Quick question from newbie
I just purchased a 7 ft piece of 3 inch type m copper pipe for 25 bux at a sale. My question is, to use this on a keg, can I just get a 2 in to 3 inch coupler for a keg still, or to get the most out of it, do I need a bigger opening in the keg?
Re: Quick question from newbie
Short answer is yes, it is the easiest way to do it. I have a 4" column and I cut my opening to fit the positive is it makes cleaning easier but it was hard to weld the ferrule as the top of the keg because it has different thicknesses and making sure it was perpendicular so the column was vertical is important.
- Twisted Brick
Nice find on the 3" copper, Trebor.
A lot of guys use a 2 x 3" reducer. You can get 'em for $10 plus shipping. Like Bushman says, it eliminates the hassle of welding a SS ferrule on. Slap a couple of ferrules on your pipe and bob's your uncle. What kinda still you gonna make?
This is what mine looks like.
Ok thanx guys . I didn't want to have to mess with welding on the keg
Just a pot still to start. Just started this hobby. Been using a 3 gallon copper still. I like the idea of a Nixon stone though
Twisted Brick’s solution is mighty nice. I bet it makes a good drop. The 3” allows the vapor to slow in the riser, which will cause a little expansion (and light passive reflux). That’ll help the vapor stabilize during the run. The riser doesn’t need to be tall, in fact, what you’ve got TB is about perfect for the vapor production rate.
So trebor66n2, I strongly suggest you consider a potstill to start. It’ll get you a fantastic stripping tool, plus it’ll make you a great flavored spirit on a spirit run....(2X).
A Nixon/Stone is a good LM design, but really is best suited for neutrals...vodka and NGS. Those are building blocks for other “flavored” spirits, ie - gin, etc. (often quoted...”patience is the hardest thing to get into the bottle”)
So, focus first on your fermenting skills and make sure you can get repeatable results from the fermenter. A potstill will get you some flavorfull product to get into an aging barrel quickly...and then the wait for maturity from the cask.
Everybody dreams of making 190 proof spirits from their still....but the real producers rarely push the product that high, unless intended for a secondary product...maceration, etc. A functional potstill...with a skilled operator is more valuable to the consumer. Believe me...your friends will appreciate the flavored spirits better...because they’re true “small batch” products.
- Twisted Brick
+1still_stirrin wrote: So trebor66n2, I strongly suggest you consider a potstill to start. It’ll get you a fantastic stripping tool, plus it’ll make you a great flavored spirit on a spirit run....(2X).
I went modular with my length of 3", and to be perfectly honest, I'm so pleased with my pot still results, its gonna take me a while to get around to making a neutral with my column.
I agree still_stiirrin. The patience is something I last. At 52 I thought is know better, lol. While I was waiting for my 3 gallon still to arrive , I was dreaming big. I actually don't need anything bigger than my 3 gallon still. YET.
- Twisted Brick
I don't believe it! Once you hook up your fine copper pot still head to a 15gal keg, you cut your stripping time in half, create enough low wines for 1 spirit run, and badda bing!trebor66n2 wrote: I actually don't need anything bigger than my 3 gallon still. YET.
