55 gallon stainless steel barrel as boiler?
Simple pot still distillation and construction with thumpers and without..
Postby Beerandsuds » Fri Feb 08, 2013 1:37 pm
Anyone ever done this or seen one? Seems like a relatively inexpensive way to have a large boiler. If anyone has seen or done this, what did you do for a pot still head? Just make a normal one but use 6" pipe instead of 3"?
Beerandsuds
Re: 55 gallon stainless steel barrel as boiler?
Postby acfixer69 » Fri Feb 08, 2013 2:15 pm
FYI better tie yourself to a commercial distillery the gate keeper will be here.... Think I here the keys jingling. :wave:
AC
acfixer69
Postby Beerandsuds » Fri Feb 08, 2013 2:35 pm
acfixer69 wrote:FYI better tie yourself to a commercial distillery the gate keeper will be here.... Think I here the keys jingling. :wave:
AC
Are we not allowed to talk about distilling in this volume?
Beerandsuds
Postby toast860 » Fri Feb 08, 2013 2:53 pm
yea we are but when u talk of soemthing this size then most think u dont plan on just make home stock. but i think that would work. i dont know where u would find one but good luck
if you cant build a paper airplane, then leave the rocket alone.
its like wiping before you poop, dont make sense.
toast860
Postby Beerandsuds » Fri Feb 08, 2013 3:09 pm
toast860 wrote:yea we are but when u talk of soemthing this size then most think u dont plan on just make home stock. but i think that would work. i dont know where u would find one but good luck
I'm building a 3" pot still right now to go on a 15.5 gallon sanke keg. That said I have alot of friends that I'd like to share with, so cooking that much would be fun. Also I'd rather make alot once than many times over. Just a fun thought to entertain while I try learn on my 3" pot still.
Beerandsuds
Postby Prairiepiss » Fri Feb 08, 2013 3:10 pm
You obviously haven't done much research around here. :problem:
Prairiepiss
Master Distiller
Return to Pot Distillation/Thumper and Design
Who is online
