Soft Copper
Simple pot still distillation and construction with thumpers and without..
Soft Copper
Postby Dave73 » Mon Jan 14, 2013 1:50 pm
I am about to build my first all copper still and a friend of mine has a roll of copper but it is the soft copper. I was wondering if this is ok or will it be too soft?
Dave73
Re: Soft Copper
Postby maheel » Mon Jan 14, 2013 2:38 pm
hey dave
do you mean sheet copper for making a pot
you could always get creative with it and make some sort of exterior support barrel around it.
or a roll of annealed copper tube for a worm etc?
maheel
Re: Soft Copper
Postby Dave73 » Mon Jan 14, 2013 5:52 pm
yes sheet copper my friend has a roll thats 24" wide and 20 feet long. So your saying if I build some type of support around it then I'll be fine
Dave73
Re: Soft Copper
Postby maheel » Mon Jan 14, 2013 6:25 pm
Dave73 wrote:yes sheet copper my friend has a roll thats 24" wide and 20 feet long. So your saying if I build some type of support around it then I'll be fine
never tried it but i reckon it would work
another issue is going to be the lid, it might bend and buckle if your putting weight onto it... so you need to consider that
but if the sheet is thin you could consider lining a wooden barrel with it and "fold" the seams and solder from inside
fit the ends and fold the seams and solder... etc etc
support the column output with a frame above etc
do able but challenging, but if i had to i would....
if you want easy i would say go get a keg if you think it's to hard, i would just get a keg....
maheel
Re: Soft Copper
Postby mash rookie » Mon Jan 14, 2013 7:18 pm
Hi Dave. Welcome aboard. The answer is that it depends on the thickness gauge of the copper. You probably wont need support. Soft annealed copper you will have to be careful while working so you don’t beat it up too much. The more you work with it the stiffer it will become. Copper work hardens. You could have it bead blasted to temper it if you wanted. I would just handle it carefully and build your pot. It will get stiffer over time as it is handled. Even a light gauge copper could last you a lifetime done correctly.
mash rookie
Re: Soft Copper
Postby Dave73 » Tue Jan 15, 2013 4:14 am
Thanks for the info. I've been using a keg ansd stainless for a long time now and just wanted to build an all copper still my grandfather gave me a design for one before he died and I would like to build it and put it to work lol
Dave73
Re: Soft Copper
Postby buckwild1 » Wed Jan 16, 2013 12:49 am
i was looking at doing this too. I was thinking of work hardening the copper through a roller system before trying to make the pot and lid first. IDK if it wll harden it enough though
buckwild1
Return to Pot Distillation/Thumper and Design
Who is online
Users browsing this forum: witblits007 and 2 guests
