12 Gal. All Copper pot still
Simple pot still distillation and construction with thumpers and without..
Postby Soft batch » Sun Dec 07, 2014 2:01 pm
How it all started
The planning stages- make it all fit on paper first.
Final fitting on the copper before the first cut.
All cut out, I used air shears- highly recommend recommend!
Soft batch
Re: 12 Gal. All Copper pot still
Postby Soft batch » Sun Dec 07, 2014 2:08 pm
Plywood disks used for the bottom and top molds.
Starting to work the edges
After first round, ready to soften again
Heating the copper to soften it (heat, work , repeat)
Soft batch
Postby Soft batch » Sun Dec 07, 2014 2:19 pm
Seams used on the pot, thumper, and flake stand
Assembling (before soldering)
Soldering
Welsh seams
Soft batch
Postby Soft batch » Sun Dec 07, 2014 2:29 pm
Thumper bubbler
Thumper top
Flake stand
Completed thumper and flake stand. The only thing I would do differently is add a drain to the thumper, it gets hot when it's full! I charges with 1qt, and holds 2 1/2 gallons. It does not fill up during a run.
Completed setup
Soft batch
Postby Bing-Bot » Sun Dec 07, 2014 2:43 pm
LOVE THE OLD SCHOOL ELECTRIC! Nice!
Bing-Bot
Master Distiller
Postby firewater69 » Sun Dec 07, 2014 2:44 pm
Nice work S.B. really like what you did with the thumper!
firewater69
Postby Braz » Sun Dec 07, 2014 3:31 pm
Gorgeous work!
Braz
Braz
Postby S-Cackalacky » Sun Dec 07, 2014 3:54 pm
Beautiful work. Should be a good demo for anyone looking to do the same.
S-Cack,
Forum Contrarian
S-Cackalacky
Master Distiller
Postby just sayin » Sun Dec 07, 2014 4:13 pm
SB,
Beautiful copper! Great workmanship! Where did you source your copper? Did you use one of Pint's patterns. Thank you for posting it here.
Just Sayin'
just sayin
Postby Soft batch » Sun Dec 07, 2014 8:46 pm
Yes, it was Pint's plans that were scaled to 12 gallons - tweaked for the 5gal flake stand, and a 2-1/2 gal thumper. On a 3'x8' sheet. Copper was from gutter supply. https://www.guttersupply.com/p-Copper-Sheet.gstml
Soft batch
Postby hamshine » Mon Dec 08, 2014 5:49 am
That is a very nice still :thumbup: and your handle makes me want cookies..... nice work sir
ETOH.... yes plz
hamshine
Postby bearriver » Mon Dec 08, 2014 9:15 am
Gorgeous work there! I'm gonna bookmark this so I can... "Use it" later. :shifty:
bearriver
Postby just sayin » Mon Dec 08, 2014 9:33 am
Thanks for the link! The link showed 16 oz copper. Are you happy with the 16 0z? They are reasonable on the price. Was shipping reasonable?
just sayin
Postby Soft batch » Wed Dec 10, 2014 6:33 pm
The 16oz copper is fine for me, as I went electric (basement). I did double up the copper where I mounted the heating element. I would say go with heavier if heating by flame, at least for the bottom. Once soldered together it is very rigid.
I built this over a year ago, copper pice is about the same, can't remember shipping charges.
After revisiting the build pics, I'm tempted to build another - 6 gallon this time.
I apologize for the turned pics. They WERE oriented correctly before I shrunk and uploaded (from iPad). They must still have had embedded code to rotate.
Soft batch
Postby moosemilk » Sun Dec 28, 2014 5:35 pm
That sure did turn out beautiful! I used 16 oz as well, even the bottom,and heat on propane. No problems at all, but I agree on thicker. If I do another, I will go with thicker bottom.
moosemilk
Postby skow69 » Sun Dec 28, 2014 5:47 pm
Gorgeous! Welsh seams are sooo cool.
skow69
Postby Ghostpepperman » Tue Jan 06, 2015 10:57 pm
Very beautiful all copper setup you have there. :-)
Ghostpepperman
Ghostpepperman
Postby dm2211 » Sun Jan 18, 2015 3:07 am
One word: gorgeous! :D
dm2211
Postby megmoll100 » Sat Aug 12, 2017 3:53 pm
hey Softbatch
brilliant write up very impressed with your work i am a few years behind you decided to make the same pot and was concerned with using a gas heat source i see from you pictu res you have installed a heating element how did you do this and what did you use as i would like to use a similar option
megmoll100
Postby Soft batch » Mon Aug 14, 2017 9:15 am
On this pot I used a heating element flange. On my latest pot I installed a 2" copper tri-clamp ferrule and a stainless heating element adapter. I would highly recommend the later option - a covering for the electrical connectors is the only obstacle.
Soft batch
Return to Pot Distillation/Thumper and Design
Who is online
