ICE ON THE WORM OR COLD WATER FLOW?
Simple pot still distillation and construction with thumpers and without..
Postby Stayshine » Sat Nov 10, 2012 5:39 am
Is it better to fill my worm bucket with ice or plug a hose in it and just run the water through it?
Stayshine
Re: ICE ON THE WORM OR COLD WATER FLOW?
Postby just-a-sip » Sat Nov 10, 2012 5:43 am
ice is not the best way of cooling distillate. you want a cooler then boiling temp not freezing . several reasons but one is that your wasting time using ice because the cooling water just has to be colder then the temp of the vapor to cause condensation. also by having the distillate coming off warm rather then cold you allow for some nasties to evaporate as you collect. there is a much more technical answer to this whole process but the use of ice is covered often ... i would just say use running or recirculated water and you will be just fine
Just-A-Sip
just-a-sip
Postby rad14701 » Sun Nov 11, 2012 7:37 am
Shock cooling is never the right answer... :thumbdown: Not to mention that straight ice will eventually promote voids... :idea: This subject has been covered far too many times and further discussion simply isn't warranted here... :problem:
Master Distiller
Return to Pot Distillation/Thumper and Design
Who is online
Users browsing this forum: MSNbot Media and 1 guest
