Pot still with dephlegmator
Simple pot still distillation and construction.
Re: Pot still with dephlegmator
Postby Ian Jay » Fri Nov 18, 2011 2:16 pm
Philosophically, the challenge may be here:
"The only thing i'd really need to add this is 5 bucks worth of copper, a 7 dollar pot, and some plastic tubing. and it seems simpler than switching things to a vertical layout. Would it really not be worth it?"
End of discussion?
Ian Jay
Postby rad14701 » Fri Nov 18, 2011 3:07 pm
Sometimes you've just gotta put solder to copper, if for no other reason than to say you've done it or to soothe the soul... :thumbup:
Master Distiller
Postby LWTCS » Fri Nov 18, 2011 4:57 pm
Postby rockchucker22 » Fri Nov 18, 2011 5:37 pm
LWTCS wrote:http://youtu.be/oS28yrkjntM
Wait wait wait, you don't ride motorcycles! I'm ashamed to associate with such a low life!
if your gonna ride, ride the wild horse
rockchucker22
Master Distiller
Postby LWTCS » Fri Nov 18, 2011 5:41 pm
rockchucker22 wrote:Wait wait wait, you don't ride motorcycles! I'm ashamed to associate with such a low life!
Would if I could.
I have the soul to do so,,,,but not the funds to ride what I would prefer to ride
Postby MuleKicker » Fri Nov 18, 2011 6:32 pm
Would if I could.
ohh come on LW, vespas arent that expensive :moresarcasm:
-Control Freak-
AKA MulekickerHDbrownNose
MuleKicker
Postby LWTCS » Fri Nov 18, 2011 6:36 pm
Haha
Vespa!
Beach cruiser more like it
Postby dime » Fri Nov 18, 2011 6:42 pm
I didn't realize that you ran that rig without the plates. That gives me a bit more confidence in adding the dephlegmator right over the thumper :)
Yes, but you still need to address the puking issue because that just isn't normal... You are looking to use that extra chamber as thumper, not a puke box, right...???
I'm assuming its happening because of my 3/8" pipe. The vapor's coming out too hard and when it hits the charge in my thumper the bubbles just go crazy. The extra chamber, I thought, would fix that problem since it would keep the bubbling from getting to the output pipe. But it only reduced it.
If you didn't put a dephlagmater on top of it.
Why would a thumper that size need a drain even with the dephlegmator? Even if I left it in full reflux for the entire run, the thumper would be able to hold everything and have room for about 5 more quarts.
End of discussion?
I wouldn't say end of discussion, but yeah. For me that's reason enough to go ahead with it and see what happens for myself. As larry said in his video.
dime
Postby LWTCS » Fri Nov 18, 2011 6:48 pm
When run as a typical thumper,,,more often than not there will be very little liquid remaining in the thumper at the conclusion of a run...Especially with my rig as I get really good thermal transfer.
But when incorporating the forced reflux you will be retaining much more liquid and the thing can and will flood if you are not minding your P's & Q's. I flooded to dog doodoo out of mine prior to installing the drain.
Postby dime » Sun Nov 20, 2011 2:06 am
Just wondering, is it significantly beneficial to have a thumper with a dephlegmator? What if I just put the dephlegmator right over the boiler? I'd think that would still produce a more pure distillate than a standard column.
Edit:
After a little more thought, cycling the vapor through a thumper should be a lot faster than cycling through the boiler. So I guess that answers the question.
dime
PreviousNext
Return to Pot Distillation and Design
Who is online
