Steel in a boiler connection?
Simple pot still distillation and construction.
Postby baron4406 » Sat Mar 24, 2012 1:35 pm
Building my first still now, Will probably have 3 or 4 by the time I'm done. Right now I have a pot still the Forum Member Samohon design I saw on here all built, plus a valved Reflux head still. My boiler is the infamous old milk can. I want to make the pot still and reflux still interchangeable on the boiler. The problem has been the boiler connection, I really don't like the connection of the Samohon design i can only get a 1 1/2" hole in the copper cap and still have room for bolts/gasket. So I was rummaging around all my old auto parts and I found a small 4 bolt flange that I could solder a 2" copper union to. Only problem is its mild steel, would this be a problem?
baron4406
Re: Steel in a boiler connection?
Postby NineInchNails » Sat Mar 24, 2012 1:48 pm
Steel is not advised. Copper and stainless steel is ideal. Some people use some brass parts.
NineInchNails
Postby Braz » Sat Mar 24, 2012 4:32 pm
I don't think the 1.5 inch hole in the cap is a problem. I ran that way with good success till I got a keg boiler.
Braz
Braz
Postby baron4406 » Sun Mar 25, 2012 4:54 am
That looks exactly like my present boiler connection, my other plan was to get a 3" cap, then a 3" x 2" adapter. That would give me a much bigger hole. Don't forget my setup will have to accomidate a reflux setup also.Then again a hole smaller than 2" will help keep my packing in the reflux column. Thanks guys this board is great.
baron4406
Postby Braz » Sun Mar 25, 2012 9:02 am
That looks exactly like my present boiler connection...
Go with what you have, it will work fine with either still head.
Braz
Braz
Postby baron4406 » Tue Mar 27, 2012 9:50 am
Ok don't know what kind of cap you have, but the biggest hole I can get is MAYBE 1 3/8" and that's using the smallest bolts I have (M5). All I need to do the 3" setup is a 3" cap but if i don't have to spend that I won't. Since my Column is 2" I'd rather have a 2" hole coming out of the boiler. Or am I being too picky?
baron4406
Postby Braz » Tue Mar 27, 2012 1:14 pm
Yes. :D
You caused me to go out to the still shed and measure the hole and it is 1 3/8". Like I said, it worked well with both a 2" Boka and a 2" pot head.
Braz
Braz
Postby baron4406 » Wed Mar 28, 2012 1:25 am
Thanks Braz. BTW all this talk actually caused my "McGuyver" mind to think up another rather elegant solution. I will post a pic when its done.
baron4406
Postby baron4406 » Wed Mar 28, 2012 3:45 am
Ok took a 4" section of 3" copper pipe, split it in half, hammered it flat. Traced out a 2" coupling then overlayed a 3 1/2" coupling. Drilled out the center with a 2" hole saw and drilled some holes. Fitted the coupling then soldered. Stainless bolts/washers and some PTFE gasket material. :D
baron4406
Return to Pot Distillation and Design
Who is online
Users browsing this forum: No registered users and 3 guests
