stainless steel question
narcolepticpug
Post by narcolepticpug »
i work in a sheetmetal shop as a welder. i have can get scaps stainless to make a pot.
But how do a attach my copper reflux still to a stainless steel pot??
ok is 304 stainless ok to use?
Hawke
Re: stainless steel question
Post by Hawke »
Most of the 300 series is ok.
You can get weld on flanges for sanitary clamps (tri-clamp). You could also weld a 2" half couple to the lid and use a copper thread adaptor on the column.
I would recomend the flange ferrels and clamp, myself.
HookLine
Post by HookLine »
304 is definitely okay. 304 & 316 would be the stainless of choice.
Be safe.
Be discreet.
And have fun.
narcolepticpug
yea. 316 is the best. but all we have in the way of stainless is 304 at work
HookLine
Post by HookLine »
IIRC, stainless beer kegs are 304 (the centre barrel part, not the hoops at the top and bottom).
Be safe.
Be discreet.
And have fun.
guillermo
Post by guillermo »
For my pot still, I brazed a 3" copper coupling onto the SS lid of my boiler with Safety-silv 56. The 3" copper pipe/column fits snugly inside and doesn't leak. Before stilling, I apply a small amount of vaseline so they won't freeze up.
augrat
Post by augrat »
Although it seems to be taboo I would prefer a stainless 75-115 liters pot still, a clear column would be nice as well. Any suggestions on a designer/builder or even ready made company? :?:
Any advice for a project such as this? :idea:
Igor_From_Jdessa
Post by Igor_From_Jdessa »
narcolepticpug wrote:... how do a attach my copper reflux still to a stainless steel pot??
Copper and stainless steel badly work together.
click for enlarge/
IMHO You need stainless steel reflux for stainless steel pot.
CletusDwight
Post by CletusDwight »
narcolepticpug wrote:i work in a sheetmetal shop as a welder
Being able to weld helps a lot.
I (tig) welded up my own pot from a length of 10" tube and a couple of plates. I welded a short length of 2.5" tube to the top plate and a ss flange made from 1.6mm plate. (thin, yes, but adequate, cheap and easy to cut from scrap - no need to buy)
Then I welded a couple more flanges to another length of 2.5" tube to make a column. I use a cork gasket to bolt the column on the pot.
The top of the column goes to copper. Several ways to do it - IMHO best is to braze a matching flange in copper and bolt it on with a gasket. Another way is to make a sliding fit of copper tube inside the steel and seal the join with dough. (braze/solder a ring on to stop the tube sliding all the way in.) It's fairly easy to make your own copper tube any size you want and solder/braze the seam.
My still was originally designed as a reflux with scrubbers in the column but I took them out later and now run it as a potstill.
PS. You NEED copper in the vapour path somewhere to help get rid of sulphur compounds.
