waterseal potstill pictures
dutch@home
Post by dutch@home »
close-in boiler before dis-assembling
after some stripping and cleaning.
it stands upsidedown!
2 brass rings solderd on top
boiler with cover and arm
everything together
boiler capacity : 15 liter - propane heated.
the space between the brass rings has to be filled with water, in the water stands the top/hat .
the water performs a gasket and also works as a pressure relief.
topping-up the water: 2-3 times during a 10-12 liter run.
if you don't want to do time,
don't do a crime!
and as a finishing touch,
god created the dutch.
Uncle Remus
Post by Uncle Remus »
Very nice design Dutch! Now that is truely inovative thinking coming up with a water gasket for a seal. Great idea...the siliconers and JB welders out there should take note.
stoker
Post by stoker »
cool, i've never heard a thing about such a water seal, good idea!
apart from that, your disign looks like one on a dutch site, did you use it?
(im begian btw)
-I have too much blood in my alcohol system-
dutch@home
i didn't find it on a dutch site (wich one do you mean stoker?)
i found searching the net.
its not my invention.i did something like copy/paste :wink:
picture from what i did copy the idia
http://www.destillatio.com/destille/des ... 82b401.htm" onclick="window.open(this.href);return false;" rel="nofollow
the english version is under construction.
available in frech german and spanish
if the link has to be removed please let me know(its from a potstill company)
they also have a parrotspout,its just under 60 euro!
made my own from scrap......
don't do a crime!
rkr
Post by rkr »
You know, you could route the cooling water via the water trap. That way you wouldn't have to worry about filling it.
Cheers, Riku
Sinker
Post by Sinker »
Beautiful work.
And Riku's idea is interesting.
Never on a Sunday.
possum
Post by possum »
Good thinking dutch. A cool design Idea.
I love copper rigs.
CoopsOz
Post by CoopsOz »
Nice...excellent work! :D
Tater
Post by Tater »
You should sent those pics to tony and see if he'll put them on his sight.Nice work
dutch@home
tater:
should i just send the pics or ask first wich one he would like to use?
how can i reach him, forum ore better p-m.
adress?
don't do a crime!
Tater
Post by Tater »
how to reach tony is distillr@bigpond.net.au read intro on his sight.
Ricky
Post by Ricky »
you know salt water has a higher boiling point than plane water. i wonder if you used salt water for the seal if it would evaporate as quickly as plane water or would the water evaporate the same and just leave the salt behind?
Day Late;Dollar Short
Rudi
Location: 50 miles past kikatinalong up that dirt track
Post by Rudi »
I think salt water has a lower boiling point and the salt would get left behind and nasty everything up
Such is life
Husker
Post by Husker »
Rudi
Salt water has a higher boiling point. However, I am not sure how this will affect the evaporation rate (it will keep the water in this "gasket" from boiling during any normal distillation process).
Yes, if the water evaporates, it will leave a nasty residue. However, if the water is filled with fresh water (no extra salt), then it will have no problems. I do not know, however, if adding salt will buy you much benefit. Only trial/error will tell.
I think someone mentioned routing the cooling water to drop into this gasket, and then having a tube leading out of the gasket, back into the bucket. I think that is the ideal method, as the gasket will simply stay full.
H.
Ricky
Post by Ricky »
i agree with you husker. for some reason i didnt grasp the prior message. i was just trying to think outside the box. sometimes it works sometimes it doesnt. thats what makes this forum so good,hundreds of people suggesting new ideas.
stoker
Post by stoker »
and I don't think the chloride has a good effect on the copper
Rudi
Post by Rudi »
I agree new ideas is what its all about. I got the idea that salt water boils faster from my grandmother who put salt in pasta water to make it boil faster ??maybe she just liked the taste of saltI have kept alot of marine fish tanks and just the salt water evaporating corroded the hell outa the light fittings above it in a very short time.and left lotsa salty residue all around the lights etc Ricky keep the ideas coming and Husker thanks I learn somthing new every day.
Such is life
hornedrhodent
Post by hornedrhodent »
="Husker
H.
You forgot to run the drain from the gasket to the header tank for the boiler's water jacket and the outlet from that through the old car radiator to cool it before it goes back into the bucket.
dutch@home
i have one correction to make!
the water in the seal wil never boil!
your cooking a water-alc mixture, the boiling point is below 100 degr.
the water just evaporates, the hotter it is, the faster it evaporates.
i think routing the coolingwater through the sealing might give problems.
when i top-up the level with some water (+- 50-75cc) the still stops dripping for aprox. 10-15 seconds.
this is becourse you are cooling the top off the boiler and the hood.
at that moment you have some reflux, your "steam" condenses at those cold spots.
to avoid this fill whith hot water.
in my opinion the best thing to do is add a litlle oil to the water so the seal is sealed to avoid evaporation. :lol: sealing a seal? :lol:
or yuse oil instead of water.
but whats the problem off topping up once and a while?
when running your still you should be around, so no big deal!
don't do a crime!
Ricky
Post by Ricky »
boy this is getting fun! the inside ring is taller than the out side ring to keep water from overflowing into yhe boiler correct? when the top"bowl" is placed into the water seal the bowl has liguid both inside and outside of it doesnt it? if it does then doesnt the oil stand a chance of getting mixed with the wash? any condensation that might come down the insides of the bowl could be caught by the seal. dutch i hope i am not offending you with my opinions. the only reason i am trying to be so thorough is because i could apply this to my setup and correct my gasket issues that i have. i yhink the water seal is an awsume idea and with enough brainstorming we could possibly refine it even more.
stillvodka
Post by stillvodka »
You could run it with a header tank, and have something like parrot spout sort of set up, keep water level equal.
dutch@home
getting a little oil in the wash isn't a problem,its even adviced by the pro's to avoid foaming over when boiling on grains.
only food grade oil!
condens wich comes in the inside seal evaporates again.
don't do a crime!
hornedrhodent
="Rudi"
You or she got it wrong - it boils hotter - not faster - possibly cooks the pasta faster. Boiling faster doesn't cook quicker as the temp stay the same. Boiling hotter cooks faster - that's what pressure cookers are all about.
Ricky
Post by Ricky »
good deal dutch. oil sounds like it may be the way to go!
stillvodka
When any of you open your bonnet/hood on your car, do any of you know what that other plastic water bottle is for, that leads to your Radiator, that thing what keeps your engine from over heating/water loss, suppose it looks the same as your washer bottle, it's called a (Header/expansion tank) it keeps water loss in a system to a minimum, no other way you can do it , multi trillion$£ car industry cant find no other way, no chemical water additives either, they wont work, you cant retard the process of water getting hot and needing to be replenished, only way is add more or fit Header/expansion tank
Please dont disregard other people post, because they are not technical enough, Remember, the Greatest Inventions were simple things
Shine Man
Post by Shine Man »
You could hire a beautiful young blond nude dutch girl to stand by the still while it runs and keep the water level up in the gasket. That still would not match the beauty of your still. You did a fantastic job. Great engineering and craftmanship.
Bujapat
Post by Bujapat »
I think here's the dutch site Stoker was talkin' about :
http://www.home.zonnet.nl/nvvoorst/
I'm french speaking!
stillvodka
This one, http://www.copper-alembic.com onclick="window.open(this.href);return false;" rel="nofollow
