If I was a city boy I'm sure I'd want to hang with the kool kids going electrical. I've watched a few runs here and in the US and the duel elements with one controlled are the bee's knees but ..... one ya need the surplus power supply, two the set up cost is harsh and three gas back up system is still wise to have. Elements don't work great in blackouts nor are they easy to run thick ferments, guys running fruit washes like plums would either waste a lot or have a dern nightmare on their hands. Thing is with pulpy fruit is the last run of Marc has a hell of a lot ( read most of the) flavour so not running it is loosing a lot more than just alcohol. The answer here is horses for courses. Ya want loud burners? Wish I still had pictures of my crab cooker burner build, on another forum years ago a guy posted instructions for a simple burner we called the BD747, that guy big don is a member here but hasn't longed in anywhere for years, guess why it's called a 747 high reg full blast the flame was prolly 10 or 12 foot high and set off the neighborhood car alarms . I used it for a fair while but turned down enough for stilling it would soot the kettle something awful.
I never had serious scorch issues with gas not even plum chutney and that burner.
Gas or electricity
- thecroweater
Re: Gas or electricity
I can say I look back and say “I will never use open flame around distillate ever again...”HDNB wrote:Larry will be so happy.
Go electric, you'll never look back.
I use dual water heater elements,I like the way 220 volt elements ran on 110 feel.good heat up times and no scorching knock on wood.
I also do multiple rackings
All right, that makes a difference.acfixer69 wrote:If doing a slurry the internal elements would never be used.Kareltje wrote:An externally fired boiler has a clean, empty bottom. A simple rotating chain can clear the bottom.acfixer69 wrote: Why would a stirrer be more difficult? I just would be designed to clear it or them. Same as to clear the bottom.
AC
When internal elements heat the slurry, the scorching is on the elements and they need to be cleaned or wiped every so often.
Cleaning these protruding elements is more complicated than cleaning a simple bottom.
AC
But then using a stirrer is beyond my imagination. But my elements are vertically protruding upward from the bottom. Maybe when your elements are horizontal, you could stir under them.
I saw an episode of Moonshiners (yeah, I know: ) where Digger and his pall made a kind of tunnel in their boiler and a long burner inside it. That to prevent scorching.
I like this thread: it surely shows how everybody finds his own solutions for his problems. And all are good!
Anybody uses a wood fire? Or alcohol?
