testing proof after adding sugar, water and flavoring???
- Hoosier Shine9
I am not sure if there is a way to test proof of "finished" fire piss. (500ml of sugar & water 300ml cinnamon infused 93%)
I know that adding sugar to water will change Specific Gravity of the liquid.
I have been using math to "guesstimate" the finished proof.
300ml of 93% abv plus 500ml water&sugar = 800ml of finished firepiss
therefore I have 3/8 of the total volume @ 93%abv
take 3 and divide by 8 (3/8) = .375
multiply 93 by .375 = 33.75
therefore 33.75% abv or 67.5 proof
but is there a way to test that this is true???
thanks in advance
thanks in advance
Re: testing proof after adding sugar, water and flavoring???
I reckon 300ml @93% = 279 ml ethanol
now spread that over 800 ml so 279/800
=34.875% abv ?
=34.875% abv ?
http://www.vinovation.com/Pearson.html" onclick="window.open(this.href);return false;" rel="nofollow
- Hoosier Shine9
I know the math will give the answer at bottling.
but is there a way to "test".
with a testing devise of some sort. I know that a hydrometer/alcoholmeter will NOT work due to the sugar content.
like using a hydrometer to test potential, or an alcoholmeter... proof & tralle, or a refractometer Brix.
the reason I ask. Gave some Fire Piss to a buddy. he said "taste was great but no buzz, like it had no alcohol in it".
I want to see if I have had an excessive "angles share (or kids share)" loss since bottling.
Not as far as I know. I've seen something somewhere about a complex methiod of distillation, which is supposed to get there.Hoosier Shine9 wrote:I know the math will give the answer at bottling.
Bet I know what the "Problem" is - Heads cut - Put the heads back in and try again
Edit:
If you were to make a "Mini-still" distill a measured amount of your finished brew, right up to BP = 100 or 101, (C) then you could measure the abv of your distillate and use teh above process to back calculate the original abv. Bit of a clat I know but best I can do
Here is a link to the TTB on proofing spirits. https://www.ttb.gov/spirits/proofing.shtml" onclick="window.open(this.href);return false;" rel="nofollow
They show 2 different methods to proof high dissolved solids spirits (like yours). One method is to distill the other is to evaporate. Considering that you aren't trying to meet TTB standards, I would just calculate it. By the way you had a simple arithmetic error. Pikey's math is correct.
For personal curiosity there's a formula in this article that may get you close. But if you're proofing it for bottling that requires precision, I wouldn't use it.
https://tickledpalate.wordpress.com/201 ... r-liqueur/" onclick="window.open(this.href);return false;" rel="nofollow
Sator Square Distillery
DSP-PA-20063
DSP-PA-20063
Yeah Pikey's thoughts remind me of a story Kentucky Shinner shared with the group a while back.
Most newbies get obsessed with very strict cuts. So,, true to form KS did too at the time, and shared some high proof with some friends. Well evidently his friends were so used to drinking bogg water that they claimed they "didn't get drunk enough" even though they were drinking higher proof spirits.
Very clean high proof can give a short "upper" kinda buzz. Like a light, high energy feeling rather than a heavy, down feeling. But then also dissipate rather quickly.
- Hoosier Shine9
I am very skeptical about the theft. but want to try to eliminate any potential questions in my mind.Pikey wrote:Not as far as I know. I've seen something somewhere about a complex methiod of distillation, which is supposed to get there.Hoosier Shine9 wrote:I know the math will give the answer at bottling.
Edit:
[quote LWTCS » Wed Aug 30, 2017 3:46 pm
Very clean high proof can give a short "upper" kinda buzz. Like a light, high energy feeling rather than a heavy, down feeling. But then also dissipate rather quickly.][/quote]
I have a feeling this is the issue......
I have a feeling he is use to drinking "low dollar" . he did say "only a light buzz that disappeared real quick".
I guess I have a few options.......educate him, keep crappy cuts for him, or tell him to get the crappy stuff from the store..............lol
Hoosier Shine9 wrote:I am very skeptical about the theft. but want to try to eliminate any potential questions in my mind.Pikey wrote:...Bet I know what the "Problem" is - Heads cut - Put the heads back in and try again...Hoosier Shine9 wrote:...Gave some Fire Piss to a buddy. he said "taste was great but no buzz, like it had no alcohol in it". I want to see if I have had an excessive "angel's share" (or kids share) loss since bottling.I have a feeling this is the issue...I have a feeling he is use to drinking "low dollar". He did say, "only a light buzz that disappeared real quick".LWTCS wrote:Yeah Pikey's thoughts remind me of a story Kentucky Shinner shared with the group a while back.
Most newbies get obsessed with very strict cuts. So, true to form KS did too at the time, and shared some high proof with some friends. Well evidently his friends were so used to drinking bogg water that they claimed they "didn't get drunk enough" even though they were drinking higher proof spirits.
I guess I have a few options...educate him, keep crappy cuts for him, or tell him to get the crappy stuff from the store.<-- THIS!! If he complains about "free booze"..let him pay at the store.
- Hoosier Shine9
SS
that was the option I was leaning towards.....lol
Give him a sobriety test next time he drinks it. If iys just a clean buzz, he's a lot drunker than he realizes.
Have to say - I've started putting som heads an early tails back in my "Flavoured stuff"
Of course, otherwise it isn't "Flavoured stuff". My best Bourbon has a bit of late heads, middle tails and "sweetwater" in it.Pikey wrote:Have to say - I've started putting som heads an early tails back in my "Flavoured stuff"
- Hoosier Shine9
An update.......the same buddy asked me for some more of the "Fire Piss" this past Friday.
I told him go to the store, buy some ever-clear,& some cinnamon sticks, and come to see me. he didn't like that.......
Good advice for you're buddy lol nice to see a fellow Hoosier here.
http://homedistiller.org/forum/viewtopi ... 15&t=68702 Grate learning tool for cuts.
Is it wise to piss off somebody who knows about your hobby?
He complained about your product earlier. I understand your feeling, but maybe an other trick would have been wiser?
Best to cutoff the mooch early...especially if he's bitchin' about free booze. Let him "make" his own...if he's so critical.Kareltje wrote:Is it wise to piss off somebody who knows about your hobby?..He complained about your product earlier....
I'm with K - LOad a bottle with heads (no fores) and add some tails - leave the hearts outstill_stirrin wrote:Best to cutoff the mooch early...especially if he's bitchin' about free booze. Let him "make" his own...if he's so critical.Kareltje wrote:Is it wise to piss off somebody who knows about your hobby?..He complained about your product earlier....
If he's a good buddy just use a bit more high proof for the bottle and if he's just an acquaintance cut him off asap.
