Usual time for boil with 1500 watt hotplate
Postby T-type » Sat Feb 14, 2009 3:39 pm
I have a 1500 watt hot plate and seems like my 7.75 gallon stainless keg with water is taking forever to boil. Its going on 3 1/2 hours now.
the hotplate is a cast iron element btw,
Does it usually take this long to get that much water boiling.
Since im just testing out my equipment now, i just didnt think it'd take that long to bring it to a boil.
T-type
Re: Usual time for boil with 1500 watt hotplate
Postby brewmaker1 » Sat Feb 14, 2009 4:53 pm
If you're using the diffuser plate, it'll take several hours. I tried the hot plate two times and then spent $30 on a turkey fryer and Lowes. Now the hot plate is used for disolving sugar.
brewmaker1
Postby T-type » Sat Feb 14, 2009 5:11 pm
Diffuser plate? mine is a cast iron element commercial grade it says.
I have a a 1/2" thick steel plate on my welding table thats about 15" by 12" i dunno if i need it for my keg
T-type
Postby inGOODspirits » Sat Feb 14, 2009 5:58 pm
atjones, brewmaker is right, get a turkey fryer and a propane tank. I have just switched to two 1500w hot water heaters but thay are inside of the boiler. One is hooked up to a on/off switch and the other is on a controller. A 1500w external heat source will not be enough.
25th
inGOODspirits
Postby T-type » Sat Feb 14, 2009 6:00 pm
Damn i guess i should of asked b4 i bought a hotplate...
You meen 1500 watt hotplate cant boil 5 gallons? hows come?
T-type
Postby inGOODspirits » Sat Feb 14, 2009 6:14 pm
if you are using a sankey keg than the ring on the bottom will lift the boiler off the plate. Thoose hot plates i believe are for the presure cooker style stills and usually the boiler is about half that size. The turkey fryer is a good method but you have to watch the open flame. You can find them for about $50. Water puts out alcohol fires quite well but be prepaired. How come? volume and heat loose. I tried cooking a "hot bonnet" pepper sauce with a 1000W and the pan wouldn't even sizzle.
25th
inGOODspirits
Postby T-type » Sat Feb 14, 2009 6:31 pm
Well im getting rolling water in the middle so its real close to boiling after 6 hours...but i just added my other hotplate that gets pretty hot,...(used for melting lead for making fish weights.) now it seems to be boiling away....btw i just added it by using a small peice of copper pipe and set a corner of the hotplate on so its sitting verticle instead of horizontal and i rested my thick piece of plate (i use for welding stuff on my welding table) against it to keep it on the side of the keg.
Yea its a sanke keg so it only has like a small surface area thats actually touching on my 7-1/2" cast iron element...I may just get some stainless flatbar from work and cut a hole in the bottom and make it flat with bigger surface area
T-type
Postby T-type » Sat Feb 14, 2009 6:41 pm
Whats involved in disabling the thermostat on these things? i've read around but im not sure what to look for or if i can just bypass it.
T-type
Postby inGOODspirits » Sat Feb 14, 2009 7:06 pm
I am not sure. I would recommend not ruining a good hotplate. I would suggest using a hot water element (i got 2 for $50) and using a flange to attach it in the keg (I bought 2 flanges for $9 each).
25th
inGOODspirits
Postby Adverse Effects » Sat Feb 14, 2009 7:26 pm
the thing is a external heat supply you will lose at lest 50% of it to the air around it
with a internal heat supply 99%+ is going to heat the pot contents so there is almost no loss if any at all
Some people say its "FREE" but i say "there ant no free lunch" you get what you pay/work for
help those that help them self first
25Lt old school SS keg as a pot with a prototype Ponu still head
Adverse Effects
Postby T-type » Sat Feb 14, 2009 7:54 pm
yea im not ganna disable it on my new 1500 watt hotplate, i'd do it to the old one, but it seems like with 2 hotplates (one on bottom and one on the side) will work good.
Since it can boil water im sure it can boil mash right? since water boils at 212f and when running your mash it boils at like 172f right?
i know my column is working ;) i collected some water from it ;)
is the column suppose to be as hot as the boiling water because my thermometer read around 200f in the column...
remember im just testing it with water for now.
T-type
Postby Adverse Effects » Sat Feb 14, 2009 7:59 pm
atjones44 wrote:is the column suppose to be as hot as the boiling water because my thermometer read around 200f in the column...
the higher you go on the column the more the temp will drop but that is where letting it reflux for an hour or more befor you start to take off product will make sure everything is in balance
Adverse Effects
Postby T-type » Sat Feb 14, 2009 8:05 pm
how'd you wire your hot water elements?? are they 120v?
T-type
Postby inGOODspirits » Sun Feb 15, 2009 5:13 am
thay are easy to wire. But if you are not good at elecrical, cut the female end off of an extension cord. White wire to one side of the element and the black one to the other(there are two screws to attach you wires to). Be sure to use the ground(green) and attach it to the body of the keg for saftey.
25th
inGOODspirits
thay are easy to wire. But if you are not good at elecrical you could use a 120V, cut the female end off of an extension cord. White wire to one side of the element and the black one to the other(there are two screws to attach you wires to). Be sure to use the ground(green) and attach it to the body of the keg for saftey.
Typically 120V and/or 240V
25th
inGOODspirits
Postby T-type » Sun Feb 15, 2009 9:55 am
Thanks, that sounds easy enough. I might go that route and put one inside the keg by drilling a hole and welding a nut around it that the element can screw into.
T-type
Return to Novice Forum Graveyard
Who is online
Users browsing this forum: Bing [Bot] and 4 guests
