ss 17ltr pot still column size
Hi,i recently purchased a 17ltr stock pot. It was meant to be 21ltr but the manufacturer sent wrong size,gutted. Anyway ,for now i just want a pot still. I will be usinf a 2ft( between cooling pipes) liebig 3/4 over 1/2" with possible spiral. The main thing i am thinking,is it worth fitting a 2" column on a 17ltr still? i ask this as my original idea was so i could convert to a reflux later on, or would you not bother and go narrower condenser? any thoughts plz? thanks
- der wo
Re: ss 17ltr pot still column size
2" for 17lt sounds good. Wait, it's exactly what I have.
Of course the wattage determines the column diameter. If you want to run it with little power only, 1 1/2" would be ok also. But 2" is definetely not too much for such a still size.
2" will work fine, as der wo advised. I have a 1-1/2" riser on my 16 qt. stock pot potstill which I heat with a modified hotplate. It makes fine gins.
One thing to consider, 2" copper fittings are significantly more expensive than 1-1/2" fittings....90* elbow, reducers, unions, couplings, etc. If it's a matter of cost, then 1-1/2" is worthy of consideration.
Regardless, I think you'll find that the potential production rate differences between 2" and 1-1/2" are minimal. Either will mate with your heat source.....which is?
its heated on a gas cooker. I agree with the price difference,quite pricey the 2"/54mm copper in uk. I am thinking if i do go the 54mm,the tank connector is a good starting point at £14,then a foot of 54mm copper is £10, then like you say the elbows,reducers,etc all add up. ill compare the difference,but as a thought,if later on i deciede on converting to a reflux, its probably worth paying the extra for the 54mm?? cheers guys
- der wo
All reflux designs require the full diameter only for the packed part and the reflux coil. For example a CM with 2" upside the coil, and then two 90° bends everything 2", would be wasting expensive.
- der wo
For example a boka doesn't need reducers or bends.
And generally reducers are replacable: Solder a plate onto the pipe, that it's closed, and drill a hole for the pipe with the new diameter.
hi,sorry for delay and replies. i didnt get any further with this till now. I held back on building as ordered a 65mm cutter for stainless and discovered that the ss stock pot lid is going to be too flimsy,as shown and arkward to cut, to hold my column and liebig. I have though found that a pizza tray fits perfectly in place of original lid,so thinking of doubling 2 together to get more rigid. I have saw some non stick stainless steel ones but dont think this would be suitable for ethenol? thanks
- der wo
If the coating is teflon, why not?
But of course soldering doesn't work. The teflon would melt and the fumes are poisonous. But if you only cut it and screw the column on, it's ok I think.
carbon steel some of them,looking also now at ss mixing bowls which may be even better, cheers
