Copper bits in Potstill changed color.
- Winebibber
Hi all,
I recently finished a 28 Lit. of Wineos plain ol sugar wash stripping run in my simple SS pot still with copper worm condenser (no reflux column right now). I used to put few pieces of thoroughly cleaned copper as boiling chips in the potstill. After successfully completing the run, I found that the copper chips were clean and shining as before, so I simply cleaned them with water and reused them for the spirit run. My low wines were also very clear.
After the spirit run, when I removed the copper bits, they were badly discolored. My final distillate started at 79% abv, I made the possibly proper cuts and collected up to 11% abv. The distillate is sparkingly clear with apparently no bad taste or smell.
I'm worried about the discoloration of boiling chips however. Is it normal or I am doing some mistake? I'll be thanklful for any guidance.
Re: Copper bits in Potstill changed color.
What's the pH of the water used to dilute the low wines for your spirit run ? I'll bet it's slightly alkaline ( 7.4 - 7.8 ).
________________
- Winebibber
I did not use any water to dilute the low wines. I collected the low wines starting at 56% abv and ended at 13% abv. The average abv was 36%, so I used it straight for the spirit run.greggn wrote:What's the pH of the water used to dilute the low wines for your spirit run ? I'll bet it's slightly alkaline (7.4 - 7..
Make sure it is copper and not an alloy or plated. Does it bend and scratch like copper?
- Winebibber
Yes, I think it is pure copper. It bends and scratches easily, and is soft enough. It was a copper plate of around 2.5" diameter and 1.2 mm thick, cut into four pieces . Similar to another plate available with me posted below. I have now socked those bits in vinegar and I'll see if they can come clean after few hours.NZChris wrote:Make sure it is copper and not an alloy or plated. Does it bend and scratch like copper?
- Winebibber
I soaked the copper bits in vinegar for about 10 hours and cleaned them with water and a scrub. Now they are clean and sparkling. It is not clear to me why this discoloration happened. Any idea please?
I have always run copper in my boiler , I have never seen it go that colour.
Did you drain the boiler and leave the copper in there for a while before removing it, oxidization could be one thing that might make it go that colour.
- Winebibber
Yes, after draining the boiler fully I let it cool down for an hour or two before picking up the bits. Does the oxidization process starts that fast? Should I worry about the quality of the distillate or continue using those copper bits in my next runs?Saltbush Bill wrote:I have always run copper in my boiler , I have never seen it go that colour.
I think that is your problem then, Ive seen copper go that colour when left wet and in a damp environment.Winebibber wrote:Yes, after draining the boiler fully I let it cool down for an hour or two before picking up the bits
Not in my opinion, looks like perfectly good copper to me.Winebibber wrote:Should I worry about the quality of the distillate or continue using those copper bits in my next runs?
Greggn would you like to explain to me why you think the PH was responsible for this issue and how it made the copper go that colour? I find it interesting that any thing and everything that cant be explained easily is blamed on PH.greggn wrote:What's the pH of the water used to dilute the low wines for your spirit run ? I'll bet it's slightly alkaline ( 7.4 - 7.8 ).
- Winebibber
Thanks Saltbush Bill, for the kind advise. I'll go ahead with my next batches with due care for this.Saltbush Bill wrote:I think that is your problem then, Ive seen copper go that colour when left wet and in a damp environment.
Given the OP's statement above that suggested the discoloration occurred *during* the run ... not from sitting around some time afterward. Since it was a sugar wash I thought water chemistry was a reasonable culprit. I profusely apologize for my silly, uneducated assumption.
________________
- Winebibber
Oops! I am sorry Greggn, for your inconvenience. As a novice, I didn't recognize the importance of idle time element lapsed before taking out and examining the bits after the spirit run. I couldn't represent the whole incidence in proper words. My bad!greggn wrote:>Greggn would you like to explain to me why you think the PH was responsible
Thanks for all the thoughts, guys.
