12 Gal. All Copper pot still
Soft batch
Post by Soft batch »
How it all started
The planning stages- make it all fit on paper first.
Final fitting on the copper before the first cut.
All cut out, I used air shears- highly recommend recommend!
Soft batch
Re: 12 Gal. All Copper pot still
Plywood disks used for the bottom and top molds.
Starting to work the edges
After first round, ready to soften again
Heating the copper to soften it (heat, work , repeat)
Soft batch
Seams used on the pot, thumper, and flake stand
Assembling (before soldering)
Soldering
Welsh seams
Soft batch
Thumper bubbler
Thumper top
Flake stand
Completed thumper and flake stand. The only thing I would do differently is add a drain to the thumper, it gets hot when it's full! I charges with 1qt, and holds 2 1/2 gallons. It does not fill up during a run.
Completed setup
Halfbaked
Post by Halfbaked »
LOVE THE OLD SCHOOL ELECTRIC! Nice!
firewater69
Post by firewater69 »
Nice work S.B. really like what you did with the thumper!
Braz
Post by Braz »
Gorgeous work!
Braz
S-Cackalacky
Post by S-Cackalacky »
Beautiful work. Should be a good demo for anyone looking to do the same.
just sayin
Post by just sayin »
SB,
Beautiful copper! Great workmanship! Where did you source your copper? Did you use one of Pint's patterns. Thank you for posting it here.
Just Sayin'
Soft batch
Yes, it was Pint's plans that were scaled to 12 gallons - tweaked for the 5gal flake stand, and a 2-1/2 gal thumper. On a 3'x8' sheet. Copper was from gutter supply. https://www.guttersupply.com/p-Copper-Sheet.gstml" onclick="window.open(this.href);return false;" rel="nofollow
hamshine
Post by hamshine »
That is a very nice still :thumbup: and your handle makes me want cookies..... nice work sir
ETOH.... yes plz
bearriver
Post by bearriver »
Gorgeous work there! I'm gonna bookmark this so I can... "Use it" later. :shifty:
just sayin
Thanks for the link! The link showed 16 oz copper. Are you happy with the 16 0z? They are reasonable on the price. Was shipping reasonable?
Soft batch
The 16oz copper is fine for me, as I went electric (basement). I did double up the copper where I mounted the heating element. I would say go with heavier if heating by flame, at least for the bottom. Once soldered together it is very rigid.
I built this over a year ago, copper pice is about the same, can't remember shipping charges.
After revisiting the build pics, I'm tempted to build another - 6 gallon this time.
I apologize for the turned pics. They WERE oriented correctly before I shrunk and uploaded (from iPad). They must still have had embedded code to rotate.
moosemilk
Post by moosemilk »
That sure did turn out beautiful! I used 16 oz as well, even the bottom,and heat on propane. No problems at all, but I agree on thicker. If I do another, I will go with thicker bottom.
skow69
Post by skow69 »
Gorgeous! Welsh seams are sooo cool.
Ghostpepperman
Post by Ghostpepperman »
Very beautiful all copper setup you have there. :-)
Ghostpepperman
dm2211
Post by dm2211 »
One word: gorgeous! :D
megmoll100
Post by megmoll100 »
hey Softbatch
brilliant write up very impressed with your work i am a few years behind you decided to make the same pot and was concerned with using a gas heat source i see from you pictu res you have installed a heating element how did you do this and what did you use as i would like to use a similar option
Soft batch
On this pot I used a heating element flange. On my latest pot I installed a 2" copper tri-clamp ferrule and a stainless heating element adapter. I would highly recommend the later option - a covering for the electrical connectors is the only obstacle.
