Using butyl rubber as a seal.
Simple pot still distillation and construction.
Re: Using butyl rubber as a seal.
Postby King Of Hearts » Thu Mar 29, 2012 10:12 am
Mwilcon wrote:I had mother boiler that worked well before, a 15 quart pressure cooker and it worked well and then my friend needed to use the boiler and...well....it didn't come back in useable condition. So I found this just laying around. It is alluminum the picture I uploaded was off google, too much work taking a picture, uploading it to the computer, then posting it. But it's the same setup. To controll the temperature I cut the power cord in the middle and wired a potentiometer in series with the heating element, screwed in a heat sink to the voltage regulator triac and enclosed the entire thing with a small plastic box. It works well and with a few calculations I discovered that with 100 volts running through the heating element it should give me roughly 175F.
I have read the introduction, and also many different topics before posting this thread. I wouldn't like to bother you guys if I could figure this problem out myself. I've spent alot of time thinking about this and I just can't get it.
You would be better off to find a suitable boiler non-aluminum.
Brewhaus 2in Pot Still head, 15.5 gal keg, 4 inch 5 plate copper column, deplag & condensor
A bad wash never makes a good whiskey
and a good whiskey always starts with a good wash.
King Of Hearts
Postby rad14701 » Thu Mar 29, 2012 10:48 am
You need the capability to push higher than 175F... See the topics in the New Distiller Reading Lounge on how you can't control the temperature of a pot still...
Master Distiller
Postby Prairiepiss » Thu Mar 29, 2012 10:56 am
I would say you already have the best answer. You may not like it. But it is the best solution. Flour paste.
It'scoldaroundhere. Whenyouloseyourjacket.
My Stuffs.
Prairiepiss
Master Distiller
Postby WV Shine » Thu Mar 29, 2012 12:32 pm
Neither architectural or food-grade silicone have been approved for use... You never know what all they contain and there use with high temperature high proof alcohol is not documented... teflon/ptfe is the only recommended synthetic.
Edit: looks like the post disappeared, guess you got your answer ;)
WV Shine
Postby Prairiepiss » Thu Mar 29, 2012 12:34 pm
I guess you didn't read my post. Or go read the rules we live by?
My Stuffs.
Prairiepiss
Master Distiller
Postby Mwilcon » Thu Mar 29, 2012 12:36 pm
rad14701 wrote:You need the capability to push higher than 175F... See the topics in the New Distiller Reading Lounge on how you can't control the temperature of a pot still...
It can go to about 250F, I was just saying that I marked the potentiometer where the 175F mark is so I can set it to that setting during the run.
And would 100% silicone architectural grade be safe to use as a seal? I was researching it and I found it is safe with drinking water and does not decompose in the presence of alcohol of any kind(ethynol, methanol, isopropyl,etc.).
Mwilcon
Postby Mwilcon » Thu Mar 29, 2012 12:42 pm
I deleted it because I wanted to add one more thing to it sorry bout that.
Prairiepiss wrote:I guess you didn't read my post. Or go read the rules we live by?
I did read it, I read it many times; I was just saying that it is said to be safe with all chemicals when dry. But I wanted to check with you guys and now I know I shouldn't use it.
Mwilcon
Postby Coaster » Thu Mar 29, 2012 1:29 pm
@ Mwilcon,
By now I am certain you have read The Rules By Which We Live item #8 usage of plastics/ synthetics in distilling ->
http://homedistiller.org/forum/viewtopic.php?f=35&t=5090
Aside from focusing on how to correctly seal the lid of your coffee maker have you addressed the problem with the black Plastic spigot? That black Plastic spigot goes into the your coffee maker and has Plastic pieces securing it to the inside the coffee maker which are in direct contact with hot alcohol.
Regards,
Coaster
Coaster
Postby Mwilcon » Thu Mar 29, 2012 2:16 pm
Coaster wrote:Aside from focusing on how to correctly seal the lid of your coffee maker have you addressed the problem with the black Plastic spigot? That black Plastic spigot goes into the your coffee maker and has Plastic pieces securing it to the inside the coffee maker which are in direct contact with hot alcohol.
If your talking about the knob on the top of the lid I unscrewed, and drilled out a wider hole to acomodate my brass fittings.
Mwilcon
Postby Prairiepiss » Thu Mar 29, 2012 2:43 pm
No he was talking about the spigot that is used to fill tour coffee cup with. The valve.
My Stuffs.
Prairiepiss
Master Distiller
Postby Mwilcon » Thu Mar 29, 2012 3:01 pm
I don't think the spigot will pose much of a hazard because it's made to withstand much higher temperatures than that of what ethanol boils at. And its also been used many times to boil water.
Mwilcon
Postby fullhouse » Thu Mar 29, 2012 3:09 pm
boiling water and temperature has little to do with the fact the ethanol is a solvent ...it too is unsafe as a plastic
3' Essential Extractor PSII High Capacity (Brewhaus) on gas,recirculating 60 gal olive barrel for cooling
Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for ~ Socrates
fullhouse
PreviousNext
Return to Pot Distillation and Design
Who is online
Users browsing this forum: Stainless dude and 2 guests
