TriClover to 2" npt question
Simple pot still distillation and construction.
Postby Big Stogie » Fri Mar 23, 2012 9:28 am
I bought an adaptor from St Pats to attach my column and it has a piece of perforated screen welded into it. Should I cut this out? I thought this was supposed to be open?
thanks,
Big Stogie
Big Stogie
Re: TriClover to 2" npt question
Postby Fjard » Fri Mar 23, 2012 9:32 am
Which one did you buy? There shouldn't be a screen in them, the ones I buy from them of other sizes don't have the screen/filter. I would try calling them.
Fjard
Postby Coaster » Fri Mar 23, 2012 9:47 am
@ Big Stogie,
Could you post a clear picture of this adaptor?
Regards,
Coaster
Coaster
Postby Big Stogie » Fri Mar 23, 2012 10:30 am
It is just a piece of flat stainless stock with small holes punched in it like a strainer. It is tig tacked in three places I will take a pic when I go back to my shop tomorrow. I will cut it out thanks for the response, I was pretty sure it should not be there.
Mike
Big Stogie
Postby WV Shine » Fri Mar 23, 2012 10:53 am
That's actually an interesting find... could be really useful for retaining packing in a column still. Can't say it would do you a lot of good on your pot though.
If you have both ya might want to leave it in as long as there are plenty of holes and you don't think it would restrict flow too much?
WV Shine
Postby Prairiepiss » Fri Mar 23, 2012 10:58 am
How big is the screen? If its big enough it shouldn't really make much difference.
It'scoldaroundhere. Whenyouloseyourjacket.
My Stuffs.
Prairiepiss
Master Distiller
Postby Big Stogie » Sun Mar 25, 2012 5:23 am
The fitting
Big Stogie
Postby NineInchNails » Sun Mar 25, 2012 6:00 am
That looks pretty restrictive. I don't see it doing you much good in there. For a pot still it might be fine though, if you don't want to remove it.
NineInchNails
Postby rad14701 » Sun Mar 25, 2012 7:54 am
Those would make great perforated plates if someone used their imagination... :thumbup:
Master Distiller
Postby Braz » Sun Mar 25, 2012 8:52 am
rad14701 wrote:Those would make great perforated plates if someone used their imagination... :thumbup:
Or a good starting point for a gin basket.
Braz
Braz
Return to Pot Distillation and Design
Who is online
Users browsing this forum: No registered users and 3 guests
