@# Dag-Nabit!!#*$!!
Posted: Wed Oct 11, 2017 1:25 pm
by Chixter
Routine check. Spray sanitize on hydrometer, shake to remove excess......snap..jingle jingle. These things will break if ya look at them the wrong way. Should be sold in 6 packs.
Re: @# Dag-Nabit!!#*$!!
Posted: Wed Oct 11, 2017 1:43 pm
by still_stirrin
I have my original from 30 years ago. Must be "operator error"!
Posted: Wed Oct 11, 2017 2:25 pm
by Chixter
30 years??!! That thing still good?. Also if ya got it 30 years ago it must be better quality than the Chi-Com stuff we get now.
Posted: Wed Oct 11, 2017 2:31 pm
by greggn
... and now you have a good reason to buy a refractometer.
Posted: Wed Oct 11, 2017 2:32 pm
by dieselduo
get you a refractometer with ATC
Posted: Wed Oct 11, 2017 2:35 pm
by Chixter
greggn wrote:and now you have a good reason to buy a refractometer.
Done.
Posted: Wed Oct 11, 2017 2:44 pm
by shadylane
still_stirrin wrote:I have my original from 30 years ago. Must be "operator error"
Do tell
And here's the place.
http://homedistiller.org/forum/viewtopi ... start=5010
Posted: Wed Oct 11, 2017 2:51 pm
by shadylane
Chixter wrote:greggn wrote:and now you have a good reason to buy a refractometer.
Done.
A refractometer is a great tool, Don't forget, it isn't accurate once fermentation starts and alcohol is present
Posted: Wed Oct 11, 2017 3:17 pm
by Chixter
shadylane wrote:A refractometer is a great tool, Don't forget, it isn't accurate once fermentation starts and alcohol is present
I read that here a while ago. So I just bought a hydro to do both, cuz I like to measure FG. No worry, I bought a hydro replacement and a refract. SS is kind of right....I was holding by the stem and shook a bit to aggressively...inertia due to mass and all. Live/Learn.
Posted: Thu Oct 12, 2017 2:57 am
by greggn
Do you not find the conversion calculations to be accurate enough ? I measured OG/FG over many ferments using both a hydrometer and a refractometer and found they tracked closely enough (for personal needs) that I retired the hydrometer.
Posted: Thu Oct 12, 2017 3:11 am
by bilgriss
Shake it, but don't break it.
Come to think of it, I don't shake it. Broke too many that way. I always rinse and give it a wipe on the hand towel hanging on the stove.
Posted: Thu Oct 12, 2017 3:26 am
by der wo
The problem for me is, that different refractometer calcs give out different results. I searched but I don't find the thread about it again.
And in general it looks not very exact:
Posted: Thu Oct 12, 2017 3:31 am
by Yummyrum
bilgriss wrote: and give it a wipe on the hand towel hanging on the stove.
OMG
bilgriss .... my OCD is screaming germphobia .... hope you don't periodically dip it in a ferment
Got to be as bad as Salt Bush Bills grubby fingers
....@Salty
Perhaps this is why we have a sudden rise in mysterious infected washes
BTW : I'm still using my original Hydrometer thats over 12 years old ..... Alcomters are another story .... perhaps the use of alcometers happens to coincide with alcohol consumption
Posted: Thu Oct 12, 2017 3:48 am
by greggn
Too large a sample produces that undefined edge ... just enough liquid to create a thin film will result in a distinct reading. Also, the type of light seems to affect the "distinctness" of the reading. Sunlight is best, artificial gives mixed results depending on source.
Posted: Thu Oct 12, 2017 2:34 pm
by Shine0n
Looks like 1.043-1.044 to me
Just slightly more than 11 brix
Posted: Thu Oct 12, 2017 6:27 pm
by Oldvine Zin
Shine0n wrote:Looks like 1.043-1.044 to me
+1
Yup and that's as close as you will get with a non certified hydrometer, my refract works just fine for me.
OVZ
Posted: Thu Oct 12, 2017 7:13 pm
by cob
bilgriss wrote:Shake it, but don't break it.
you are not supposed to shake it like your mama's rectal thermometer.
Posted: Thu Oct 12, 2017 7:50 pm
by HDNB
Posted: Thu Oct 12, 2017 10:05 pm
by Oldvine Zin
or you are playing with it
OVZ
Posted: Fri Oct 13, 2017 2:08 pm
by iwine
Watch not to go blind. When you shake that !
Posted: Sat Oct 14, 2017 5:37 am
by bilgriss
I've found the refractometer to be very accurate for an unfermented wort. Looks like Der Wo might need to adjust focus or (like me) put on an extra set of reading glasses to see the little tick-marks. Post-fermentation it's not quite as spot-on, but if you look up the mathematical correction (or use a calculator) it's pretty close. If you are looking for absolutely exact numbers, you need to use a calibrated hydrometer, but I don't see where perfection of computation helps much at that point.
As for the grubby wipe on the hand towel...... relax. Sanitize before you use it again, if you are so inclined. Remember people make a fantastic product in their sheds with the mice and dirty plywood over their fermenters. We're distilling this stuff, so it's not like homebrewing where you're trying to prevent infections while it rests before drinking. Broken glass is a bigger problem.
