in-line thumper... Calling Hawke
Simple pot still distillation and construction.
Re: Calling Hawke
Postby myerfire » Thu Sep 24, 2009 6:24 pm
Great pics, nice workmanship, good looking shop and interesting design. I'm envious.
myerfire
myerfire
Re: Calling Hawke
Postby plonker » Thu Sep 24, 2009 6:41 pm
Thats amazing Larry, good work..
I love these forums......
plonker
Re: Calling Hawke
Postby olddog » Thu Sep 24, 2009 7:13 pm
I am looking forward to you posting the results of your first run. :ebiggrin:
olddog
Master Distiller
Re: Calling Hawke
Postby Hawke » Fri Sep 25, 2009 4:20 am
Looks good. Keep us posted.
Hawke
Master Distiller
Re: Calling Hawke
Postby Hack » Fri Sep 25, 2009 7:48 am
That's a nice looking thumper.
Do you have a way to quickly break the vacuum between the thumper and boiler on shut down? Otherwise the the cooling liquid in the boiler will contract and siphon the thumper juice back into the boiler when you shut down. From my own experience I know this can happen within a minute or two of shutting down.
Hack
Re: Calling Hawke
Postby rad14701 » Fri Sep 25, 2009 10:57 am
You've been reading my mind, LWTCS... Been kicking that exact design around for several months now...
Ummm... Uhhh... Where's that patent application I was working on... :twisted:
Master Distiller
Re: Calling Hawke
Postby Dnderhead » Fri Sep 25, 2009 2:14 pm
the vacuum brakes Iv seen were just check valves
Dnderhead
Master Distiller
Re: Calling Hawke
Postby LWTCS » Fri Sep 25, 2009 4:58 pm
Hack wrote:Do you have a way to quickly break the vacuum between the thumper and boiler on shut down? Otherwise the the cooling liquid in the boiler will contract and siphon the thumper juice back into the boiler when you shut down. From my own experience I know this can happen within a minute or two of shutting down.
I had not even thought that to be an issue Hack. Please continue with that line of thinking out loud.
I just shut down from a water test run. It took 45 min. for steam to exit the business end with a 10 gallon water charge(is that,,,,,good/fast?). When switching to 120 volts Steam/vapor would barely exit the discharge. I am hopeful this is a good thing when the boiler (s) are charged with wine. I have a 4500 watt element on a 240 volt (30 amp) current. Then switched to a 120 volt current with a DPDT (30 amp) switch.
The unit completely assembled is 85.5 inches tall. This ain't Grandad's pot still :P
Re: Calling Hawke
Postby LWTCS » Fri Sep 25, 2009 5:00 pm
Finished weld inside the thumper pot
Re: Calling Hawke
Postby LWTCS » Fri Sep 25, 2009 5:03 pm
Lid fastoning system.
The threaded rod can be removed/ replaced or what ever during the service life of the unit.
Re: Calling Hawke
Postby LWTCS » Fri Sep 25, 2009 5:05 pm
Bottom of thump unit
Re: Calling Hawke
Postby LWTCS » Fri Sep 25, 2009 5:08 pm
lid fastoning system pic
PreviousNext
Return to Pot Distillation and Design
Who is online
Users browsing this forum: No registered users and 5 guests
