peels on?
The problem with DADY is it is a grain yeast. My personal opinion is you need a cider or wine yeast for best results with brandy. I will say that some people swear by some ale yeasts like S-04, US-05 or Nottingham. I like wine yeasts myself and always recommend using EC-1118 for brandy until you get the hang of it then branch out to other yeast. Cuts on 1118 are distinct and easy where others yeasts can make cuts pretty difficult and apple flavor tends to come over in the heads which can add even more challenge to getting the flavor.MrBrew69 wrote:I use Red Star Dady Distillers active dry yeast from LD Carlson
Re: Flavoring
Excellent. Thanks for the info. Will order some up.
