It is a nice home build option. Not cheap but then neither is buying stainless bosses and having them welded on
thats why in really curious about it.
in the way you describe it i could use a nipple 2 nuts 2 washer and 2 cork wash and do the same.
its not that i i don't think its worth it but i checked and couldn't find then in america.
picture this grind off two of the side of a nuts so it will go trough the the hole and a washer with a dent/slut
a threaded nipple and washer and nuts outside.
kinda like a a bulkhead fitting.
one worry is a treaded nipple is a lot big in the middle and won't be able to tighten them enough
how big is the entry of a sanke valve?
if i have to get stuff inside from there.
how big is the treading of a water heater element?
getting error from my thinking there nipples anrt treaded inside to srew something like a element.
treading something in my point of view is less trouble then a s/s welder.
still do able
just need the right tap.
do those guys from uk ship to america?
even if its not the right treading standard i could get elements from there?
50 or 60 cycle doesn't matter on element doesn't it?
its just i might finally get my hands on a keg and welding the thing i a major concern
i can't use gas since i distill in my basement.
